Old 03-03-2013, 03:15 PM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
Lightbulb Towing hook the same size for each model?
Towing hook the same size for each model? I want to buy a new one, and have searched everywhere, but cannot find a definite answer. Are the towing hooks the same size for all BMW (E30, E39, E46, 3 series, 5 series, etc..) The part number from BMW is not always list in ads. I found a BMW place very close to me with good prices, but was unclear whether it is a walk in store, or Just by mail. Again, people who write stuff are not clear with what they write, and leave me with questions. If They are walk in I will just drive there. 10 minutes.
I found at least 2 tools missing out of my tool kit, the tow
hook and **** changed to some other tool, unknown***. I want to make sure I also have the proper (preferably OEM) tow hook.
Any comments appreciated on what is best. I just want to be prepared.
thanx..
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Old 03-03-2013, 03:54 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Same "towing hinge" for all: http://www.realoem.com/bmw/partxref.do?part=72157203519
Here's the other stuff: http://www.realoem.com/bmw/partgrp.d...87&hg=71&fg=05
Old 03-03-2013, 09:49 PM
I would think the proper towing hook should also be listed in one of these threads:
- What do you keep in your trunk for winter emergencies (1) & for all-weather emergencies (1) & pictures of complete rear tool kit contents (cn90) (3-series) & the BMW Rescue Manual for Emergency Services (1)
Old 03-04-2013, 10:50 AM
SRFast's Avatar
SRFast SRFast is offline
Mein Auto: 2003 BMW 530i
I would think the BMW tow hooks are the same across all the model lines. It would be too expensive to have unique tow hooks for each model considering its function.
Hope this helps...JL
2003 530i 5spd/SP/PP/CWP/PDC/RSAB/Xenons
Old 03-04-2013, 11:51 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Edjack posted a link (if you click it) that shows which BMW models use the same tow hook as the e39. Yes, BMW does use the same part in many different vehicles sometimes...and in this case the e39's tow hook is used on multiple BMW models as well as some Rolls Royce models.
The SUVs use a different tow hook...probably due to some design changest etc...but again, if you look up the part nbr used for your car...you can then paste that same number in the part nbr cross reference feature of realoem.com , bmwfans.info, or http://bmwmobiletradition-onlinecom.x-shops.com/bmw/ (just to name a few) and find out which other BMW models use the same part.
Its' that simple and easy...no need to guess or speculate...and only takes a few seconds.
Another example...if you click the 1st link below you'll see all the BMWs that use the same towing hook as the one used for my e53 X5...and if you click the 2nd link you'll see all the BMWs that use the same towing hook as my e38 7 series:
  1. http://www.realoem.com/bmw/partxref....0643&showus=on (e53/e60/e63/e65/e70/e71/e83/e85/e88/e90)
  2. http://www.realoem.com/bmw/partxref....3519&showus=on (e31/e38/e39/e46/e52)
Q {BMW CCA Member #191509}
(SOLD)
Old 03-04-2013, 12:18 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Bluebee you might to update the complete rear tool kit picture. The current one is missing three tools + warning triangle. I tryed to post link but forum didn't like it.
Old 03-04-2013, 12:45 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Warning triangle was available only on Euro models. You could buy it on line from different parts distributors, but NOT from the BMW dealership.
So Bluebee is correct. The triangle is NOT missing. As well as the other "3" tools.
Check in realoem and you will see the difference.
Old 03-04-2013, 01:06 PM
That picture was from cn90.
However ... I 'would' like to add a larger screwdriver, if that's what's missing.
Here is a picture of 'my' toolkit taken just yesterday.
What am "I" missing?
Old 03-04-2013, 01:25 PM
Ooops. I hadn't seen this response from Doru when I posted prior.
So, my toolkit is complete?
I understood about the warning triangles:
- Where to obtain emergency toolkit warning triangles (1)
But what about the other stuff?
Q: What emergency is the s-shaped allen key useful for?
Q: What is the straight tool in the left of Dhoang's toolkit?
Q: What is that socket in the picture from Dhoang?
Q: Are the only emergency nut sizes 8/10 and 12/13 mm?
Photo from Dhoang.
Old 03-04-2013, 01:28 PM
I tried checking in realoem, but, the darn pictures confuse me to no end.
I just can't make any sense out of this:
- Realoem E39 525i trunk toolkit contents
Old 03-04-2013, 01:40 PM
Mein Auto: E39 540i
Well in bluebee post it stated it I quote "complete rear tool kit". That is not complete tool kit. It's just US spec tool kit.
Spark plug wrench, socket wrench, pin and warning triangle.
Photo from Dhoang.
Q: What emergency is the s-shaped allen key useful for? It is for sunroof.
Q: What is the straight tool in the left of Dhoang's toolkit? The pin for sparkplug and 12mm sockets
Q: What is that socket in the picture from Dhoang? 12mm socket.
Old 03-04-2013, 01:52 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Q: What is the straight tool in the left of Dhoang's toolkit? The pin for sparkplug and 12mm sockets.
Don't forget the other use for it, which is a wheel installation tool. Insert the plastic end into the lug hole on the hub and it helps support and align the wheel with the lug holes.
Any errors in this post are purely Swype's fault, not mine.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 03-04-2013, 04:31 PM
Q: What is the straight tool in the left of Dhoang's toolkit? The pin for sparkplug and 12mm sockets; also used to align wheel lug holes.
Very nice information. It certainly was not intuitive to me what all these things were for.
I'm still a bit confused about the size of one of the sockets ...
The spark plug wrench is clearly a 16mm deep socket (or 5/8", which is the same thing).
The realoem parts lists says it's a "supplement SW16", which I will loosely interpret as "socket wrench 16 mm" (I'm guessing here - but it makes sense).
The additional socket is a "supplement SW10", so, shall I assume it's a 10mm socket and not a 12mm socket?
(If so, I can see it being used for the battery cables in an emergency.)
Old 03-04-2013, 05:23 PM
QSilver7's Avatar
I always laugh to myself when I see the wheel pins that have never been used. I bet 90% of BMW owners have no clue that the "straight" tool can help facilitate mounting your wheels...as well as being the handle for the spark plug tool. And if you have an e38 seven series it's the best tool ever for releasing the fog lights. It's girth & length is perfect for the slot where you're supposed to insert a screwdriver...but the wheel pin works much better...the fog light pops out so fast & easy, many owners wind up picking the light up off the ground because it releases so fast.
Using wheel pin to mount wheel on hub...you can see that my pin gets used...the gray plastic end shows its scars.
Stick pin in empty lug bolt hole, the align & slip pin thru hole in wheel, and slid wheel up onto the hub...the pin helps hold it there until you can start a bolt:
(SOLD)
Old 03-04-2013, 05:43 PM
Nice pictures. I've never seen this 'pin' thing before, and especially not in use.
I had never known that I don't even have the wheel pin; now I know why my wheels are so extremely difficult to get onto the lug bolts!
I'm going to add your picture to the composite above to make the composite below.
A) In addition, it would be nice to have a picture of the sunroof crank in use.
B) And, to get confirmation on the socket size (I don't have that either).
C) And do the warning triangles come with the gray plastic case & velcro straps?
Old 03-05-2013, 03:24 AM
Mein Auto: E39 540i
Good catch, of course it's 10mm. Just a brain fart on my part.
Old 03-05-2013, 11:44 AM
QSilver7's Avatar
Here's an old illustration from my old e32 days on how to manually open the sunroof with the "Z" shaped "winder" tool from the trunk's tool kit. I'm not sure if the e38/e39 has a "clutch" as mentioned in this e32 illustration...but this is one of those processes that is basically the same for most BMWs from across multiple generations and decades:
(images below by: mzmtg/BimForums e36 forum)
(SOLD)
Old 03-05-2013, 12:20 PM
Reefin' Dude Reefin' Dude is offline
Mein Auto: 02 540it
where is the pin located in the touring toolkit? i am pretty sure i have not come across one in my touring in the two places i know of where these tools are housed.
G~
Old 03-05-2013, 04:06 PM
If you have a touring, would you kindly post a picture of your existing toolkit so the team can show you?
EDIT: Thanks QSilver7 for the pictures. I ran a check yesterday but only spent about 15 minutes and couldn't find a picture of it. If we don't find an E39-specific picture, I'll use those.
The point is to give the NEXT person the idea, right off the bat, to start where we left off.
Thanks, as always. You're a saint!
Old 03-06-2013, 11:57 AM
Mein Auto: 02 540it
i will post pics when i can get decent light on the touring. i have found where the pin goes, but the pictures will help. i am missing mine. the pin goes in the toolkit in the rear hatch next to the multi-screwdriver. i figure it would have gone under the load floor with the other wheel changing tools.
G~
Old 03-06-2013, 01:45 PM
That would be great to get an E39-specific look at where it goes.
I would recommend NOT using the word 'PIN' when talking about the "Z winder" because there is a tool already called a "pin" which is for spinning the sockets and lining up wheel lug holes.
On my bimmer, the "pin" (which QSilver7 showed closeup pictures of) is on the left front of the tool shelf, and the sunroof z-winder is on the right side middle of the tool shelf.
Old 03-06-2013, 02:05 PM
Mein Auto: 02 540it
Thank you for trying to clarify, but i am talking about the pin used for aligning the rim to the hub. i did not know this existed, mine was missing. i just had an empty spot next to the multi-screwdriver that looked like something goes in there, but no idea what until this thread.
the toolboxes for the touring are different than the touring. there are two tool boxes. one under the loading floor which holds the tire iron, the jack, the towing hinge, and a spot for holding a lug key. the one located inside the back hatch has the Z winder, the pin, the multi-screwdriver, a place for the triangle, and both open end wrenches.
G~
Old 03-06-2013, 02:11 PM
Oh. I see. I am also missing the wheel alignment "pin".
In my shelf tool tray, I have a large screwdriver insert in its place.
the toolboxes ... are different [for] the touring.
It would be nice to see a photo of the touring toolboxes so we can help others.
Old 03-06-2013, 04:30 PM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
my 2000 528
did not come with spark plug socket & and wheel pin. I was able to purchase better quality wheel pin & folding warning triange. Both fit in empty spaces in tool kit.
Old 03-06-2013, 04:40 PM
retiredat44
Mein Auto: BMW
Question
where did you get the new wheel pin? I think mine is missing...
thanx
BMW 2001 530i (E39)
(Family cars):
Disabled Veteran:
