E90/E91/E92/E93 (2006 - 2013)
Old 03-04-2013, 06:13 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: BMW X3
BMW E90 LCI Rear Indicator Lights
question (my freinds' car)
How do I relace rear LED Indicator light BULB or Panel ? (2009 LCI E90 Model)
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton
NEXT CAR : A PORSCHE
Old 03-04-2013, 09:42 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi Sedan
1. Open trunk.
2. Pry/pop out trunk lining access panel behind light cluster.
3. Remove nuts (8mm IIRC).
4. Remove & disconnect cluster.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 03-04-2013, 10:43 PM
SilverX3's Avatar
Mein Auto: BMW X3
can he buy replacement LED cluster only ???
06 130i
07 320i
08 E92 325i
Old 03-05-2013, 05:45 AM
Zeichen311's Avatar
I think the LED array is integral to the panel. The incandescent lamps are obviously replaceable but if one or more LEDs have quit, I seem to recall reading you need to replace the whole socket panel.
Old 03-05-2013, 06:53 AM
Mein Auto: 2007-335 HTC
nope not replaceable, I just went thru the same thing with my 07 335I, the whole unit has to be replaced, once I replaced it I mangled the old unit to see if it is, and its not, I cut it apart with a cut off wheel just to see what it looked like on the inside, its got a circuit panel board inside too, thats probably what died. I have also noticed that the other lamps, only one seems to be replaceable the rest I could not pull them free of the board to use as spares.
Hondo
Old 03-05-2013, 10:44 AM
SilverX3's Avatar
Mein Auto: BMW X3
Ok... Dealer quoted $300+ for one rear led panel
06 130i
07 320i
08 E92 325i
Old 03-05-2013, 12:52 PM
go thru bmw parts of south atlanta, I savde about 60 buck from what the local BMW place wanted, and I just ordered the upper strut mounts and saved about 60 dollars each on them
Hondo
