E90/E91/E92/E93 (2006 - 2013)
Old 03-04-2013, 07:02 PM
BMWtje BMWtje is offline
Mein Auto: 2010 White 328xi
tire question
I have a 2010 - 328xdrive with 28K miles on the tires. Tire Question: When you need one tire replaced, should you buy replacement tires in pairs to match 2 similar tires either in front or back? Should new one(s) be placed in front or back? Many Thanks for feedback.
Old 03-04-2013, 07:03 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
Pairs & fronts
Old 03-04-2013, 07:28 PM
bear-avhistory bear-avhistory is offline
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
New tires should go on the back & the worn back tires moved to the front. Its counter intuitive but its the best way unless you are running bigger rear tires.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 03-04-2013, 07:50 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
And just to confuse matters further, we replaced two tires on my wife's 328iX and the car drove like crap... Only after we replaced the remaining two tires, did it drive well again... Supposedly there is a limit as to how much of a variance there can be in tire height (front to back) otherwise the DSC gets confused, or something to that effect...
Old 03-04-2013, 08:00 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
New tires should ALWAYS be put on the REAR....NEVER THE FRONT when there are worn tires.
NO tire manufacturer recommends new tires on the front when only two tires are replaced. If only one tire is replaced, it should go on the REAR, mated with the tire of the highest tread depth, but the SAFEST option is to put two NEW tires on the rear.
This has to do with unsafe "oversteer" in WET conditions with worn tires in the rear. If you have any doubts about this...or if your local installers have any ridiculous "wive's tales" that say otherwise, I'll send you about a dozen horrific product liability death cases where "new tires" on the front resulted in deadly accidents. Sorry to be so graphic.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-04-2013, 08:08 PM
pointandgo's Avatar
It makes no difference if you are running "bigger" rear tires. New tires on the rear ALWAYS.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 03-05-2013, 10:32 AM
Excuse me but I have 275X30X19 on the back. They will not fit on the front which has 245X35X19. Neither would the factory stock 255X30X19.
Kevin
Old 03-05-2013, 10:37 AM
Mein Auto: 2007-335 HTC
go for 4 new tires
Old 03-05-2013, 01:17 PM
pointandgo's Avatar
Staggered fitments sometimes pose a problem when the front tires wear out before the rear tires...and the rear tires are still good. This happened on my E92. I wasn't about to put two new tires on the front. These were my original (OE) tires.
After some "negotiations" with the tire manufacturer, all four tires were replaced on a "shared cost" basis.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 03-05-2013, 01:25 PM
Agree, I usually change all 4 if they are close, so far have been OK with that.
Kevin
Old 03-05-2013, 01:53 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi Sedan
Shaving is another option in unusual cases such as this. I once had two wheels and tires destroyed by a road hazard and had the replacements shaved to match the average tread depth of the undamaged pair. The $50 charge for shaving paid for itself a dozen times over.
Originally Posted by Salvator View Post
And just to confuse matters further, we replaced two tires on my wife's 328iX and the car drove like crap. ... Supposedly there is a limit as to how much of a variance there can be in tire height (front to back) otherwise the DSC gets confused, or something to that effect...
You are exactly right; there is nothing supposed about it. It's not just front-to-back difference, either; the rolling radius of all four corners needs to be within tolerance relative to one another (hence my shaving adventure).
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 03-05-2013, 01:57 PM
Thanks for all the great replies. I will go with 2 new tires on the back. The remaining 2 on the front will be at 6/32, so should be good for another year, unless the DSC gets 'confused'.
Old 03-05-2013, 02:26 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Mein Auto: 2009 335i xDrive coupe
The allowable difference in diameters across an AWD system varies by manufacturer. IIRC, Subaru allowed a 2/32" difference in tread depth across the car and VW allowed a 4/32" difference. My wife's old Subie required you to pull a fuse to disable the AWD function if you were running on the T-spare tire, and my daughter's Passat has a full-size spare as a consequence of the above. The tread depth difference bit us when my daughter damaged on tire on a half-worn set of 4 on her 4motion Passat. We replaced one tire and had it shaved through TireRack to be able to get the whole set in spec.
The problem with xDrive cars is that I have never been able to find a BMW specification for the difference allowed. You would think a German manufacturer would want you to know something like that, but no.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 03-05-2013, 02:37 PM
Thanks, I will check with the dealer and perhaps buy 4 new ones......
