Old 03-05-2013, 11:59 AM
jlittle67 jlittle67 is offline
Mein Auto: 2012 328i Sport
60,000 mile service question
Do I need to have it done? What does it entail? How much is it? Is it something I can do myself? Any help would be appreciated.
Old 03-05-2013, 12:10 PM
Banned
Mein Auto: 2007-335 HTC
what is required for 60K miles, if its a air filter, cabin filter and oil change, you can do it yourself,
Old 03-05-2013, 12:32 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Google Mike Miller BMW
Google Mike Miller BMW for the old school maintenance schedule.
You can probably download it with the results of the search
If you have not done it and you are keeping your car long term .
All fluids and filters for 325 and 328 . Spark plugs should have been done
at 45k if you have a 335
The Filters in the Engine bay are easy.
http://www.e90post.com/forums/forumdisplay.php?f=16
There is a DIY and Maintenance Forum in the above link.
Old 03-05-2013, 01:10 PM
floydarogers's Avatar
Pedant and Curmudgeon
As other threads have mentioned, there is *NO* 60K service (like Inspection II in the old days). Pretty much everything is CBS (Condition-Based Service), or is contained as odball exceptions in your "Maintenance And Warranty" booklet/manual.
Given that, some people like to do things the old-fashioned way (re Mike Miller.) For instance, I just passed the 60K mark, and in addition to the oil service that was due, I had the Auto Tranny fluid changed, the diff fluid changed, an alignment done (turned out it really needed it), and the air filter and fuel (diesel every two oil changes) changed. YMMV.
Old 03-05-2013, 02:01 PM
So if the red service light when I start the car is that a CBS indication or is it some sort of scheduled maintenance? Is there a way to tell what CBS issue is setting the light off oil, air filter, etc
Old 03-05-2013, 03:40 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
It is an "Inspection" which is mileage based at every 30,000 miles. It does not include an oil change or any filter changes as they are CBS.
Instead, it involves a scope, a number of electronic, mechanical and visual checks and a road test. It should not cost more than 2 hours labor.
Tom
Old 03-05-2013, 03:41 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Sure.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 03-05-2013, 03:47 PM
Thanks, so just reset it and change filters etc when the CBS icon comes on or sooner?
Old 03-05-2013, 03:50 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
I recommend changing spark plugs because in my case 2 didn't make it to 72000 miles, causing serious misfires.
