E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Oil Pan Removal on the 545
OK the newest oil leak on the 545i is the oil pan. Looks like there is a weld hair line crack where the oil plug screws into. Looks like it is best just to put a new pan in rather than remove and have welded.
Anyone remove the oil pan on the 545i. Looks straight forward I am just hoping that there is no motor mount removal or any subframe hardware. Should I just be able to remove the support pan to gain access and just unbolt the oil pan section. http://www.realoem.com/bmw/thumbs/r/p/128.png |
I believe that the engine has to be lifted to remove/replace the pan. Big job. Remember that oil leaks from above the pan will spread over the oil pan and collect near the drain plug so make sure it's not coming from areas above the pan. The N62 is guaranteed to leak from key areas above the pan. |
This was a "feature" of the N62, it was designed to encourage people to get a 550 and then an F10 550
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers Previous 3 cars (the 550 is my 38th car): 2005 530i - Prem, Sport, NAV 2006 Jeep SRT-8 2003 Infiniti G35 coupe |
I've seen pictures of this being done on a 7 series where they used an engine hoist to hold the engine (BMW has a special tool that mounts to the shock towers that does the same thing), then dropping all of the front suspension/cradle to get at the oil pan.
Doesn't sound like a fun one |
If I was faced with this, and did not have the desire to pay to have the motor pulled, I would try to fill the crack with JB Weld. Let the flaming begin!
'05 545i '06 MB R350 '03 allroad (for sale!) '68 Deville Convertible |
No flaming, if you don't have the time/skill/money to do it properly this could be a quick, albeit temporary solution. Eventually it would need a more permanent remedy.
OK - The results are in... Easy.... The 545i oil pan is in different sections. 1 cast and 1 steel. The drain plug is in the steel section and can be removed by: 1. Put the front on jack stands 2. Remove both forward and rear carriage covers 3. Remove the reinforcement plate - Shiny metal plate that covers oil pan 4. Drain oil - duh 5. Disconnect the oil level sending connection 6. Remove the bolts and leave two in-place to catch the pan as it drops 7. That is it - This was well designed (except for my plug insert ![]() Wow I have 182K miles and the inside of this pan was CLEAN!!. Wiped it out and it was shiny metal clean, wow. I am having the plug thread insert rewelded. Guy has a nice mig and states it will be straight forward. I'll post the outcome tomorrow. |
Cool, good deal, glad it worked out that easy (so far).
