DME Help - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 03-05-2013, 02:55 PM
B1mm3rB B1mm3rB is offline
Mein Auto: 93 318i
DME Help
1992 318i While i have everything apart from taking apart the blower motor figured i should make sure my dme is protected after reading a few nightmare threads about water getting to it before i put everything back together. Where are the drains located that need to be cleaned out? Also where can i purchase the dme insulation and the bottom of the cowl that the wire harness connects to? Both of these are in pretty bad shape, actually the dme insulation crumbled into little bity pieces soon as I touched it to take it off.
Bottom of cowl that wire harness connects to
DME Insulation
Old 03-05-2013, 03:31 PM
Mein Auto: 93 318i
Well i finally managed to find the part number for the dme insulation (51481977110) And found out this insulation ranges from $135-$165 Nooooo way in the world im paying that much for this insulation. Looks like its to the drawing board & making a way to replace this.
The current state of the dme insulation that i removed after seeing those prices and getting it back out the trash...
Old 03-05-2013, 04:10 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Duct Tape and caulk, my friend. Embrace your inner redneck.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
