Old 03-05-2013, 12:08 PM
Robert A Robert A is offline
Mein Auto: BMW 535d
Sqeaky Door Seals
What's the trick for dealing with noisy door seals? I've got a couple of squeaks that I'd like to take care of.
Thanks.
Robert A
BMWCCA Member
Current
2014 535d, M Sport, Space Gray/Mocha Nappa
Prior
2007 530i, White/Black, 6MT
2001 530i, Orient Blue/Beige, 5MT
1994 325is, White/Black 5MT
1984 325e, White/Black 5MT
1983 318i, Delphin/Beige 4MT
Old 03-05-2013, 12:25 PM
RIHI RIHI is offline
Mein Auto: BMW
If it is squeaky as in rubber to metal squeaking, use Leatherique Pristine Clean on the door seals. This will lubricate the seals and stop the squeaking. Armorall also works.
Old 03-05-2013, 12:26 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
The cheapest and easiest way to deal with them is, and I am not kidding here, Vaseline. Just rub some Vaseline down the length of the seals on each door and the squeal will be gone.
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-05-2013, 02:01 PM
Campfamily's Avatar
Campfamily Campfamily is offline
X2 on the Vaseline. Works great.
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 03-05-2013, 03:26 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
Vaseline will attract dirt. Use what BMW uses -- Einszett Gummi Pflege. Works fantastic and leaves no residue. You can purchase it off Amazon for around $8.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 03-05-2013, 04:46 PM
Dishoom Dishoom is offline
+1
However like any coating, you'll have to reapply when the squeaking and creaking return. I don't think there's any permanent fix. Some have mentioned "teflon tape," but even that works for only so long.
2008 BMW 550i M-sport, 6sp SAT, Jet Black/Black Dakota leather, prem, nav
Mods: matte black grilles, 18% tint, GP Thunder 8000k AE, Nanoshield paint protection film, 15mm TMS spacers
Old 03-05-2013, 04:49 PM
Mein Auto: BMW 535d
deleted
Robert A
BMWCCA Member
Current
Prior
Old 03-06-2013, 01:10 PM
mrgrumpy mrgrumpy is offline
Mein Auto: 2005 545i Sport
Agreed!
Do not use silicone spray as that will make them squeak even more.
You can also use Zaino CS which is also great for those roughly painted areas on the underside of the hood/trunk lids and painted areas in the engine compartment. Clean them first before applying the Zaino CS and you'll pickup a nice shine without having to go back and buff it off.
Sounds like you have some chassis flex taking place. Make sure that any torsion frame supports on the underside of the vehicle are present and bolted tightly into place. You'd be amazed how shops will either leave them loose or forget/lose a bolt or two after taking it down for repair access.
Old 03-06-2013, 05:31 PM
10550i 10550i is offline
Mein Auto: 2010 550i M Sport
Thanks DJtoad!!!!! I had the terrible squeaks on all 4 doors. Took your recommendation and went on Amazon and bought the Gummi Pflege. Got it today and applied it to all the door seals. Worked like a charm!!! All squeaks are gone!!! Thanks again!!!
Current Cars:
2010 550i M Sport
2003 Porsche C4S
2008 328i
2007 530i
2004 M3
2001 330i
