No Heat, temperature warning - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > New Member Introductions
Welcome to Bimmerfest! Whether you are a current BMW owner, shopping for a new or used BMW or just interested in cars, we hope you enjoy your visit. Take a moment to introduce yourself and post a picture of your BMW for the rest of the Bimmerfest BMW community to see.
Old 03-05-2013, 05:01 PM
WillRoger WillRoger is offline
Mein Auto: 2008 535xi
2008 535xi CPO- what i have is probably (hopefully) just a classic case of a failed thermostat.
After a couple of minutes of driving, i noticed the air blowing through the vents wasn't getting warmer. shortly after that, i heard the engine fan kick on. another mile and i received a high temperature warning. luckily i was only a few blocks from home. car has 68K miles. can this be more than just a thermostat?
Old 03-05-2013, 05:16 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Sounds more like a low-coolant condition....a T-stat stuck open would give you a "no heat" situation, but no overheating....conversely, the temp gauge would tend to stay down near the blue zone, probably generating a CEL as well.
A T-stat stuck in the CLOSED position would be *immediately* apparent....it would overheat *real*fast, and you would be able to bleed off some of the excess heat by running the heater on full blast.
The road goes ever onward....
(R.I.P. Jever)
Old 03-05-2013, 05:32 PM
Thanks Bob,
i'm taking her in tomorrow for service.
ditto on Wounded Warrior
Klamalama Klamalama is offline
Mein Auto: 330i, C230K, 3.2CLS-6
My educated guess is that you've lost all your coolant from a substantial radiator leak. Mine split at the crimp between the aluminum and plastic. Same symptoms. Open the coolant reservoir cap and you'll see zero coolant. Pour water into the radiator and watch it leak out. You're getting no heat because there is no coolant.
[SIGPIC]
Capo di tutti capi.
