E36 (1991 - 1999)
Old 01-23-2013, 09:40 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
From High River, I'd try giving Sheni of Sheni's Auto Trend in Calgary a call. See if he'll recommend anyone.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.”
- Hunter S. Thompson,
Old 01-28-2013, 04:55 PM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inde Fatherland 325
A little airbrushing for my buddy's 7.3 L powerstroke
Sent from my SGH-T989D using Bimmer App
My wheel bolts require more torque than your Honda makes...
see my progress
http://www.bimmerfest.com/forums/sho...040&highlight=
Old 01-28-2013, 05:42 PM
hunter94 hunter94 is offline
Mein Auto: 1993 BMW 325I
Your car is coming along really nice. So from what I read you are doing an engine swap from a non-vanos to a vanos engine? And you plan on rebuilding the non-vanos engine? If so I'd love to see pictures of the swap and engine rebuild.
Old 01-28-2013, 05:53 PM
jonesin's Avatar
The Canadian Prick.
Did you give Sheni a call?
Old 01-28-2013, 07:47 PM
jkmeisl's Avatar
Josh
Im going to be just replacing the head gasket on the m50 which is in the car now and installing a 30mm eibach
front sway bar and 26mm rear sway bar, xbrace and a 3.93 Limited slip diff. And calling it good for the summer.
I will rebuild the m52 and do the obd1 swap eventually but not right now. I dont have the money time or space to do it the way i want to so im just going to wait till i do. But dont worry i will document my head gasket replacement and all other work i do to the car.
No, i think im going to drop by his shop tomorrow and talk to him in person if posable
see my progress
Old 01-28-2013, 08:27 PM
Alright cool I'm very interested to see how every thing plays out. I bought a 93 325i knowing there was coolant in the oil. I pulled the head off and the gasket was a little beat up but no signs of it being blown. I ended up taking the head to a machine shop to get it pressure tested and the guy I took it to found a couple cracks in between an oil journal and a water jacket. So I ended up replacing the head, luckily I found one at a junk yard and picked it up for about 140 bucks. And to my knowledge the head was recently rebuilt. So I would make sure to get that head checked out if you hadn't already planned on it.
Old 02-11-2013, 01:38 PM
jkmeisl's Avatar
Josh
ha
see my progress
Old 02-26-2013, 01:05 PM
jkmeisl's Avatar
Josh
Finally saved up enough to order my M3 Rotors, pads, sensors and caliper rebuild kits.
also ordered a head gasket set and head bolts for the M50. so I'll be rebuilding the head soon
see my progress
Old 02-26-2013, 01:08 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by SCJon View Post
Jared is king of ambiguous comments.
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 02-27-2013, 02:16 PM
jkmeisl's Avatar
Josh
way to excited to get these on
ID:	364141   Click image for larger version
see my progress
Old 02-27-2013, 02:17 PM
petriej's Avatar
What bike is that in the background of pic1?
GGC BMW CCA #443004
Join the BMW CCA!
Old 02-27-2013, 04:30 PM
jkmeisl's Avatar
Josh
Its my brother in laws 83 suzuki gs850L. Pretty nice bike he wants me to buy it but i would rather spend 1200 on my e36
see my progress
Old 03-05-2013, 03:05 PM
jkmeisl's Avatar
Josh
Sprayed the caliper Semi Gloss Black before I rebuild it. just couldnt wait for it to dry haha. big improvement on the brakes. $1000 in I hope they make a bit of a difference
ID:	364917   Click image for larger version
see my progress
Old 03-05-2013, 05:07 PM
Looking good. It would be saweeeet if you painted the m and stripes with m colors.
Old 03-05-2013, 05:18 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Nice. I have new front calipers sitting in boxes that I've been wanting to paint silver or black so they don't become discolored with use. Probably won't get around to it until I replace the rotors and lines, and will do the rear at the same time.
1998 BMW 328is
1966 Pontiac GTO
Old 03-05-2013, 08:53 PM
jkmeisl's Avatar
Josh
Ya i just ordered just about every brake part i could new. I have new steel braided lines new caliper seals new springs new bushings new rotors pads and all that.
Not sure about the ///M dont think i will paint the colors on there just to keep it more stealthy and stock. Dont really want to ///M it out to much you know...
see my progress
Old 03-05-2013, 10:08 PM
Makes sense.
Old 03-08-2013, 07:08 PM
jkmeisl's Avatar
Josh
Got a few little updates. a few more brake parts showed up. got my E-Brake shoes(waiting for spring kit) my front caliper seals(waiting for hardware kit) my rear Caliper Hardware kit(spring, bushings and caps) now all I need is the rear caliper seal kit...
I went to take apart the right front caliper and the PO snapped the bleeder valve screw in the caliper... Great. so eventually found my screw extractor and got it out after bout half an hour.
snagged a new bleeder screw from the old 328(RIP) so now I'll just wait for the rest of my parts. all from Rock Auto. so far they most has shown up in a week. so not to bad
also ripped into my 2.93 Open Diff. and ripped out the gutts. My LSD 3.92 is ready for the swap. apparently any ol. transmission shop an swap the gears for me so I'll start shopping around after I swap the ZF 5 speed.
anyways heres a few pics
ID:	365439   Click image for larger version
ID:	365440   Click image for larger version
ID:	365441   Click image for larger version
ID:	365442   Click image for larger version
see my progress
Old 03-08-2013, 07:09 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: 1995 318is
3.92?? I really don't think you're gonna like that ratio.
-CJ
Old 03-08-2013, 08:22 PM
jkmeisl's Avatar
Josh
Im going to match it with a autotragic for now. Like a said i will swap the gearing to 2.93 before i drop in the 5 speed
see my progress
Old 03-08-2013, 08:34 PM
cj.surr's Avatar
some kid
Oh, that makes sense. How come you're not doing the ZF swap now?
-CJ
Old 03-10-2013, 08:42 AM
jkmeisl's Avatar
Josh
I'm laZy and I want to have new bushings and links before I install. I'm just focusing on brakes and engine right now. Not in any real rush
see my progress
Old 03-13-2013, 12:51 PM
jkmeisl's Avatar
Josh
head gasket kit and new head bolts are in. anything else I should buy before I get in over my head?
see my progress
Old 03-13-2013, 12:59 PM
petriej's Avatar
Boost!
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-14-2013, 07:15 AM
jkmeisl's Avatar
Josh
boost!
nooooo
see my progress
