E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
KW V2, CKS, or PSS10's
I'm debating on which CO's to go with since all three are close in price. This will be my DD, about 80 miles RT for work, and I don't plan on tracking or autoX. I do like taking corners quick and I don't mind taking the long way home if there's a lot of curvy roads.
2009 AW 535i -Sport, Premium Package, and Comfort Access -20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs. |
I'm also looking at the KW V2's coming off my current setup of H&R Sport with Koni's.
lots of good reviews on the KW's... |
KW's streetcomfort are the closest to stock sports, V2 are harder which puts them about equal to the CKS. The difference is you cannot find new KW V2 for the price of CKS new, used yes. I would never buy used suspension or brake components, just me. The Bilsteins are good, but more like stock. I prefer coilover systems like the CKS if only because you can adjust the ride height without affecting the spring rate, that is HUGE for eliminating bounce. I had KSport on my previous car, loved them - especially considering I could change my ride height over lunch. Of the systems you listed, and what I plan on for my 550, I would choose the CKS. They are price of used KWs, slightly less than new Bilsteins, and more comfortable than the KSports I used to have.
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers Previous 3 cars (the 550 is my 38th car): 2005 530i - Prem, Sport, NAV 2006 Jeep SRT-8 2003 Infiniti G35 coupe |
I also considered CKS - like the ride height adjustment without affecting the springs.
I know Trinity has them for $1650. + What about the Swift spring upgrade? worth it you think? |
If your going to get them then get the swift spring upgrade.
I have KW Street Comforts on my 545i. I wanted something a bit softer so this kit works perfect for me. I drive a LOT on the weekends in the mountains and have a lot of fun with the car.
Kris General Manager www.thesuspensionsource.com (888) 230-1288 (559) 790-3287 (text) Like us on FaceBook for 10% Off
You will be happy with the V2s. The spring rate is a bit different between the Street Comfort and V2s but overall the same adjustments. Can't wait to see yours closer to the pavement!
with ur new kw's ,, do u feel less body roll on turns,, and also is the steering sharper now goen into the turns ?,, and also do u feel any difference as far as less understeer, and do u feel more over steer because of it ?
This is one of the best upgrades I've done so far. The car handles much better and the KW V2 matches well with our ARS to minimize the roll which is significantly better then the sports suspension. The handling and turning is definitely more precise when making sudden turns. Also when taking corners and freeway ramp loops the car feels more planted to the road and stable. I actually had to even tighten my side bolsters to help keep me in the seat when cornering. The only issue I've had is clearance between the tire and CO's. It's a tight fit since I'm running a 9x20 et 18 wheel with a 255/30r20 tire. I had to use a 5mm spacer to make my tire clear the CO and roll my front fenders since i lowered it another 3/4". Now there's no rubbing at all.
Ya, I was hoping that I would clear the CO but it is very tight up front. At least I only needed a 5 mm spacer and I haven't had any issues with wheel vibrations.
I ended up using front and rear spacers to make the wheels more flush. Didn't have to roll by fenders though.
Now that I have had the v2's for 2 weeks with about 700 miles, I've noticed at low speeds the front passenger suspension is making noise. It was only recently that it started to make noise, like some metal piece is loose. I jacked up the car and checked for loose parts but seems like everything is tight and nothing is loose. Was wondering if you might have some troubleshooting suggestions since I hate rattles. Btw the car handles fine and drives normally.
Thanks.
2004 545iA, Titansilber Metallic/Black Dakota, Sport, Premium & Cold Weather Packages, Navigation, Premium Sound, Logic 7, HL Washers, Active Steering/Suspension, PDC, Adaptive Bi-Xenon,Voice Command, Beltronics STiR +, 58% Full Tint, Smoked Side Markers, 19" Hyper Silver Avant Garde M359/Michelin PSS, M5 Trunk Finisher & iDrive Controller, Dinan Performance Mods: High Flow Intake & Throttle Body, S3 Engine Software, S1 Suspension, CF Front Strut Brace and High Flow Exhaust |
I was thinking of doing that tonite, not sure of the shop did that during the install. Is the torque spec for the three bolts for the top hat 25ftlbs?
http://www.kw-store.com/extras/docs/...ah68620005.pdf
Page 8 talks about the ft lbs required.
Should be 25 ft-lbs - 34Nm
LED Angel Eyes - GP Thunder 7500 9006 Fogs - Matte Black Grills - Tinted Side Markers - LED Interior - Cusco Front Strut Bar - M5 Rear Sway Bar - H&R Sport Springs/Koni FSD - AFE Drop-In - JB4 G5 ISO - M-Style Kit - LI - Escort 9500ix - M5 166 Rims - Hankook V12 - 19"- 245/35 - 275/30 |
Nothing like finding the problem and fixing it!
