E36 (1991 - 1999)
Old 03-06-2013, 06:39 AM
cindyluwho cindyluwho is offline
Mein Auto: 1998 BMW 323ic
Exclamation Automatic convertible top problems
I have a 1998 323ic (convertible) So at first it would only raise the front portion and then made a clicking noise in the back. power top switch red light blinking continuously now the light isn't blinking and nothing happens when i push the top down button. the motors are disengaged the bar war taken off the tonoue motor and wont line back up I was told they had to disengage the bar to lower the front closed. Im not sure where to start, Help! Please!
I need a new top installed but can't install without the top being operational. is it a fuse or the switch I need to address first? and then at somepoint cant I reset the motors with the top in up position? Can I lower the top manually and then reset and or get new top installed? ... and yes the emergency bar under the back seat has been pulled with the top in up position,,, urgh
Old 03-06-2013, 09:01 AM
hornhospital's Avatar
D'oh, You Kids!
Did you read this thread?:
http://www.bimmerfest.com/forums/sho...d.php?t=639047
Quotes to live by:
BMW-CCA #441426
Old 03-06-2013, 10:12 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Way to go Ken.
OP: Check out the docs posted in the Origami problems thread. That should help clear things up. If you're getting a brand new top installed, I'd just have someone tear off the old one.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
