E36 (1991 - 1999)
Old 03-06-2013, 10:03 AM
BiGPaPaRu's Avatar
BiGPaPaRu BiGPaPaRu is offline
Unstoppable
Mein Auto: 2008 328XI
Brake lights
Hey guys,
My brake lights do not work but the one in the middle or the third light still works.
I did some research but it seems everything I find is either someone who installed aftermarket tails or did something to cause their problems. But from what I gather it is most likely the brake light switch. Can anyone shed some light on this for me. Thanks all and good day.
Sent from my PG86100 using Bimmer App
Thank you god for putting BMW on this planet.
Old 03-06-2013, 12:54 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
If one of the three works, it is most likely the wiring bundle going into the trunk. Slit it open carefully and patch the broken and frayed wires.
Sent from my U8651T using Bimmer App
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-06-2013, 01:21 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Did this come about suddenly, or do you suspect it has been this way for a long time? If your car has the check control feature, have you been getting any fault messages? And since your 3rd brake light works, I don't think it's your brake light switch.
Of course, the first thing to do is check all of the connections (harness plug into each taillight, and each bulb socket).
1998 BMW 328is
1966 Pontiac GTO
Old 03-06-2013, 02:00 PM
BiGPaPaRu's Avatar
Unstoppable
This was sudden. And I figured it couldn't be the switch cause the third light worked. All the lights work it is only when you use the brake that the second filaments aren't working. I have tooken it apart and things look ok but I will go through if again. I have not looked at the wiring but bulbs and fuses are good.
