E36 M3 (1995-1999)
Old 03-01-2013, 07:41 AM
E36squad E36squad is offline
E36squad
Mein Auto: E36 m3
Question "Floatiness" in handling when driving at higher speeds
Hey guys, so lately with my steering in my 98 e36 m3 there's been some feel of "floating" at higher speeds. I was wondering if you guys knew what that could be or if you guys have ever experiences that before!! Thanks
Old 03-01-2013, 09:44 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Could you be more descriptive? It might just be normal.
Does the steering system make weird noises? Might be low on fluid (and you might have a leak). I'd try flushing it.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 03-01-2013, 11:23 AM
E36squad
Mein Auto: E36 m3
No it does t make noises or anything. It just feels like your floating at high speeds..like the tired startup float off the floor
E36squad
Mein Auto: E36 m3
Somewhat like when you hydroplane
Old 03-01-2013, 11:25 AM
petriej's Avatar
That is very odd. Like maybe your aerodynamics are changing? It could be normal... How fast are we talking? 100+?
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-01-2013, 03:52 PM
E36squad
Mein Auto: E36 m3
No I'm going only like 70
Old 03-01-2013, 07:24 PM
yonsayvitch yonsayvitch is offline
Mein Auto: 740il,99M3
What are your tire pressures and does it happen on all road conditions?
Old 03-01-2013, 08:16 PM
Adamo99 Adamo99 is offline
Mein Auto: e39 530i, e93 335i
Check your front control arms, bushings, and RTABs.
Old 03-01-2013, 10:53 PM
E36squad
Mein Auto: E36 m3
Yea it happens on all roads and I just changed my bushings...the car just got aligned so I'm not sure
Old 03-02-2013, 04:31 AM
How long have you had the M3? Do you know the history, any accidents? Definitely check the alignment. Camber might be off. It could just be the tires age or condition. This is not a normal thing like it would be on big old american cars.
Old 03-02-2013, 09:47 PM
E36squad
Mein Auto: E36 m3
I've had the car for 3 years and now accidents one owner and the tired are brand new...they just did alignment for me
Old 03-06-2013, 11:50 PM
MCXL MCXL is offline
Mein Auto: 1996 M3
Bad alignment then, have them recheck it.
Old 03-25-2013, 08:47 PM
EE05063 EE05063 is offline
Mein Auto: M3
Power steering rack moving about might make the entire front end feel like it is washing out at once?
Tie rods, ball joints, and so on unless both sides suddenly went out at once, not likely would do other things. But the rack is what centrally ties those tie rods together.
Also the rear trailing arm bushings or even the rear subframe to body rubber mounts would let the rear end track a little off center from the front, causing a similar feeling.
Get it going straight and at neutral throttle on flat ground, see if the car shifts left or right when you apply throttle or let off all at once. That is likely something in the rear suspension IMO.
Old 04-04-2013, 02:06 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Shocks/struts are another thing to check. How many miles on them?
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
