Old 03-04-2013, 09:30 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Oil Change Interval vs. Need for Valve Blasting
As most of us are well aware by now, Direct Injection engines are prone to developing crud accumulations on the backs of the intake valves and the surrounding area in the head. Unfortunately many of us have had to have our engines partially disassembled and 'walnut shell blasted' or used other abrasive means to remove the deposits.
Several causes for this problem have been extensively discussed. It seems the deposits are the result of condensed crankcase blow-by gasses which are not dissolved by gasoline. Gasoline no longer runs through the intake area of a direct injected engine.
I have a theory that those with longer oil change intervals may be more likely to develop deposits than those with shorter intervals. This poll will help me further explore that possibility. It is decidedly unscientific, and overly broad, but will help me decide if further research is warranted. Probably its biggest faults are that it doesn't control for driving style and mileage. Regardless, it's a start.
If you have been using Techron or any other fuel system additive respond as if you did not.
Please select one condition most applicable to you:
EDIT: SORRY, WHEN I WENT TO POST THE POLL I GOT A MESSAGE SAYING I HAD ONLY TEN MINUTES TO MAKE UP THE POLL. BY THE TIME I GOT IT DONE I WAS OVER THE LIMIT. WILL TRY AGAIN LATER!
Old 03-04-2013, 07:44 PM
Thunder Dump's Avatar
Thunder Dump Thunder Dump is offline
Tastes like chicken
Mein Auto: '09 328i E93 SGM/CR
Poll fail.
Old 03-04-2013, 07:58 PM
tturedraider's Avatar
Freedom isn't free!!
Voice of that experience - prepare the poll in a Word document ahead of time, then cut and past.
www.bmwcca.org
Old 03-04-2013, 08:39 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
DSX - good concept. Better luck setting up the poll.
Old 03-04-2013, 08:49 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
mine only had it done once at 137,000 miles. I change oil like i change my undies. When they can walk to the basket...
Just kidding every 8,000 miles
If you like customer service. Don't look beyond a BMW.
Old 03-04-2013, 09:10 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Mine is mixed-mode. For the first 3 years I went full factory intervals, then I switched to 7500 miles (or sometimes less) between changes afterward. My valve problems likely showed up around 60k miles.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 03-05-2013, 06:08 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
I bought the car with 15k miles on in, right after the original owner had the oil changed according to the BMW maintenance schedule. Since then I've changed the oil every 5k miles, 3 times now. At the moment my car has 32k miles. I am planning to keep changing the oil every 5k miles. As far as valve cleaning goes, it will be done at 50k miles or when I begin to feel the usual symptoms of carbon buildup, whichever comes first.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 03-05-2013, 06:15 AM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
My Little Pony
Old 03-05-2013, 06:32 AM
AnotherGeezer's Avatar
Entwicklung 39
Mein Auto: 2003 530i/5
I'll expect this poll as soon as I see DSX's pictures from CTC4
Old 03-05-2013, 10:59 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Ouch.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-05-2013, 11:07 AM
Banned
Mein Auto: 2007-335 HTC
it would be nice to see pics of what they look like at 30K miles
I plan on changing oil every 7500 miles or 6 months, I got my 07 335 HTC in nov last year and put 1000 miles on it to date, its my weekend car,
my 4runner is my travel vehicle when I call on customers
Hondo
Old 03-05-2013, 01:03 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
7500k for me bro and you saw mine I also didn't start mods till right before WB. So 99% of those deposits were probably stock
Old 03-05-2013, 01:06 PM
galahad05's Avatar
Better with Butter
What about boosted vs stock? I can't believe that this wouldn't be a factor as well.
-- Irish Proverb
Old 03-05-2013, 01:15 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Could be, I know with higher PSI you want to change plugs @ 25-30K intervals to prevent misfires. Don't have enough mileage for poll.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-05-2013, 01:23 PM
galahad05's Avatar
Better with Butter
So maybe DSX's (eventual) poll should be limited to people who are completely stock. This to help eliminate extra variables. Either that or perform Statistical DoE (Design of Experiments).
-- Irish Proverb
Old 03-05-2013, 05:06 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
I think if there is a poll a better reflection of users would be those that:
drive the car hard all the time
drive the car hard part of the time
don't drive the car hard
oil changes per CBS
oil changes approximately 7500 miles
modded car
stock car
It is known that you get blow by under vacuum but how much is unknown (BMWs PVC valve don't seal completely) and blow by under boost.
For me my answers would be
change oil every 7500 miles
slight mod (JB+)
I am sure we can work this out but do think a more comprehensive poll would help since there are more variables than just one or so. That would give us all a lot more information to see if there is a trend...
Old 03-06-2013, 02:29 PM
Psi 5 Psi 5 is offline
Mein Auto: 2007 E90 335
Quite the coincidence. Just got back from a dealer service yesterday and they mentioned the carbon blasting (@ $750) to me. First I have ever heard of it so I checked the forum and there it was, right at the top. In my SAs defense, he said that the blasting and fuel induction service were optional and that they had no indication they were necessary at this time. Rather, he said, they were indicated by time and mileage (2007 E90 335 w/ 70k miles).
So, the question is, how will I know if I need this? What are the symptoms of carbon build-up? As far as I can tell, the car is running the same as it was when I got it three years and 40k miles ago. Could be a gradual thing that I haven't noticed or just not a problem.
Old 03-06-2013, 02:38 PM
If these two threads don't make you want to do it. Nobody can really help you
http://www.bimmerfest.com/forums/sho...d.php?t=678670
http://www.bimmerfest.com/forums/sho...530&highlight=
Old 03-06-2013, 03:31 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Originally Posted by Zeichen311 View Post
Ouch.
He must have been walking around with a fake camera, fooling us all into thinking that he was taking pictures. I do remember him springing up the rock, above the Mt Washington parking area, not unlike his favorite barn yard animal, to take said pictures.
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 03-06-2013, 07:09 PM
pointandgo's Avatar
My post makes 19 replies and 470 views for a failed "poll" thread. Not bad.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-07-2013, 08:55 AM
Saw both these threads before posting and they are certainly compelling. That said, it doesn't answer the question of how you would know if your engine looks like this or what impact it has if it does. Or is the argument that every single 335 looks like this whether you have pictures or not? And what is the practical risk of doing nothing about it?
The comparison for me is engine oil sludge from which my E39 540 suffered. The dealer and one indy wanted to thoroughly clean it out (for some outrageous amount of money). My trusted indy said not to worry about it unless I actually noticed some performance decrement. I didn't and the car worked wonderfully for 100k+ miles after the dealer's diagnosis.
Old 03-07-2013, 09:04 AM
galahad05's Avatar
Better with Butter
You don't have to do anything unless you see symptoms--hesitation, misfires, noticeable performance degradation (typically high load low rpm), or progressively worsening gas mileage.
-- Irish Proverb
Old 03-07-2013, 09:42 AM
I only noticed some light rumbles at idle I didn't care for + I'd known about the issue. Frankly $450-750 isn't that much to let princess feel as pretty on the inside as she looks on the outside People have different priorities and we've seen plenty of cars go 100K without it, I just wouldn't add undo stress for that small amount of money.
Old 03-07-2013, 10:23 AM
Thanks - that is helpful. I'll ask my indy about it next time I need service. My car will go out of the CPO warranty and extended service in a few weeks so that's it for the dealer!
Old 03-07-2013, 01:28 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I may try this in a couple of years, perhaps at the same time as spark plugs, and I'll keep an eye out for any developments in OCC designs in the meanwhile. I'll also cross my fingers in hopes that more indys will acquire walnut shell blasting capability by that time.
