E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#26
Or better yet, why not just run the car at operating temperature, drain everything out, run water into the system (while the T-stat is open), then just keep draining as needed until the water is clean? I figure I can flush with Water Wetter as well, since I got tons of this stuff at home. Last edited by hnaz; 03-06-2013 at 02:06 PM. |
#27
Water Wetter! Nice.
I'd make my own. Take the bolt out and take it to a hardware store, try to find a brass or other heat friendly pipe fitting that you can clamp a rubber hose onto. Taking the bolt out will make a mess, though, so maybe do it outside on the grass. Except you likely have a foot of snow outside right now ![]() I'd be wary of running the car with the engine block drain off. I've run the engine with the expansion tank open and the bleeder screw open, but never for more than a minute.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
#28
Whatever you choose to do, good luck an I hope it works out. Can't wait to see the outcome.
#29
I am just shocked that this car has not overheated. And yes, it does blow full heat to boot. ![]() Here is the bleed method I like and use on my cars. It's what my dad taught me when bleeding air out of cooling systems: As the person says in the video, when you see bubbles coming out of the bleed screw area, screw it down and watch the water going into the expansion tank. He has the expansion tank cap open for pretty much a while to make sure the air is out of the system. But this is later on. |
#30
Bingo. Do that.
#31
#32
Huh, check this out... I see VOB is the culprit to the green coolant they put in the car. Apparently you have to request the service department to use the BMW coolant. What sacks of ****. Un-freakin-believable... I seriously gotta flush the engine out now.
Check out this link, the guy is local to me: http://www.unofficialbmw.com/e36/eng...nt_change.html The whole procedure makes the trip to the dealer like an inconvenience. VOB stealer quoted me $200 for a radiator flush and brake flush. The VOB stealer rep (when asked) revealed the fact the dealerships use the cheap stuff AND NOT THE BMW fluid (customer has to specifically request it and pay for it). Considering I would be w/o a car (and $200) for a day (well the $200 would be gone for ever). As far as a good article to bleed your coolant, I found it on Pelican and Bimmerforums.com http://www.pelicanparts.com/bmw/tech...lant-Flush.htm http://forums.bimmerforums.com/forum....php?t=1073044 I figure with the drain plug off of the engine block, I am just going to run the garden hose through the radiator and just drain the system once and for all. Since now that I found out that VOB, the bastards that had been dealing with the 325is M-Tech with the first and previous owners were using cheap coolant, I am worried for the head gasket. Again, I didn't see any oil drops or milky sludge in the valve cover area or in the expansion tank and the car was not overheating. But now I am thinking about replacing the water pump and thermostat as well, just in case they are chewed to bits from the cheap coolant. I wish I had a bigger garage. This is really ticking me off that I can't help this poor baby out. It's suffered long enough. |
#33
I honestly wouldn't even bother with the drain plug on the block. I've flushed it almost exactly like you're talking about and that works quite well. I pulled the Tstat housing off and tossed the tstat, reinstalled the empty housing, and ran it through like that.
I wouldn't want to get it hot enough to open the stat and then shock it with a bunch of 40*F water. I'd think that would be very stressful on the block. Any errors in this post are purely Swype's fault, not mine.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
#34
Ninja edit! Came to comment on VA being the most awesome state.
![]() Just flush it all and use good BMW coolant with distilled water. You should be fine.
#36
What distilled water do you like? Deer Park? Giant? Harris Teeter? Uncle John's Darn Good Piss Water?
#37
Well the good stuff isn't really for consumption. The stuff I like is safeway brand (because who cares?) for mixing with baby formula. You generally do NOT want to drink DI (de ionized) water by itself. It shocks the body and you'll get crazy sick, but it's great for infants to mix with formula. So I have a couple of jugs in my garage. Friends always ask about the baby water, since its label is pink and has a baby on it.
I think you could find it at Bloom or Kroger, you East Coaster!
#38
Ah, but there are Safeways in MD. I've seen them. They have Utz brand crab chips in them. We don't have Utz or crab chips.
"It doesn't do any good for me to know more than you if you aren't going to listen to me" |
#39
Wow I didn't know Safeway was that far out east. Cool!
#40
We have Publix which is the same level but Harris Teeeter is the really nice one. HT actually has a sushi chef. I hate sushi though. Sorry Harry, I'll stop the hijack now.
#41
HT is awesome. Why don't you like sushi? I love sushi.
#42
I loooooooove sushi.
And FYI California Rolls are not considered real sushi. I know because I have a Korean friend, who has a Chinese gf who's ex-bf was Samoan, his mom was Philippine so they pretty much know the Japanese Culture!
97 M3, KW V2 C/O, shark injected, SS Headers, AA Exhaust, Apex Arc8s, Daily Driven, POS, Slammed! |
#43
Yea I had sushi with some east coast friends in Vegas and they were all gaga over "eatin' sushi in Vegas!"
They were hesitant to even try their california rolls. Meanwhile I'm getting nigiri and sashimi saba, hamachi, tako, ebi, etc. etc. I didn't have the heart to tell them their imitation crab meat is so far from real sushi they shouldn't even call it that. Who am I to put them down?
#44
Lol, my brothers did the same thing. I'm just enjoying raw tuna and salmon and when I said try the California roll, they almost turned green!
One time I made a mistake by eating next day Sushi, I remember being drunk and seeing the nice rolls there, totally forgot that they had been in the house for 4 hours at room temperature and someone through them in the fridge for another 10 hours or so. Being the drunken idiot, showed all my friends how a hardcore raw fish eating m'fer I was! Well within 3 hours I was sober peeing from my anus and puking at the same time, slept in the bath tub naked!!!
#45
#46
![]() It's the texture of sushi BTW, just don't like the raw aspect. I don't like rare steak either. Medium well is my choice, but I don't like most seafood, except shellfish. I do like crabs, lobster, and shrimp. Especially Maryland crabs. It's like a religion to them. That should lead right back to Harry in Maryland. So how goes it Harry, has it been flushed yet?
#47
I'm always down for Sushi!
#48
Much of what we get here at Americanized places isn't sushi at all. California roll = no seafood at all.
![]() I'm not a huge fan of rolls since they're so unpredictable, but give me some sashimi and I can pack down a couple hundred worth of that. Any errors in this post are purely Swype's fault, not mine.
#49
I'm going have to just bleed the car with the new thermostat in, add some distilled water in, and drive down (carefully) to the DIY garage in VA and just do it there. Believe me, it kills me that this crud is still in there, but I am cursed with no garage space. My only worry is how bad electrolysis has damaged the radiator, thermostat, water pump, engine block, and head gasket. If all goes to ****, I will have to buy another engine. No two ways about it. ![]()
#50
