E36 (1991 - 1999)
Old 03-06-2013, 02:55 PM
poorkidmikey36 poorkidmikey36 is offline
Mein Auto: 98 E36
Question Problems starting!!!
Hey, i have a 98 328i and having trouble. So this morning i went to the store(3 blocks away). Got back in the car, turned the key and only got a fast clicking sound. Then every turn after that got no sound but the cluster lights and gauges going crazy. any suggestions on what that might be?
Old 03-06-2013, 02:59 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Dead battery, or bad battery connection.
1998 BMW 328is
1966 Pontiac GTO
Old 03-06-2013, 03:02 PM
Woody Woody is offline
Mein Auto: 2004 X3 2.5
Did you try and jump start it?
Woody
BMW CCA Member
Old 03-06-2013, 04:15 PM
Mein Auto: 98 E36
tried jumping it, nothing. just had my battery tested and it says its at 10.9v, guess i need to be at 12v to start. thank you guys.
Old 03-06-2013, 04:19 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
It should be closer to 13V to start. Even 12V is a low battery.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-06-2013, 04:25 PM
BMWZ4RIDER BMWZ4RIDER is offline
Z4 35i Rider
Mein Auto: 2009 Z4 35i
A good battery will read a constant 12.4 volts under standard testing.
Anything below 12 volts indicates a bad cell in the battery.
10.9 volts is as good as dead.
2009 BMW Z4 35i/Space Gray Metallic/7 Speed DCT/Premium,Cold Weather & Premium Sound Packages/Nav/Comfort Access/Ash Grain Interior & Dash Kit/AntiTheft/SportWheel/PDC/WindDeflector/Black Kansas Leather/Smoked Reflectors, Side Markers & 3rd Brake Light/Ferrari Red Brake Calipers/Clear Front Mask/Gloss Black Grill Inserts/6000K LED Lighting/De-Badged/Aluminum Pedal Set/Real Carbon Fiber BMW Door Sills/CF Wrapped Engine Compartment Roundels,F Lower Grills & Center Wheel Caps.
Old 03-07-2013, 05:45 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
^^ 12.6 volts is a fully charged battery. Battery should be able to hold a load half of its CCA rating at or above 10v for 15 continuous seconds. 12.4 is nothing to be of concern other than low state of charge, anything less than 12 after charge can almost be sure its got a bad cell or two
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
electrical, problem, problems, starting, trouble
