E36 (1991 - 1999)
#26
Except the straight answer bit, but even that is not a sentence.
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
#27
Anyway, divide it by 3600 and you'll get Amp-hours.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
#28
It's an enigma,wrapped in a riddle kind of like what you see below this line. Quote:
"It doesn't do any good for me to know more than you if you aren't going to listen to me" Last edited by SCJon; 03-08-2013 at 07:22 AM. |
#29
Yes.
#30
"It doesn't do any good for me to know more than you if you aren't going to listen to me" |
#31
Re: 95 m3 wiring harness
And as for your question, I'm not sure i really understand but the car that it came from had asc so i don't think you'll lose it Sent from my SPH-D710 using Bimmer EDIT: Ok i logged on from the PC and it looks like an EGR class just took place
#32
So, now that we've finished the hazing and you've survived, let's see if we can get your problem fixed.
From your description of the hard starting where you state it "kicks and kicks" if you mean that it's trying to catch and fires a time or two and then spins and then fires a time or two and then spins, that sound more like fuel starvation to me. If you've got a wiring issue (an intermittent open) you're going to get the engine spinning by the starter with nothing happening, or you're going to get a start up typically. I'd be first checking the fuel system to ensure that you've got pressure at the fuel rail that feeds the injectors. If it's low or zero then it could be the fuel pump, the fuel pressure regulator, or a simple thing to change, the fuel filter. Seems you've been down the path of throwing parts and $$$ at this car, let's work on really getting it correctly troubleshot and then correctly fixed. If you'll try to be very detailed and descriptive in the symptoms (correct punctuation and grammar counts in this sub forum) we'll try to walk you through the troubleshooting steps to figure out what's really wrong.
#33
Then check your cam and crank position sensors. If they're malfunctioning, it can prevent spark and fuel.
#34
With all the work done on it, I would also take a peek at all the electrical connections as well. Anything could be unplugged at this point.
#35
For the wherefore as to requiring correct grammar and punctuation:
There is a HUGE difference between 'helping your Uncle Jack off a horse', and helping your uncle jack off a horse.
#36
Here are some vids i found on youtube on how to perform fuel related tests
http://www.bimmerfest.com/forums/sho...9&postcount=11
