E36 (1991 - 1999)
Old 03-07-2013, 11:09 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Originally Posted by Airborne95m3 View Post
Guys correct me if I'm wrong but if I get/use a 94 325i harness I would lose traction control and what else if anything?? I don't have to worry about the EWS because I'm running red label 413. Help a guy out. A brief history I bought my M july5 2011from Corpus Christi.. 3 days later I money shifted... I had a roommate you Owen a bimmer shop I gave him for a motor and he burned me their went 2k... Feb 2012 I bought a rebuilt s50 with 3k miles($3300) on it also ceramic racing headers. He recommended the mechanic and dude ****ed my car bent the clutch forks bent a whole bunch of ****.. Paid another 1200 to get the motor running.but it has this issue.it won't start right away it kicks and kicks. I'm just hoping to catch a break a straight answer...
Um. I don't understand what any of this means.
Except the straight answer bit, but even that is not a sentence.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-08-2013, 08:10 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Originally Posted by dc_wright View Post
How many miles on a wiring harness? At least 10 x 1,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000,000,000, 000,000,000,000,000,000,000,000,000,000,000,000,00 0,000,000,000,000,000,000,000,000,000,000 Coulombs.
Give or take a few.....
That might be more Coulombs than the history of the unit. It's too many zeros for MATLAB, so I'm not going to count them either. And 10 x that number is just one more zero.
Anyway, divide it by 3600 and you'll get Amp-hours.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 03-08-2013, 08:20 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Originally Posted by drivinfaster View Post
it.
must.
be.
some.
sort.
of.
code....
off to get my super secret decoder ring so i can figure this out....gunna be a toughy....
df
The code is only deciperable if your name begins with "J" It's an enigma,wrapped in a riddle kind of like what you see below this line.
Me either, but I don't understand the last half sentence either.
What a nerd. ^
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
So let it be written, so let it be done.
Old 03-08-2013, 08:34 AM
petriej's Avatar
Yes.
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-08-2013, 08:46 AM
Yes.
Old 03-08-2013, 08:48 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Re: 95 m3 wiring harness
I wasn't questioning thAt. If I was I would have been straight about it And asked him that. If you knew what I have been through with this car you would understand.. With that being said Dino if you took offense I apologize.. I don't use the forums regularly.
Haha, you're good man. They're just messing with you ( a lot of people seem to not like this) that's how we are here.
And as for your question, I'm not sure i really understand but the car that it came from had asc so i don't think you'll lose it
Sent from my SPH-D710 using Bimmer
EDIT: Ok i logged on from the PC and it looks like an EGR class just took place
-Dino
Old 03-08-2013, 09:59 AM
dc_wright's Avatar
bimmerfest Supporting Member
So, now that we've finished the hazing and you've survived, let's see if we can get your problem fixed.
From your description of the hard starting where you state it "kicks and kicks" if you mean that it's trying to catch and fires a time or two and then spins and then fires a time or two and then spins, that sound more like fuel starvation to me. If you've got a wiring issue (an intermittent open) you're going to get the engine spinning by the starter with nothing happening, or you're going to get a start up typically.
I'd be first checking the fuel system to ensure that you've got pressure at the fuel rail that feeds the injectors. If it's low or zero then it could be the fuel pump, the fuel pressure regulator, or a simple thing to change, the fuel filter.
Seems you've been down the path of throwing parts and $$$ at this car, let's work on really getting it correctly troubleshot and then correctly fixed.
If you'll try to be very detailed and descriptive in the symptoms (correct punctuation and grammar counts in this sub forum) we'll try to walk you through the troubleshooting steps to figure out what's really wrong.
Old 03-08-2013, 10:01 AM
petriej's Avatar
Then check your cam and crank position sensors. If they're malfunctioning, it can prevent spark and fuel.
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-08-2013, 10:05 AM
With all the work done on it, I would also take a peek at all the electrical connections as well. Anything could be unplugged at this point.
Old 03-08-2013, 10:10 AM
jonesin's Avatar
The Canadian Prick.
For the wherefore as to requiring correct grammar and punctuation:
There is a HUGE difference between 'helping your Uncle Jack off a horse', and helping your uncle jack off a horse.
Old 03-08-2013, 10:51 AM
BMRfanatic's Avatar
Here are some vids i found on youtube on how to perform fuel related tests
http://www.bimmerfest.com/forums/sho...9&postcount=11
-Dino
