Old 03-08-2013, 11:54 AM
titan silber titan silber is offline
Mein Auto: '02 330ci RIP
Question on rear suspension
My '02 330ci is 11 years old with 141k miles. I've already done RTABs but am now turning my attention to the rear suspension ball joints.
Realoem shows my car having an upper ball joint and a lower "rubber mounting". When I load in a same year M3, it shows the same upper ball joint as my 330ci in both positions. I'd rather put in upper and lower ball joints as in the M3 because they're probably stiffer and longer lived than the rubber mounting.
Will an M3 lower ball joint fit in place of the lower rubber bushing in my 330ci? Hoping somebody as already done this, if not it'll be to give a first try. Searching didn't turn up much.
TIA!
Three Queens = a full house!
There's also a Queen in the sky - her name is Svetlana Kapanina!
Check her out on you tube, it's worth the trip.
Old 03-09-2013, 05:07 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
Since realoem shows different part #s for the trailing arm, I would think the lower ball joint would not fit.
Old 03-09-2013, 10:11 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
TIA!
They rarely wear out...what makes you think you need them?...more than likely you need rear dif bushing much more than Trailing Arm ball joints or lower rubber mount.
Old 03-15-2013, 09:14 AM
Thanks for the replys guys. I got the idea from turner motorsports which claims the ball joint will fit both upper and lower locations, as in an M3. They also recommend replacement after 100k miles; I'm at 141k. Just seemed like a nice upgrade. Will take the advice on the diff bushings and do them both.
On to the DIY section....
Once again, thanks to all!
