DISA won't go back in
I imported the GAS disa o-ring for my 320ci. I spent about an hour pulling the old one out (in pieces), then fit the new one in and now I can't get the disa back inot the intake. I've tried multiple times using sheer strength to push it in using a very thin layer of clean oil on the o-ring, I even tried tightening the disa down hoping it will just slide into place...nothing. The o-ring just seems too "fat". I tried compressing the ring a bit to hopefully flatten it out but that didnt work either. Has anyone had this experience with the GAS o-ring before? Need help any and all ideas are welcome.
Chris
I just replaced my disa yesterday, but with oem unit. It fit right in without any issues. So would say there is something up with you o-ring.
Sent from my Nexus 4 using Bimmer App |
What engine does 320i use? If the 325i and the 330i use different DISA valves, it might be safe to assume the 320i is different from either as well, which might be your problem.
I used the GAS kit with o-ring and had no problems. |
It's the same as the 325i even though I have a 2.2L. It's very annoying because now I have to search for a new o-ring and if I can't find one I will have to buy a new disa. Do you know what size it is?
sorry, ITYS "Cheating" the system by avoiding just replacing the oem DISA is bad business. We have enough little aggravations with our German motors, no need to add complications at the DISA. |
OP is doing something incorrectly. Reread the instructions and follow them completely. |
[QUOTE=hitbyastick;7431679]Nothing wrong with repairing a DISA valve with a GAS kit. Like I said before, my installation went without a hitch. Now it is superior to an OEM unit, with no likelihood of that steel pivot pin walking out and getting sucked into the engine. And the o-ring supplied should fit fine. If the OP can fit the o-ring to the DISA valve itself and it seats properly in the groove, then there is something he is not doing correctly upon reassembly if it won't fit. Nobody has ever had any trouble with this. If the old DISA won't go back in a new one won't either.
OP is doing something incorrectly. Reread the instructions and follow them completely.[/QUOTE] OP *is in Australia*, where they have different engines than we get here in US and A....
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
That comes up with this thread, among many others: - Where to get just the M54 DISA valve o-ring (1)
[QUOTE=Fast Bob;7431706]
We have sold hundreds of these kits throughout the world and have not had a problem. The o-ring is very carefully sized for the M54 DISA housing. There must be something else going on. If you are able, please post a photo of the unit with o-ring installed. You also stated that the old DISA was difficult to remove and came out in pieces. This is very unusual as far as I know. Is there a possibility that part of the old unit is still trapped somewhere in the opening? Another thing to check would be whether some of the molded silicone seal of the original unit has bonded itself to the inside of the manifold opening. If you find that to be the case you should be able to remove it with a Scotchbrite pad, but make sure to wipe out any loose stuff afterward. There is a fatter version of the o-ring for the M52 engines, but the way these kits are packaged it would be almost impossible to have shipped a kit with the wrong o-ring. Please email me our use our website contact page if there is anything I can do to help. Gary
"I'm a little rascal on my Little Rascal" - unknown |
But realistically, I've been active on three BMW boards and have heard of a few times where someone referred to the steel pin falling loose. The DISA in this case has to be horribly worn, and even then I've NEVER heard of a single example of the pin falling into the engine. I think this scare is worse than its bite. |
To the others who provided feedback-the o-ring I bought was just too fat. I cleaned the groove on the disa really well, there was nothing left of the the old ring. I pushed straight into the intake with all my might and couldn't get it in. I made sure the intake was clean and free of debris before trying to slide it in. Let's be real here, there is only one way to put a disa in, right? Thanks everyone!
Gary
PM Sent Thanks
But I bought the kit, it's a great kit. Made very well. What the hey. The O-ring is definitely a good idea to replace, but the rest of the kit is probably more of a feel-good measure. |
Actual photo sent to me by a customer. Hopefully the noise would get your attention before all the pieces let loose. Gary
Just type /disa F3 into the best links and this shows up in a split second, for example; - An example of how a broken DISA valve can ruin your M54 engine (1) Did you read the referenced thread? Did it not answer the question? It's my understanding it answers the question for the M52 and the M54. It even gives you suppliers, and prices, and pictures? It would be disturbing if the thread, which purports to provide o-ring sizes, didn't provide you the right size for your engine. What is it missing from that thread that you needed? Ample stories abound about how the pin slowly works its way loose are to be found by typing /disa F3 in the best links: - Where to get a proper DISA valve repair kit (1) & how some jury-rig 'repair' a rattling DISA unit (1) (2) (3) & how the DISA valve operates (0) (1) (2) (3) (4) & how to test DISA operation (0) (1) (2) (3) (4) & a simple DIY to install an M54 DISA (1) & a nice DISA autopsy (1) (2) & a great DISA group buy (1) & how the disa valve o-ring fails (1) (2) & how it can reputedly cause all sorts of cold-engine rough idle problems (1) (2) & where to get just the DISA valve o-ring (1) & why you want to check the DISA at 100K miles or whenever the airbox is removed (1) (2) & why the DIfferenzierte SAuganlage ("Differential Air Intake") valve flap breaks (1), sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & a well documented example of how a broken DISA flap can ruin your engine (1) & yet another seemingly complex set of misfire codes reputedly traced to a broken DISA valve (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 03-11-2013 at 04:05 PM. |
Check the detailing forum.
I hadn't noticed you're in Australia. While shipping for an o-ring might be more than the o-ring, it shouldn't be too bad. But, don't they sell equivalent (metric perhaps) o-rings in Australia?
