E90/E91/E92/E93 (2006 - 2013)
Old 02-27-2013, 03:18 AM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
Originally Posted by sptt144 View Post
How did the Expansion Cap repair turn out?
Apparently it has fixed the issue according to the mechanic. So looks like I have a spare pump lol I still need to scan the codes with DIS though, because the indy won't have this software, but he is positive it was the cap.
The reason why I still haven't picked up the car is because I had my appendix removed 2 days ago lol Worst possible timing ahahah. So I will update this thread when I pick up the car and check the codes out.
It was interesting that their was so much coolant in the engine bay, I assumed if the pump had died then there shouldn't be any coolant, because what else could push the coolant out.
Old 02-27-2013, 12:25 PM
Patrick- BMWPartsSource Patrick- BMWPartsSource is offline
Mein Auto:
Originally Posted by aleks001 View Post
Just so people have a list of when these things go, mine finally died tonight:
136,000 kilometers/84,000 miles
Normally wouldn't really be bothers by it and would change it myself, but I need the car fast so I took it to my local indy and I'm scared to even guess the price (I'm in Australia). I'm bracing myself for anything between $1000-$2000.
As far as I'm concerned the pump has lasted long enough, car is now 7 years old. 7 years is a very long time for anything electric. Just a bit disappointed I can't wait for the part from europe and do the change myself, would only cost me $500 damn you busy life :P
I would recommend to any other e90 owners to just change the pump as part of maintenance at 120,000 Kilometers/75,000 miles at the latest.
Hit me up, we ship all over the world !!!
Patrick
Patrick Casey
Internet Parts Manager
121 Granite Run Drive
Lancaster PA 17601
pcasey@bmwpartssource.com
Old 02-28-2013, 01:21 AM
Aleks
It's not the expansion tank cap, on the way home from the mechanic it overheated. Man mechanics suck these days, this is why I do everything my self. My biggest mistake was taking it to him in the first place.
Charged me $120 for get this. 1 expansion tank cap, half an hour labour to remove the lower panel, pressure test the system and top up with distilled water. What a disgrace.
Old 03-01-2013, 05:14 PM
Aleks
Scanned for codes with DIS. It's definitely the pump.
Old 03-10-2013, 06:01 PM
Aleks
Have changed the pump on the weekend, didn't change the thermostat as I changed it about 7000 miles ago as it failed open.
My tips for doing this work.
1. Take your time, it's not too complex but it's not too easy either.
2. Take the radiator fan out.
3. Take the 4 bolts of and let the sway bar swing.
4. Any hose that is in the way remove it. They are easy to take of as the clips are simple pop in out kind of stuff.
The hoses on the pump and thermostat can be a bit of a pain though.
This will give you a lot more space to work in there.
