Cheap easy DIY smoke tester.
Hi all, here is my version of a M54 vacuum system smoke tester.
Built it today with stuff laying around. I could never have come up with this if it were not for this forum. Thanks all to contributors! Tools: Glue gun. Something to cut hose. Something to make holes in plastic. A source of compressed air. Parts: Plastic jar with screw on lid. 5/8 plastic elbow (i used a tee). 5/8 rubber hose. 1/4 rubber hose. Cheap cigar. 3/8 drive socket that fits cigar. Assembly instructions: Drill hole in center of lid. Drill hole in side of jar, at top. Glue together. Lol How to use: First remove air filter box and put a rubber glove over MAF. Remove hose from brake booster (be careful, the connector is plastic). Put cigar in socket, light it, screw on jar, shoot air (low pressure) into 1/4 hose at top of jar to get it really smoking good. Insert smoking end into brake booster hose. Look for leaks. And I got the famous CCV hose to dip stick leak. A video of using it. Last edited by RainyRider; 03-10-2013 at 09:26 PM. Reason: Adding video link. |
Love it! I was thinking about puffing away into the intake but this takes the cake. Hopefully you are t using a $20 double chateau Arturo Fuente. ;-)
PeteMo94 2004 325Cic w/ ZSP, ZCW, ZPP, Bought on 12/1/2012. 1st time BMW owner E46 Merit Badges: OFHG, WP, ET, AT-T, ICV, CCV, Fluids (5) |
Here's another reference:
- How to make your own smoke machine (1)
Ahhh bluebee... I have your great write ups bookmarked! A wealth of information for sure.
Petemo... I had a good laugh with cigar store guy on how cheap i wanted to go. Looks like you did allot to your car already. Slowly doing the same. Bought mine 12/31/12. |
The only way a true pimp smoke tests!
2003 330i TiAg Sport Pkg MODS: AA Stage I supercharger , Meyle HD FCAs w Powerflex bushings, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, SAP seafoam, Magnetic Infandibulator (see wiki) On deck: Bilstein shocks, Meyle HD Rtabs, Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD |
+1 And md 2020 works as a great parts washer. :-)
Looks like a Fuente cuban corona, the DBL chateau is a much longer cigar.
Arthur John Born 02-24-11 Has already been awarded the title "Destroyer of Sleep" |
