What to do with brakes? - Bimmerfest - BMW Forums
Old 03-10-2013, 03:14 PM
Zain1003 Zain1003 is offline
Mein Auto: 07 e90 335i w/ Sport Pkg
So as of a few days ago my brakes started squeeking heavily when I slow the car. It's pretty annoying, I was just wondering what exactly needed replacing, if anything.
Rotors and pads? Just pads?
The odd thing is that my "BRAKE" warning light isn't on. Maybe the problem is something else?
Old 03-10-2013, 03:43 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Your pads probably need replacing (please verify). As far as brakes, replace pads, rotor, and sensor...go to www.getbmwparts.com for the brake kit. Bring to your indy, or DIY. As far as the brake warning, I think that is a pressure-related warning system (think air in system, brake line rupture, or master cylinder/ABS issues), so you would not see that warning due to worn pads.
Old 03-10-2013, 03:54 PM
I see. Also, do I need to replace rotors? I know BMW recommends it, but BMW would also recommend us to give them our life savings if they could.
Old 03-10-2013, 04:10 PM
I would replace rotors. The reason being is when rotor thickness is checked, it is usually checked when replacing pads...who knows what that rotor thickness will be once the new pads wear out. If you end up saving the rotors, I would recommend checking rotor thickness every 5000 miles or so.
Old 03-10-2013, 04:22 PM
Red bull Red bull is offline
Mein Auto: BMW 3 328i.
Oh please. F to a Indy and have them check your brakes. Brakes are easy. Any average guy can do a brake job.
Old 03-10-2013, 04:24 PM
I see sounds good, also, what do you think of turner ms' brake revamp kit, 485 bucks for rotors pads sensors and brake fluid? For an extra 100 you can get turners slotted rotors with some autocrossable stop tech pads.
I feel I could definitely use the heat dissipation and extra bite, I don't autocross but I do some "spirited" driving on the highway often. Usually with any given g37 .
Question 1: is it reasonable to buy the turner kit? 500 bucks and DIY saves some pretty serious costs, by any standards even if I don't go to the dealer.
2: should I opt for slotted with better pads?
Old 03-10-2013, 04:27 PM
I have a buddy who works at jaguar who's gunna do the work for me. I'm not expecting any labor costs.
Old 03-10-2013, 04:38 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
http://www.ehow.com/facts_5036302_sy...ke-rotors.html
how many miles on car?
my car is still on original rotor at 139k miles, I don't use brake much - on my 2nd set of pads.
Old 03-10-2013, 04:41 PM
61.5k miles. But since I've had the car at 54k miles, I womp on my brakes. God knows how they were used by the previous owner.
Old 03-10-2013, 04:58 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Getting a bit ahead o'yourself....you should: Inspect your brakes noting pad & rotor thickness.
How's she measure?
Old 03-10-2013, 08:11 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
You can just replace your pads if you want after eyeballing for rotor thickness. You don't want a raised lip on the outer side edge of the rotor (or a level, "break even" edge). YOu want some raised thickness as compared to the rim. The pads are typically very soft so you don't get as much rotor wear on these as evidenced by all of the brake dust. Worst case scenario is you put on new pads, its starts squeeking or grinding and you have to put new rotors and pads on again. The only thing that gets hurt is the old rotor, brake pads, and your wallet (from my personal experience).
Old 03-10-2013, 09:52 PM
Due to my lack of self control I ended up buying turners brake kit. Got slotted rotors and stop tech pads.
Old 03-10-2013, 10:04 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Those must be awesome. I have the original originals on my E92 with 36K miles. And once around the Nurburgring, several hundred Autobahn miles, and many times around NHIS and Lime Rock Park, with not a single issue with the brakes that came from the factory.
So I gotta figure that with the Turner kit my car would stop even faster and straighter for a lot longer. Right?
Old 03-10-2013, 11:01 PM
Wait wait, all that driving and you must have been hard on your brakes, maybe I didn't need all that, hmm. BUT, from where I looked, aftermarket basic replacements would have been 100 dollars cheaper, and of course OE would have been more expensive. So hey, 100 bucks for some capability I may or may not use? I'd say its worth it, at least I can brag about it to my friends
Also, I'll let you know how they feel once installed, incase you ever need to replace your stopping gear.
