E46 (1999 - 2006)
Old 12-24-2011, 08:00 AM
jsconway jsconway is offline
Mein Auto: 325it
HK business CD on/off/volume knob broke
One of my kids pulled on the button (rather than pressing it) and now the on/off/volume knob no longer works and is loose in its socket. As a consequence, I can no longer power on the system, so for now it is radio silence. I have looked on ebay and found a reseller with factory BMW HK business CD units and it looks like there are both Alpine and Blaupunk units. I have a 2003 325iT, and not sure which of the two I have, so I am thinking I need to pull the existing unit to be sure before ordering the replacement.
A couple of questions:
Are there any coding issues with a new unit? I thought there was some kind of radio security code.
Does the model year indicate specific radio manufacturer?
Anything else I am not thinking about?
Any input is appreciated. It is driving me crazy not having radio in the car Thanks in advance!
Old 12-24-2011, 02:24 PM
Chauntalei Chauntalei is offline
Mein Auto: 2002 325i
If you check out realoem.com and put in the last 7 digits of your VIN, you can pull the part number/model for your radio and use that to track down a proper replacement.
Old 12-24-2011, 02:31 PM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
You might be able to fix it, I've glued mine back together twice! Just google it, there's a diy video somewhere... I'll post a link if I get a chance.
Old 12-24-2011, 02:34 PM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
I you do like I did and send it to a shop for repair you will find it costs as much or more than getting a used one. I got my from Christy's BMW over two years ago and it still works.
PT
___________________________________
Old 12-24-2011, 03:17 PM
Mein Auto: 325it
Mine is just sort of loose in the socket... I can not turn the radio on. The knob itself is intact, or at least what is exposed. I couldn't find any video, but admittedly am a lousy google searcher. Thanks for the reply!
Old 12-24-2011, 03:18 PM
Mein Auto: 325it
Thank you... I don't know why I didn't think of that.
Old 12-24-2011, 09:39 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
If just the radio knob is broken, that part is replaceable individually. Order it through your BMW dealer.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 02-11-2012, 05:09 PM
ggladden ggladden is offline
Mein Auto: 2003 325i - 5 spd SP
The DIY video:
This is video 1 of 2.
I performed this repair today. It is fairly simple and you just need a few small pieces of additional hardware. The total cost was ~$5.00 and I bought a couple extra pieces just in case.
Old 11-05-2012, 06:43 AM
rruiter rruiter is offline
Mein Auto: 04 M3 Coupe SMG
This just happened to me last week. Knob stopped working. Looks fairly easy to fix.
Good thing I found this, without it I would probably have bought another unit.
04 BMW M3 Coupe SMG-II Carbon Black
Old 11-05-2012, 07:41 AM
1972ford's Avatar
Mein Auto: 325xiT
I was able to do the repair in the video without any of the disassembly beyond removing the head unit from the dash. There were vents (holes, anyway) right above the area I needed to glue and I was able to finagle it back together in like 3 minutes. Left it overnight to cure and it's been good since.
Old 11-06-2012, 10:35 AM
Went to lowe's to get the small machine screws but they don't have them that small
Old 11-06-2012, 10:41 AM
Mein Auto: 325it
I ended up sourcing a head unit from German Audio Tech on ebay... was about 235 bucks I think. I have the old unit and might fix so I have a backup in case this happens again.
Old 11-06-2012, 04:37 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Let me see if I understand your problem. The knob broke so you want to replace the unit? How about gluing the knob back on? I am sure you can think of some cleaver way of doing that, which is less drastic than replacing the Business CD unit.
I guess I'm too late to rattle in this thread. Done deal.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 11-06-2012, 05:12 PM
1972ford's Avatar
Mein Auto: 325xiT
yep I've glued mine back together twice, grand total of 30 minutes of time and $2.99 in super glue invested. Next time I'll suggest someone just send me their head unit and $200 and I'll mail it back fixed. ha
Old 11-06-2012, 05:15 PM
If only it was that simple. The part inside the radio breaks causing the on/off button to stop working. You have to take the radio apart (well, the outer shell really) and then fix it.
It's easy to do.
Home depot and Lowe's do not carry machine screws that small. I found them at a local ace hardware store. 1.25 dollars in parts and some easy labor. I'll take that.
Old 11-07-2012, 02:22 PM
Mein Auto: 325it
the part of the knob that broke is on the inside of the radio, as shown on the video above. It's actually not the knob, but the retainer on the inside. Much more involved than super glue and a few minutes.
Plus, now I have a spare that I can repair whenver I can find the time and listen to music in my car in the meantime.
Old 11-07-2012, 06:51 PM
JJ3699's Avatar
JJ3699 JJ3699 is offline
Send a message via AIM to JJ3699
1972ford, were you able to find the video that you were talking about or is the video posted by ggladden the one you were referring to ?
.................BMW 4 LIFE.....................
Old 11-08-2012, 06:00 AM
1972ford's Avatar
Mein Auto: 325xiT
That video is the one. I guess I was lucky that I could reach the internal broken part through a tiny hole in the casing, seems like other head units have solid cases right there, and you have to do more disassembly. I guess I need to watch that again, I don't know why you need to buy screws. I can't watch now I'm at work but anyway I've taken apart plenty of electronics and never had to purchase new screws...
Old 11-08-2012, 06:40 AM
I fixed mine last night. Overall it's pretty easy to do. I used machine screws like in the video.
I did notice the little plastic stands were broken on both sides. I kind of put them back in but I am not sure if it will hold up over time. Ideally I would like to replace the whole switch, but I doubt you could buy that piece. The diagrams on realoem.com don't show it as a separate piece. Anyone know ?
Old 03-10-2013, 03:36 PM
tokapeba tokapeba is offline
Mein Auto: 2003 325xi
I was able to fix my radio for $.15 from Ace hardware. I drilled a small hole in the plastic behind the knob that lined up with the hole on the bracket. My hole was at 11 o'clock about 1/3 of an inch from the center. I bought a small screw the same size, but a little longer than the screw holding the heat sink in place with courser threads. I bet it could be done without removing the radio in about a minute if you were lucky.
Andy
Old 03-10-2013, 11:24 PM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
I have a Business CD unit for parts with all the external buttons if anyone needs it.
Old 10-04-2015, 07:08 AM
mke_36 mke_36 is offline
Old post, I know, but I found it very helpful as my radio broke recently. I was not able to get the new screws to work but the superglue did the trick for now.
I found another helpful video at http://www.bavtekinc.com/do-it-yourself/e46-cd53 that showed a different way to pull it apart, and the company sells a replacement for the broken white piece of plastic (which my BMW dealer did not).
Old 04-01-2017, 12:39 PM
FXDL FXDL is offline
Mein Auto: '03 330Ci
A cheaper, simpler fix for radio knob
Mine broke a few years ago. I watched the video posted above and couldn't believe how they over-designed the mounting of an On-Off_Volume control pot. I spent over 35 years as an electrical engineer and have never seen such a ridiculous mounting scheme for a pot. I thought there had to be an easier fix then removing dozens of screws and trying to work with that plastic mount piece. I found another video where a guy just jammed a piece of wood behind the pot to hold it in place. So, I removed the radio from the dash, removed the top cover (a couple of screws), put RTV silicone adhesive around the pot behind the front plate, cut a small piece of wood and RVT'd it in place between the back of the pot and some structure directly behind the pot. I let everything dry to verify that it was solid before reinstalling the cover. Done. That sucker ain't going anywhere. A simple, elegant fix. Well simple anyway.
