Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-12-2013, 10:41 AM
Wolfy Wolfy is offline
Mein Auto: 1988 BMW 325i
Exclamation Brake Pads? (Advice wanted)
I posted a topic a little bit ago regarding brake pads and no responses now I would like some input on what I should replace my old pads with both front and rear and of they would come with brake pad sensors.
Car is a 1988 BMW 325i convertible
Also would like to know, if there is a place I can purchase an Auto Stick shiffter as mine has recently broke
Old 03-12-2013, 12:36 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
Depends what kind of driving you do.. If your racing on the weekend and not driving the car during the week then use Hawk pads. If your mostly daily driving then Wagner Thermoquiets are nice Part number MX493 for the front and MX279 for the rear. If you do a mix then Centric brakes is some of the best oem style pads and rotor I've ever put on.
front pad sensor 116.34003 and rear is 116.34002 about 5 bucks a piece. Centric part numbers.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
Old 03-12-2013, 12:39 PM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
http://www.pelicanparts.com/bmw/cata...pg3.htm#item13
Trans shift handles.
1985 335i
Old 03-12-2013, 07:25 PM
downhiller's Avatar
livin large
i had a nice setup, mainly for dd and quick runs up and down mountains, centric posiquiet ceramic pads and brembo blank rotors front, stock rotors and pads rear. abs didnt work so i had a great feel of the pedal
Old 03-13-2013, 12:13 PM
Thank you, and I dont race but I'd prefer to get a better combo with new rotors and pads, as I do tend to have a heavy foot at times.
Old 03-13-2013, 12:21 PM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
All good info thus far. I prefer OEM pads on a stock car.
Old 03-13-2013, 12:39 PM
ECSTuning's Avatar
Mein Auto: e30
On my vert I'm running Pagid pads and Meyle rotors (LINK), it's a great combo for a weekend cruiser. On the coupe I'm running Hawk HPS pads and Meyle rotors (LINK), the Hawk pads are plenty mellow around town but when I'm running around the twisty back roads out in hill country they provided great braking force and are very very difficult to fade on the street.
As for the shifter for the auto trans 25161216905 is the current active part number. I have it available HERE.
800.924.5172
OEM BMW Part Number Search
