Old 03-12-2013, 10:50 AM
eWERK-E60's Avatar
eWERK-E60 eWERK-E60 is offline
Mein Auto: E60 550i Porsche 911SC
Coil pack help Removal
Hi guys, changing my spark plugs now, passenger side. Got first 3 moving front to rear, how do I remove the last pack? Do I have to remove the bracket on the left? There's no room to remove the pack from the cylinder. Frustrating!!
“Racing is life. Anything before or after is just waiting.”
Steve McQueen
Old 03-12-2013, 11:03 AM
pcy pcy is offline
Have you removed the cabin air filters, surrounding plastic moldings, bars that are mounted from strut towers to the firewall?
If not, you need to remove all those parts to access the remaining coils and spark plugs.
Old 03-12-2013, 11:06 AM
eWERK-E60's Avatar
Pcy, yup removed all that. My problem is when I'm trying to remove the last pack it's hitting the inside of strut wall to the left in engine compartment, no room to wiggle out of cylinder? Coil is too long...
Steve McQueen
Old 03-12-2013, 01:05 PM
eWERK-E60's Avatar
Any ideas guys? Can't figure it out...
Steve McQueen
Old 03-12-2013, 02:15 PM
pcy pcy is offline
See if this helps...
File Type: pdf E60 545i Spark Plug Replacement - Bavarian-Board.co.pdf (1.12 MB, 121 views)
Old 03-12-2013, 02:33 PM
eWERK-E60's Avatar
Thank you pcy! I need to remove that bracket holding the AC lines and push it downward as described, thats what is preventing me from removing the coil pack from the cylinder. PITA!
Steve McQueen
Old 03-12-2013, 03:03 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
You have to remove the two bolts that hold the AC line connection in that area and move the whole thing out of the way. This requires bending the line slightly.
Old 03-12-2013, 03:16 PM
eWERK-E60's Avatar
Ok great, will take another stab at it later tonight... I actually removed the two bolts and bracket but was afraid to move or manipulate those metal lines to make room. IMO that is a pretty dumb place to put those lines and having to bend them out of the way just to replace a spark plug! Greatly appreciated gents! Will keep you posted. Cheers-
Steve McQueen
Old 03-12-2013, 03:18 PM
DIY'er
Yep, not so smart. They certainly could have gotten them out of the way, although I'm just glad that you CAN get to the spark plugs on these things with as tight as the engine is wedged in there.
I wouldn't put it past BMW to call spark plugs a "lifetime" wear item and make it where you have to pull the engine to replace them, lol
Old 03-12-2013, 03:31 PM
eWERK-E60's Avatar
Agreed! Like my dad always tells me, "you need the right tools for the job"
So far only mishap is the coil pack plastic cover that secures two packs in place, I dropped one. I need to crawl under the car and remove the bottom splash guard to fish it out.
Steve McQueen
Old 03-12-2013, 11:19 PM
eWERK-E60's Avatar
Thanks for all the help guys, I was able to change all the plugs. The car is running great, idles and accelerates better than before. Cheers!
Steve McQueen
Old 03-13-2013, 06:32 AM
pcy pcy is offline
good to hear that you've completed the spark plugs change and the car is running good.
Old 03-13-2013, 01:12 PM
eWERK-E60's Avatar
Quick update: driving the car all day, now it seems there's more throttle lag, as if there's a problem with the fuel- "starving" Is this normal after spark plug replacement? Do I have to get a reprogram done? Kinda want to put my old Bosch plugs in. Maybe I'm just being at the moment?!
No fault codes.
Replaced with NGK Laser Platinum BKR6EQUP.
Tourq 30 Nm dry as to NGK specifications. Thanks!
Steve McQueen
Old 03-13-2013, 02:37 PM
pcy pcy is offline
Programming is not needed after spark plug change.
Are you sure that lag wasn't there prior to spark plug change?
See if you can do trans adaptations reset.
Old 03-13-2013, 02:41 PM
eWERK-E60's Avatar
Ok good to know thanks. The car is most likely fine, I think I'm being paranoid at the moment. ;0)
Steve McQueen
Old 03-14-2013, 09:39 AM
eWERK-E60's Avatar
Had my new battery registered finally, solved my issues. I also had a error mis-fire code, which was cleared as well. My car is running perfectly now!
Steve McQueen
Old 03-14-2013, 12:04 PM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
How many miles were on your car when you decided to change them? How long was the process?
2008 550i Sport-a.k.a. Hot Kraut Garbage
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR Sold
2005 Triumph Daytona 650 (wife) Sold
Old 03-14-2013, 03:24 PM
eWERK-E60's Avatar
Hi Jim, my spark plugs had 33k on them. I was having rough idle when engine was cold, so I decided to inspect the coils and the plugs. All my coil packs are in working order and are not damaged, I'm glad I didn't have to buy new ones just yet. I replaced the plugs and used NGK this time around. The whole process should take around 2 1/2 hours. In my case, I didn't know how to remove the #8 coil pack due to the A/C lines and bracket being directly in front of that pack. So, my project came to a halt and did not finish until later that night. My car idles nicely and fires up in heart beat. When I change again in 35k or so, I'll replace the coil packs as well.
Steve McQueen
Old 03-14-2013, 03:34 PM
Cool, thanks! Just wondering, though...aren't these plugs supposed to last like 100K? I'm considering changing mine out at about 80K (currently at 56K and runs fantastic), but you state that you plan on changing your current plugs again in 35K miles? I assume your duty cycle is extremely rough to cut the change interval by 2/3rds?
Others:
Old 03-14-2013, 04:09 PM
eWERK-E60's Avatar
It all depends I guess, some techs say 80-100k on the 6 cylinder, on our 4.8's 4 years/60k which ever comes first according to bavauto.com
BMW tech stated to me at my milage it would be ok change plugs, he suggests 40k on our engines. your right, to change out the plugs and packs in another 35k might be too soon here is a picture of my original Bosch plug.
Steve McQueen
Old 03-14-2013, 05:08 PM
DIY'er
I can say mine looked HORRIBLE when I changed them, although I have no idea how many miles were on them
It can be done in an hour (after you've done it once before)
Old 03-14-2013, 06:32 PM
eWERK-E60's Avatar
Yup agreed. Just don't drop stuff in the engine bay like I did. Had to crawl under the car and remove the splash guard to find what I dropped. LOL!
Steve McQueen
Old 03-15-2013, 06:56 AM
Stephen Max Stephen Max is offline
Mein Auto: 1998 M3, 2004 545i
To avoid having to do that in the future, just stuff some towels down in between the cylinder head and the side of the engine bay. Anything that drops will land on the towels in easy reach. Just don't use your wife's good towels.
Old 03-15-2013, 09:45 AM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
The rear coil on the passenger side is a real PITA, well worth it in the end.
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 03-15-2013, 09:46 AM
eWERK-E60's Avatar
Originally Posted by vapiano View Post
the rear coil on the passenger side is a real pita, well worth it in the end.
+1000
Steve McQueen
