Old 03-11-2013, 02:40 PM
Alex Ford Alex Ford is offline
Mein Auto: BMW 530D SE
E60 gear stick knob removal?
Hi. The chrome plate on my 6 speed manual gear stick knob is come off and leaving sharp edges, so I need to replace it but I see no obvious way to remove the knob from the shaft.
Does anybody know how its attached please?
E60 350 D manual 56 UK reg.
Thanks,
Alex Ford.
Old 03-11-2013, 02:45 PM
etnav382 etnav382 is offline
Mein Auto: 06 550i
The knob is just shoved on basically, pull up on the leather thats connected to the trim and then pull up firmly, at least thats how it is on an auto.
Old 03-11-2013, 02:49 PM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
Have you tried turning it counter-clockwise? The one on my 370Z was a real pain to get off. I used a pair of vice grips and a towel to hold the shaft while turning the knob with a pipe wrench. It worked. You don't want to put too much strain on where the shaft connects to the transmission.
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 03-11-2013, 02:50 PM
Thanks. It's a leather and chrome knob and has a leather gaiter that goes down to the centre console. Are you saying to pull the knob off at the Joint of the bottom of the knob and the top of the leather gaiter? Really don't want brake the stick. Was worried incase it had a concealed alllen screw, or was screwed one etc. PS these knobs are expensive!
Old 03-11-2013, 02:52 PM
Thanks. Not tried anything yet. I too don't want to break anything so that's why I am asking the experience here before I try :-)
Old 03-11-2013, 02:54 PM
Mein Auto: 06 550i
Pull the leather away from the center console, I usually start with one side and bend it slightly to pull it up. Then once the leather is only connected to the knob pull up on it til it comes free. Some have suggested opening the sunroof because the knob will kinda fly off when it comes off.
Old 03-11-2013, 02:56 PM
Ok thanks very much for your assistance.
Old 03-11-2013, 03:40 PM
mrgrumpy mrgrumpy is offline
Mein Auto: 2005 545i Sport
I replaced mine recently.
Pull up on it pretty hard in a sharp jerk.
That's it!
Fastest known repair on a BMW
Old 03-11-2013, 03:44 PM
Ok thanks, but you have to undo the leather gaiter from where it joins the centre console at the bottom square area or does the knob come off and leave the leather gaiter in place attached to the top area of the stick please?
Old 03-11-2013, 03:57 PM
To the best of my knowledge all E60's have a push-on / pull-off gear shift knob.
The leather gaiter reaches to the bottom of the knob but is not connected to it.
I don't believe you stated the year of your vehicle; only model.
Inspect closely, but I am quite certain that is your setup as well.
Old 03-11-2013, 04:02 PM
Thanks very much. It's a 2006/56 plate UK reg 350D E60 6 speed manual.
Old 03-12-2013, 10:18 PM
AlterZgo AlterZgo is offline
Mein Auto: 2010 535i 6MT M-Sport
I just removed mine following the instructions from turnermotorsport.com. The knob pushes on and pulls off. It clips to a ridge at the very bottom of the shift knob. The key is to place the shifter into 2nd gear. This gives you the best leverage and prevents you from pulling up against the windshield or other things that might get damaged. Once you have it in 2nd gear, just pull directly up (at the same angle as the shift lever is in while in 2nd gear) and it should come right off with no trouble. At least mine did.
To install, just push the shift knob down hard until it clicks in. Very easy, no tool affair. You don't need pipe wrenches or anything else. In fact, using tools may increase the chance of damaging something in the car when the shift knob pops loose.
Old 03-13-2013, 12:50 AM
Thanks very much. I have ordered a replacement knob and await its arrival.
Old 03-14-2013, 05:39 PM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is offline
545i pilot
Mein Auto: e60 545i e34 540 e32 740
Followed these instructions, & surprise! worked perfectlyClick image for larger version
Sent from my DROID RAZR using Bimmer App
Old 03-15-2013, 12:34 AM
Good news then! Thanks.
Old 03-15-2013, 10:43 AM
Job done. Ordered new one from Ebay (BMW Direct) 50.00 :-( but arrived this morning 2 days after ordering. 60 seconds old off, new on. Thanks to everybody's help.
Old 03-15-2013, 05:47 PM
myates3 myates3 is offline
Mein Auto: 2006 750i
Greatest advice I've read on this forum!
2006 550i - Retired 1/8/2015...you will be missed
Old 03-02-2015, 07:47 AM
gmak2012's Avatar
gmak2012 gmak2012 is offline
Mein Auto: E60:M5 530xi E39:540 528
I ordered a walnut shift know to replace the peeling plastic chrome one. After reading on forums, I thought that I would have brace myself on both sides and really pull hard. Not so. Sitting in drivers seat, pressed the start button twice (foot NOT on brake), and put car into Neutral. Shift knob came off easy with a firm pull upwards. Newone went on just as easy. Thanks to all for info and ideas on how to do this. The part I put on is here on REALOEM. It's the Pappel Dunkel one. The "Hell" one is lighter.
http://realoem.com/bmw/showparts.do?...24&hg=25&fg=95
Old 05-07-2015, 07:43 AM
545i pilot
Yeah, I figured I'd revisit this thread after busting my own stupid self in the mouth removing the very same knob I installed using these directions a couple years ago. THE KEY IS TO PUT IT IN 6th GEAR! A chrome gear shift knob to the face is not a good thing, for damn sure! I might add that that particular knob becomes a burning coal in the summer, and an ice cube in the winter. The leather wrapped knob I've got now is much more pleasant.
Old 05-07-2015, 08:19 AM
JayDee4711's Avatar
JayDee4711 JayDee4711 is online now
Benz S211 Convert
Mein Auto: 535 Xi Wagon, MB CLK430
Here comes the next level of comfort options: Complement your heated and vented seats and the heated steering wheel with an air-conditioned shift knob!
Trust me, I know what I am talking about. I am a smartass by training and have been in this business for decades.
This vehicle ran OEM pads on one axle and Akebono Euro on the other (left). Guess which ones were where!
Now there are Akebono Euro pads on both axles (right). This picture was taken after ~2000 miles without a wash.
Old 05-07-2015, 07:19 PM
5SeriesGod's Avatar
5SeriesGod 5SeriesGod is offline
Mein Auto: 5 Series
Very simple, pull up straight very hard lol.
| 2004 | 530i | 20' Concavo CW5 | BC Coilovers |
Old 05-12-2015, 10:28 PM
madmax5 madmax5 is offline
Mein Auto: 2015 650i Gran Coupe
That was the first step of many needed for me to start fixing a tiny cut wire that prevented DS and steptronic shifting to work on my automatic. cant believe how the wire harness was positioned, no wonder it eventually cut! thank the engineers for using all electric shifter in LCI and F series
Old 05-12-2015, 10:39 PM
Mein Auto: 06 550i
Madmax, can you give more details on removal and fixing the wires? My DS isn't working and I can't see any broken wires looking top down.
Old 05-12-2015, 11:07 PM
etnav,
It was honestly kind of a pain in the rear because i tried my best to avoid taking the entire centre console out to be able to access the gearshift assembly properly.
I used this guide to help me out with the steps:
Centre Console Replacement/Removal
Basically before taking everything apart, try to make sure that it is a cut wire. In my case it was the little grey one that was part of those thin wires all taped together as seen in the first picture. PLEASE NOTE: Ignore the thicker yellow, blue, green, black wires, you wont have those getting in the way, i ran those (somewhat too thick) wires to install the famous hidden Sport button
The second picture shows just how much i had to take apart to be able to access the 3 main Torx 30 screws holding down the gearshift assembly, then i pulled the shifter assemble somewhat forcefully to the left (driver side) to access the 3 (also very hard to reach) Torx 10 screws on the right side of the assembly which are holding the plastic piece that is wedging that little wire harness where the wires tend to get cut. The wires get cut after switching between D and DS too often. Bad positioning of that thin 'wiring harness' IMO. Once I managed to move the plastic piece far enough, i took out the harness from that zig-zag position, soldered the cut wire, taped the entire harness, and screwed the plastic cover back on and left the harness out loose so that there wouldnt be any more tension. Then i put everything back together which was easier than taking apart.
Ideally you take apart the entire dash/radio/centre console to have full and easy access to the shifter, that way you can take that plastic part off the side easily and put it all back together without destroying your fingers and dropping the tools in the tight spaces. All that for a tiny cut wire? really annoying. I had to use allen keys at times and turn the screws a quarter turn at a time to take out the hard to reach torx screws on the gearshift assembly. You definitely need a full afernoon for this if it's your first time.
Again, start by removing the shifter knob and pulling the dust cover off and look inside for that wiring harness and look for a loose/cut one before attempting any of this. Try to use the picture as reference to identify the cut wire.
Oh and if you resolder the wire and you want to test before putting it all back together, make sure to reconnect the 3 connectors that make the P, R, N, D LED light up otherwise DS still wont engage even if you fixed the wire correctly.
ID:	508867   Click image for larger version
Old 05-12-2015, 11:43 PM
Mein Auto: 06 550i
I've looked at the little group of wires before and didn't see anything, I'll look again tho, If I don't see anything I might have to just buy a new shifter assembly.
