Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-13-2013, 08:33 PM
Bluefin13 Bluefin13 is offline
Mein Auto: 325E
Tried the NOID!
So a little history. Bought a 85 e30 not running. Found that it will start with starting fluid. replaced all fuel lines and filters and pumps. Getting 40 lbs pressure at rail. Used a generic Noid light from Autozone. getting no light. (Although my son and I tested the ohms and he swears it was getting 2 ohms.) So this means the brain or ECU is dead right? Or is it the Ecm? Big difference in price. Can someone let me know please. I dont want to have to junk this car.
Old 03-14-2013, 07:05 PM
downhiller's Avatar
livin large
have you checked the crank sensor?
Old 03-14-2013, 07:28 PM
Mein Auto: 325E
Not yet. Got a used Ecu and now I get light flashes at the injectors but I think the injectors are clogged. no fuel out the bottom. Getting 37 psi at the rail. Will the crank sensor dictate when the injectors operate?
Old 03-14-2013, 07:49 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
The crank sensor times everything. Ignition, injector pulses. If it's bad, the ECU can't fire anything on time.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 03-14-2013, 08:17 PM
Mein Auto: 325E
This would be down by the transmission or am I thinking of the CPS?
Old 03-14-2013, 08:58 PM
D'oh, You kids!
Crank position sensor and the engine speed sensor are located on the bellhousing behind the starter mount. If either are bad the engine will run very poorly if at all.
Quotes to live by:
BMW-CCA #441426
Old 03-16-2013, 07:17 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
Have the injectors cleaned, or source another set as this may be the problem.
m
Old 03-16-2013, 07:34 AM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
m
There's a guy on this board that cleans injectors. Search for 'MEPEH'.
Old 03-16-2013, 08:37 AM
Mein Auto: 325E
Yeah i been PMing him. he wont have any til Sunday which means they are about 4-5 days away still. Im getting some from a junkyard today to see if that is the problem.
Old 03-16-2013, 08:45 AM
an audience of One
He's about two miles from where I work. Let me know if I can assist.
Old 03-16-2013, 08:47 AM
Mein Auto: 325E
I appreciate it.
