Old 03-16-2013, 03:44 PM
auricon2 auricon2 is offline
Mein Auto: 650i
Just returned from a week cruise and found an oil leak (about 1/4 quart ) dripping from the oil cover. I checked the oil level and it showed full. I took the car for a quick ride and noticed the leak was still dripping very slowly when I returned. Sounds like I may have the same problem. CPO expired
Wanted to mention that I only have 28k on my 06 convert.
Old 03-16-2013, 05:53 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Check your vacuum pump and oil sending unit right under it ! Probably the oil switch they are known to leak that much.
Sent Via iPhone using BimmerApp
Old 03-16-2013, 06:18 PM
Mein Auto: 650i
My dealer is about 60 miles away. Do you see any problem driving that distance?
Any idea about cost??
Old 03-16-2013, 06:29 PM
Nitrogen's Avatar
I don't know about the cost I repaired mine myself. My sending unit was only $15 and the vac. pump I just used Peramtex. Check the oil pan too while the car is running to see if the drips are coming straight from there. I see no problem driving the car 60 miles you should have plenty of oil in it to get you that far if it's full. If you are worried take a quart with you if it gets low the car will tell you to add a quart.
Old 05-08-2013, 10:37 PM
hipertec hipertec is offline
Mein Auto: 2005 645ci
Re: Oil Leak!
I think my vacuum pump is leaking. Its coming from there and dripping all over. Does anyone know how much is this part and how difficult it is to replace? Or should I take it to a shop?
Please help. Leaking bad.
Sent from my Transformer TF101 using BimmerApp mobile app
2005 BMW 645ci - DPE 3pc Forged Rims, Coilovers, Britalman full cat-back exhaust system, , K&N Air Filter, LUMMA Roof & Trunk Spoiler.
Old 05-08-2013, 11:00 PM
Ultimate_drivin Ultimate_drivin is offline
Mein Auto: Bmw 645
I changed my vacuum pump the part cost around 300 dollars at the dealer and mine is a 645 but u must also change ur oil pressure sensor same time
Old 05-08-2013, 11:13 PM
Re: Oil Leak!
Thanks for the reply. Do you have the instructions on to change it out? The link is no longer there from tis. I read that matching the crankshaft is the hardest part...how do you line up the shaft to slot it into the engine?
Also do you happen to have the part number? Can't find it on getbmwpart.com
Would be greatful if someone can email me the how to sheet to replace the vacuum pump.
Old 05-08-2013, 11:17 PM
Mein Auto: Bmw 645
Honestly my mechanic changed that for me I don't have any clue
Old 05-09-2013, 07:04 AM
HerbP HerbP is offline
Here is the part numbers for the vacuum pump & oil sending unit. There are 3 bolts to remove the vacuum pump, & it takes a 15/16" deep well socket to remove the oil pressure sending unit. This can be done in less than a hour. The price for the parts will vary, but the diagrams will give you a ball park on pricing!
Good Luck!
http://bmwfans.info/parts/catalog/E6...mp_with_tubes/
http://bmwfans.info/parts/catalog/E6...2*61*7*568*480
