Old 03-14-2013, 07:13 AM
mopjude mopjude is offline
Mein Auto: 2014 X5 ,99 Lexus ES300
Low RPMs at Idle
Hello all..
My E60 Idles closer to 500rpm with a slight irregular intermittent vibration, although the engine stalls but never dies at Idle. The SEL indication is not currently on...I have replaced the exhaust VANOS solenoid..resolved the Idle but came back a couple of days later.... May I add the car drives exceptionally well other than the engine jerks/vibration/stalling at low RPMs Idle.
Has anyone experienced this problem before?
2006 530xi 98K miles
Old 03-14-2013, 08:27 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Time for new coil packs. Throw in some new spark plugs while you're in there.
Old 03-14-2013, 01:51 PM
Thanks for your reply..
Car just spent 8 hours at the Dealership they can't find anything wrong after scanning, on-board scan and scoping. Service tech says although he feels the vibration at idle they can't pinpoint any fault and car is running well per BMW standard
Advised to play the waiting game because there's not enough info to change coil park/plugs or even to start throwing parts at the car...
So I have to wait for a fault code to register
Old 03-14-2013, 02:04 PM
boramkiv's Avatar
Propellers Up Front
Yes of course. They can't find any history of misfires? That's what happened to mine. The shaking was there on startup and never got any engine light or codes associated with. I changed coils and it smoothed out at idle and was fine. However using a different program I saw a history of one misfire on cylinder 3 around the time I was experiencing the roughness. The codes are mileage stamped.
I would stick with the dealer however, because it's already there and it could be something else plus coils are expensive.
Old 03-14-2013, 11:40 PM
Thanks...I will change the intake vanos solenoid to see if it makes any difference, although only the exhaust VANOS was changed earlier.
The intermittent stall-like vibration is driving me insane and I can't wait for a fault-code to register....
Just a thought, do the 06 530xi have ICV? I know the 05 model has one...
Old 03-15-2013, 04:17 AM
NoQuarter's Avatar
NoQuarter NoQuarter is online now
Mein Auto: 2008 535xi
I have experienced this as well and the dealer monitored it at idle for long while and ultimately couldn't do anything.
This was a couple years ago with my first E60. I ended up switching permanently to different brand of gas and it made things much better for me. But it seems to be a combination of things being marginally out of spec- brand of fuel, injectors, intake, plugs, .... Any combination of the usual suspects. Best to learn how to DIY the maintenance items so it is feasible to replace things that don't register as actually needing replaced yet.
Old 03-17-2013, 07:14 PM
GSG1 GSG1 is offline
Mein Auto: 07 X5 3.0, 07 525i
take out the MAF and clean it or replace it with a new one.
had the same problem and cleaning the MAF with a electric spray worked for me.
