Odometer Still doesn't work after new gears - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 02-18-2013, 03:08 PM
rkkenyon rkkenyon is offline
Mein Auto: 1983 533i
1983 533i, I replaced the gears in my odometer. The odometer now works intermitently and very slowly, my 20mile commuter only registered 5 miles, then stopped working again. Physically everything looks fine, and spins fine manually. I'm assuming this is an electrical problem but I can't trace it. The Speedo works fine, and doesn't modulate when I honk the horn (a symptom of a bad board I learned from another forum). Any Ideas?
Old 03-05-2013, 10:19 AM
ch650's Avatar
ch650 ch650 is offline
SVSCME
Mein Auto: 217 440i
This exact thing happened to me also so I went back to the instructions and missed one step.....vacuuming out the old broken pieces. All is OK now.
2017 440i
2006 650i
2003 330i (wifes) sold 10/27/06 replaced with 530i (7/21/06 ED) 9/28/06 re-delivery
2001 540i (rear ended & totaled 8/17/05)
1986 535 e28 (beater, but working on restoration)
Old 03-06-2013, 08:38 AM
Thanks! One more thing, do these steering wheels adjust? If I could lower the wheel getting the gauge cluster out would be a lot easier. There is a lever on the bottom side of the steering column but it doesn't seem to do anything.
Old 03-07-2013, 04:40 PM
ch650's Avatar
SVSCME
Mein Auto: 217 440i
I really don't know myself as I haven't been using mine very much latetly, but try mye28.com forum and you should be able to find your answer there.
Good luck.
2017 440i
2006 650i
Old 03-09-2013, 05:15 PM
catso's Avatar
catso catso is offline
catso
They adjust, but it's probably stuck from years of not being used. You can loosen the lever and try to work the steering column free. Try suirting some penetrating spray in there and consider loosening some of the mounting bolts.
Someone once had the same problem and found that there is one bolt in particular that when loosened, relieved much of the tension on the telescopic segments.
![/I][/FONT]
Old 03-17-2013, 08:24 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
The steering wheel telescopes in/out, not up/down. As mentioned, it might be stiff if it hasn't been moved in a while.
