2008 535i rough idle - Bimmerfest - BMW Forums
Old 03-18-2013, 10:17 AM
Vabstheman Vabstheman is offline
Mein Auto: 2008 535i
wondering if anyone else has experienced this. my car was running perfectly. i went on vacation for a week and started the car today and the car was just shaking when in park and even when stopped at a red light. a very strong shaking sensation. as i said the car was running great a week ago. i don't know if this is just because it sat in the garage and just needs to be run for a while. thoughts?
Old 03-18-2013, 10:45 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
I know the 535's commonly have fuel injector and fuel pump issues, but I don't know much more than that
Is it under warranty?
Old 03-18-2013, 10:47 AM
no the warranty ran out a while ago. just strange that it was fine 7 days ago and now all of a sudden there is this issue.
Old 03-18-2013, 11:32 AM
DIY'er
yeah, I don't know enough about that model to say if it's normal or not. Have injectors or fuel pump been replaced before?
Old 03-18-2013, 12:16 PM
polski7 polski7 is offline
It could be the injectors, I had the same symptoms accompanied by white smoke when my injectors went out.
2008 535i|6-spd man|sport|platinum gray|black dakota|cold weather|nav|L7
Old 03-18-2013, 12:48 PM
Cattani Cattani is offline
New to BMW
Mein Auto: 2006 550i
White smoke go away w the injector changes?
2006 BMW 550i Base
Old 03-18-2013, 01:32 PM
I had bad injectors in bank 2 which were sending too much gas and thus creating the white smoke. Due to the injector part nr update I had all 6 injectors replaced under my aftermarket warranty. White smoke and rough idle went away!
Old 03-18-2013, 01:57 PM
so when i drove the car this afternoon - everything was back to normal. no more shaking in idle/stopped. its as if the car was really "cold" after not being used for a week and it just needed time to "warm up". very strange.
Old 03-18-2013, 03:09 PM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
This is often a misfire fault that goes away when the car is restarted.
No warning lights /messages?
Old 03-18-2013, 07:02 PM
amit1947 amit1947 is offline
Mein Auto: 2014 BMW M5
Sounds like you have leaky injector(s). After sitting for a while, leaked fuel caused missfires? You should get the codes read and look for any missfires.
Have you ever had the injectors replaced? The original injector part was defective and was superceded by a better design.
Old 04-16-2013, 07:47 PM
jbnimble jbnimble is offline
Mein Auto: '09 535i M Package
I'd get it looked at right away. Otherwise you could be left stranded. I had one injector replaced 3 weeks ago. Car started to rough idle over the weekend again. Whole car was shaking. But if you drive it, it goes away. I believe that's because you burn up the leaked fuel. Started my car this evening after work and the problems occurred again w/ CEL. I drove it straight to the dealer. Luckily I made it. I had to turn off the engine a couple of times in stop and go traffic. My guess is it's another injector. Will find out more tomorrow.
Old 04-18-2013, 10:53 AM
Dorfman Dorfman is offline
Stealth
Mein Auto: 2010 535i Black Saffire
Rough Idle
I took my 2010 535i on a long road trip about two weeks ago. First day out I drove about 300 miles the first day and the car was flawless. Leave the hotel the next morning and the car runs like a bucket of bolts. Thought it was going to stall. Amazingly, there was a BMW dealership about 1/4-mile down the road so I took it in immediately for service work.
They claimed they found a bare wire near the coil with worn insulation from vibration and repaired it. The car ran fine for the next 900 miles but I am not convinced this was the main cause.
My guess is an injector problem is beginning and they did not close properly the night before at shutdown. Fuel got down in the cylinders and I did not drive it long enough to burn the extra fuel off. The car has been running fine since but is going in for another checkout shortly to my own dealership and I will have them check the codes for missfiring.
Anybody got any other thoughts on what could be happening?
Thanks in advance for any comments.
Old 04-18-2013, 07:05 PM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
My guess is fuel injectors or carbon build-up.
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 04-21-2013, 07:07 AM
billyp billyp is offline
Mein Auto: 2008 BMW 535i
jbnimble, did they find out what was wrong with your car?
Old 04-21-2013, 07:16 AM
I heard a completely revised fuel injector was released this year. Is anyone running these?
Old 04-21-2013, 07:53 AM
Yes. It's as I suspected. Fuel injector failed again so they replaced all 6 with the new injector type. My manufacturer's warranty expired March 30th. It's still under CPO but they replaced them all free of charge.
They replaced all six with the following: 6-13-53-8-616-079
I believe those are the latest injectors. So I'm hoping I've dodged a bullet on this one.
Old 04-21-2013, 08:08 AM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
Try to run top tier gas all the times and if not possible get some Chevron Techron and run it a few times every couple hundred miles.
Old 04-21-2013, 08:14 AM
Top tier gas does not help much with the N54. I have only run top tier gas and had tons of problems with the engine. Fuel injector cleaner does not help much in a direct injection engine like the N54.
BMW CCA Member
Old 04-21-2013, 09:11 AM
Jbnimble,
Did you have a longer crank time when starting in the morning or after several hours of letting the car sit?
Old 05-01-2013, 07:42 PM
Originally Posted by amit1947 View Post
Jbnimble,
Not really. But as soon as it started, I could feel the idle was rough. If I got into stop and go traffic it would get real rough. The car would shake and I could see white smoke in my rear view.
Old 05-01-2013, 09:09 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Nice. You did get the newest injectors that came out for our N54 engines. This would have been covered under the CPO warranty too so you are good to go. Like what UltimateDriving said, use top tier gas to keep the fuel rails and injectors clean. The gas won't help your intake valves but it should help keep those injectors happy.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 05-02-2013, 05:14 PM
kmack31 kmack31 is offline
Mein Auto: 535i M-Sport
Had similar issue, was the fuel injectors. If u take into the dealer and they have to change the fuel injector make sure they change to the new fuel injectors, they will most likely change all 6....just had this done this week. I also cracked a valve cover that was replaced.
Old 05-02-2013, 06:01 PM
It really seems like everyone with a n54 is going through this and many are getting their injectors replaced by the dealer. This is really getting bad. All I can say is, this better be the end of the injector/hpfp fiasco.
Old 05-02-2013, 06:33 PM
booyaazaa's Avatar
It is always nice when it's covered under warranty.
Hopefully this new series of injectors will follow the path of the HPFP since you really don't hear that much noise out there anymore about bad HPFP's when BMW went with the newer model in 2011.
2009 AW 535i
