Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 02-02-2013, 03:09 PM
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Crankcase Vent Valves
Remove the following covers.
Locate the cap and pry off cap with angled screw driver, be sure to get all the clips off
Remove the seal and spring as shown.
Compare parts old vs new to make sure you have the correct part also you can see where the defect is.
Insert new spring and seal. Also observe notch on valve cover make sure the vent cover notch aligns with that marking for proper install.
When replacing cap you should hear 6 clicks to confirm proper seating. Replace all the covers (it helps to put grease on the holes of the valve cover badges they insert much easier) clear all check engine lights using scan tool.
That's it your done! Happy speeding!!!
Sent Via iPhone using BimmerApp
Old 02-04-2013, 07:05 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
I want to change mine just because this was such a good DIY......Thanks alot.
Old 02-04-2013, 10:46 PM
Haahahahahah Thanks my first one and I know it wont be my last!!!!
Old 02-05-2013, 08:30 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Living in Fast Forward
Mein Auto: 2007 E63 650i
Thank you for the DIY Nitrogen. At which mileage should I consider doing the CCV?
Once a 6'er, always a 6'er.
Old 02-05-2013, 08:42 AM
Thanks......Mine was prompted by a check engine light. So I don't really know but mine went out at 100k miles. I would say around that would be the target or a little sooner. Rubber only lasts for so long. As you can see in the picture how it was torn.
Old 02-05-2013, 08:51 AM
07 E63650i's Avatar
I'm only at 57k right now, but I'll probably do it around 75k. I'm still amazed that your car made it up to 122k with only a few issues!
Old 02-06-2013, 03:39 PM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645
Was there something going on with the car that made you do this?
Old 02-06-2013, 08:15 PM
Check engine light came on and the car was idling rough and surging at times.
Can't remember the exact code.
Old 02-07-2013, 03:52 AM
D Woolley
Mein Auto: 05-645
I don't know of any codes but mine does idle rough and haven't been able to locate problem.any particular place to get the parts?
Old 02-07-2013, 04:50 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I replaced my CCV a couple months ago. I bought two CCV's based on the 645i CCV DIY also posted here. I returned one because I only found one CCV on my car which agrees with your DIY for the 650i.
So this was one of the changes made when they updated the N62 motor I guess from the 645i to the 650i (and 550i , 750i)? You may want to update your very excellent DIY to let folks know. Nice job on the post.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 03-19-2013, 09:42 AM
Bk650's Avatar
Bk650 Bk650 is offline
Send a message via AIM to Bk650
Mein Auto: 650i
Was your car smoking with the torn CCV? It was suggested i change mine cause im getting some smoke out of the tailpipe from idling too long
Greg A
650i on 21's 128's chrome, mtec v3 angel eyes, Custom exhaust...
2000 GS300 heavily modded gone but never forgotten
1998 LS400 Daily driver
2005 Range Rover HSE (family car)
Old 03-19-2013, 05:23 PM
07 E63650i's Avatar
Yes, a worn CCV can cause poor idle and smoke.
Old 03-19-2013, 09:56 PM
Yes it might smoke at times, and have erratic idling and also serge. It's a cheap fix only about $25-30 each from the dealer if you hunt on the net you might find them cheaper.
Hope that helps!!!
