Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 03-19-2013, 10:16 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
BMWUSA 1 series Features/Specs Specs
Engine
TwinPower Turbo 3.0/inline 6/4
Displacement
2979 cu cm
Bore/Stroke
3.31/3.53 inch
Nominal output @ rpm
320 @ 5800 hp
Max. torque @ rpm
317 @ 1500-5000 lb-ft
Compression ratio
10.2 :1
Wheels
Tire dimensions standard front
225/40
Tire dimensions standard rear
255/35
Wheel dimensions standard front
18 x 8
Wheel dimensions standard rear
18 x 8.5
Material
light cast alloy
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-19-2013, 11:02 PM
JP 99300 JP 99300 is offline
Mein Auto: 2003 E39 M5
OK, I now see that under the "Specifications" tab on the website for 135is convertible. Interestingly, though, if you look at same 135is convertible under the "Standard Features" tab, it lists 18x7.5 w/ 215/40 and 18x8.5 w/ 245/35. So 0.5" wider front wheels too on the vert? Talk about contradicting and confusing!
I guess the proof will be on the actual car when it arrives (or maybe you've already confirmed with one on the lot)....
Thanks for pointing it out.
Old 03-20-2013, 12:28 AM
No they just had a Coupe on the lot. Will take a look in a few weeks when its due in & post what it actually has on it. Will still be looking to replace them with get flats but the wider wheels if they are there would increase the available choices.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-23-2013, 10:54 PM
Just received a couple of reports from new 135is convertible owners that the website specs are wrong and their cars have 215/40 and 245/35 tires, same as coupe.
Old 03-24-2013, 12:05 AM
Sorry to hear that, do you know how wide the wheels are? Need 8X8.5 to get the bigger tires.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-25-2013, 08:37 AM
bmw325 bmw325 is offline
Mein Auto: 528i
Just curious why you guys would want even wider tires at the rear? The car is already tuned for understeer an with the wider rear tires it exacerbates the issue. But maybe i'm missing something. Granted it might look a little bettter.
Old 03-25-2013, 09:29 AM
Understeer/oversteer is less of an issue than loss of traction due to no LSD &/or overpowering the tires.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-25-2013, 09:37 AM
ND40oz ND40oz is offline
Mein Auto: 09 135i
Helps put the power down, plus things aren't changing drastically when you move to a 225/255 staggered setup, the percentage of contact patch at the front actually increases a bit.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Old 03-25-2013, 11:07 AM
Mein Auto: 528i
Kind of fun to overpower the tires though... I think most modern cars are over-tired in the interest of generating good numbers and safety but not as much fun. Kind of like Subaru's approach with the BRZ; they use skinny prius spec tires so you can get the tail out easily.
Old 03-26-2013, 04:08 PM
To follow up, it turns out actual tire size on 135is convertible is same as size on coupe. It appears the specs showing wider size for convertible on BMW website are an error.
Old 04-17-2013, 06:18 PM
Guam135i Guam135i is offline
Mein Auto: 08 135i Coupe
great info!
1970 Morris Cooper S * 2008 BMW 135i Coupe * 2008 BMW 128i Cabriolet * 2003 BMW 525i Touring * 1995 BMW M3 Coupe
Old 04-17-2013, 08:36 PM
Just looked it up & based on the size of the stock wheels width 235F & 255R are the best choice.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 09-13-2013, 07:15 PM
spotteddog spotteddog is offline
Mein Auto: 328i convertible
Here's my situation. I have a e93 'vert with sport package and want to buy tires with a larger profile. The OEM is 18 inch wheels, tires are 225-40 255-35 rear. I'd like to go 225-45 and 255-40 on those 18-inch rims. Is there enough clearance? No rub? I may not know unless I buy a tire and try it, but anyone else have some experience on this? thx
Old 07-28-2016, 04:13 PM
theangelromero theangelromero is offline
Mein Auto: 335i
I just put a pair of Firestone Wide Oval 255 35 18 on the rear of my 135i and it is fantastic! Car is much easier to drive and holds together really well. I think I am going to drop the Hankooks I have on front and replace with Wide Ovals as well. I will likely go one size wider and see what that does becasue the sticky tire a bit wider has made it smoother and much more responsive.
