Old 03-19-2013, 09:43 PM
david831's Avatar
david831 david831 is offline
Cuztomizing
Mein Auto: 2000 BMW 528i
Question upgrading speakers on my 2000 528i and need help
hi,
im about to upgrade all my speakers and need help since im a newbie. i looked around the forums but didnt find what i was looking for ... how many speakers does my 2000 528i have in total? if i want to replace all of them how will i know wich ones will i need and fit perfectly? im looking to get rockford fostgate for all of my speakers does any one recommend them or any other best brands out there? Any help will be greatly appreciated thanks
Old 03-19-2013, 11:13 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Take a look at MB Quart for the E39, unless rockford fosgate has a plug and play solution.
The standard audio system came equipped with 10 speakers. If you have DSP, you have 12.
Old 03-20-2013, 01:33 AM
david831's Avatar
Cuztomizing
thanks for the help ...i have a non DSP ...i would like to know the sizes of front and back and tweaters that will fit
Old 03-20-2013, 02:13 AM
demas demas is offline
Mein Auto: F10 550i M-Sport
Rainbow speakers are a decent upgrade and are designed to 'drop in' original enclosures.
http://www.mymotiv.com/forum/topics/...ow-e39-speaker
Old 03-20-2013, 05:06 AM
Fudman's Avatar
Fudman Fudman is offline
The OE woofers are 5.25". The tweeter size for replacements vary by brand. Search Youtube for e39+speaker+installation and you will find various videos by BSW for speaker replacement DIY. I would also search this forum for some more background info. You don't specify type of music you prefer nor the volume level you typically use. Here's a quick synopsis:
1. Priority 1 - Replace your front door speakers with a high quality 2 way system. This will make an audible difference in sound clarity and definition.
2. Rainbow is probably the top end in terms of quality but they are also the costliest. Many good alternative options (Infinity, Boston Acoustics, etc.) exist for less than $125-$200/set.
3. Priority 2 - Installed a powered subwoofer before spending your money on rear door or rear deck speakers. Replacing these other speakers makes a minimal improvement in overall audible sound quality. The low end is the missing link in the e39 audio system and must be addressed.
4. Low end options include powered rear armrest subwoofers for less than $200 (do a search for the DIY). The sky (and the budget needed) is the limit for high end.
5. Unless you like REALLY LOUD music, the OE amp is adequate for casual listening.
6. The head unit is adequate unless it lacks specific features (nav, aux input, etc.) you are seeking. Keep in mind you may sacrifice some utility (access to OBC) if you replace the HU.
7. If you need an aux or iPod input, there are multiple options (Dice, Intravee, etc.) available. Do a search for more info.
Keep in mind audio quality and what is needed to attaiin it are highly subjective so you will get multiple opinions on this matter. My personal opinion is tempered by maximizing return on investment. Enjoy your ride.
Old 03-20-2013, 09:46 AM
david831's Avatar
Cuztomizing
Thanks for the info Mates
Old 03-20-2013, 09:55 AM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
+1 on the MB Quart, I bit pricey but well worth it. I believe there made in Germany as well
Old 03-20-2013, 04:45 PM
david831's Avatar
Cuztomizing
I usually listen to rap music with lot of bass & freestyle from the 90's wich has less to no bass... do you guys still recommend the rainbow speakers or should i get. Jbl,kicker,rockford fostgate etc... any other recommendations
Sent from my SPH-M950 using Bimmer App
Once a Bmw will Alwayz be a Bmw
Old 03-20-2013, 05:34 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
The car has four 5 1/4 woofers, four tweeters, and two "midbass" tweeter things that usually get disconnected because most component kits are woofers and tweeters only.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 03-20-2013, 06:25 PM
david831's Avatar
Cuztomizing
Can anyone or does any one know if theres a diagram that shows wich speaker or size speakers goes were?
Old 03-20-2013, 07:11 PM
Fudman's Avatar
When replacing the woofer and tweeter with an aftermarket two way speaker system, you should leave the OE midrange speaker in place if you continue to use the OE amp. The OE audio system uses an active x-over and divides up the speaker output at the amp. No x-over is required so throw the aftermarket x-over away. If you disconnect the OE mid, you will lose the entire midrange.
Old 03-20-2013, 07:35 PM
david831's Avatar
Cuztomizing
Im planning on installing an non oem double din touch screen stereo and installing all speakers and gettin a new after market amp and a 10 " sub .... will it be any problems? Ill be using an adaptor to install new stereo that way i dont have to cut wires
Old 03-20-2013, 10:22 PM
Josemartinez Josemartinez is offline
Mein Auto: BMW
Originally Posted by david831 View Post
hi,
im about to upgrade all my speakers and need help since im a newbie. i looked around the forums but didnt find what i was looking for ... how many speakers does my 2000 528i have in total? if i want to replace all of them how will i know wich ones will i need cheap speakers and fit perfectly? im looking to get rockford fostgate for all of my speakers does any one recommend them or any other best brands out there? Any help will be greatly appreciated thanks
What is you thought about sony brand speakers. I think they have finest sound quality
Old 03-20-2013, 11:49 PM
david831's Avatar
Cuztomizing
will these speakers will do for front and back? they are ROCKFORD FOSGATE P152 PUNCH 5.25" 2-way Coaxial Speakers
Configuration: 2-Way Full-Range
Midrange Diameter (in): 5.25"
Midrange Depth (in): 1.81"
(46mm)
Tweeter Diameter (in): 0.75"
(19.0mm)
Tweeter Depth (in):
Frequency Response: 70Hz - 22kHz
Nominal Impedance: 4-Ohm
Power Handling (RMS): 40 Watts RMS
80 Watts MAX
Crossover: n/a - tweeter has built-in crossover
Sensitivity
(dB @ 1 watt/1 meter): 87dB
or the Rockford FOstgate PRIME:
5-1/4" 2-way Prime Series Component System
Power Handling:
Peak: 160 watts per set / 80 watts each side
RMS: 80 watts per set / 40 watts each side
Mylar balanced dome tweeter with an in-line crossover delivers crisp high frequency response
Easy installation of flush, surface, or angle mounting
Mica injected polypropylene cone for extended frequency response and accommodates direct OEM installation
Foam surround allowing fluid movements for accurate sound reproduction
Perfect for original factory replacement
Stamped steel basket
Frequency response: 58 - 20,000 Hz
Crossover Frequency: 12,000 Hz
Sensitivity: 85 dB
Impedance: 4 Ohm
ID:	367449   Click image for larger version
ID:	367450   Click image for larger version
Old 03-21-2013, 12:27 AM
Adamo99 Adamo99 is offline
Mein Auto: e39 530i, e93 335i
Do you know which line/series, is the ideal drop-in replacement for the e39s?
Old 03-21-2013, 12:50 AM
jdodds jdodds is offline
Mein Auto: 01 Dinan 5 540iA
I would install some sound deadener tiles and acoustic foam while you're in there. It helped my stock sound system out quite a bit.
Old 03-24-2013, 10:48 AM
agouraM5 agouraM5 is offline
AgouraM5
Mein Auto: '03 540iA
Talking sound deadening
so where did you fit the tiles and where did you put the foam? can you elaborate on the placement and how much the materials ran? tia...
AgouraM5
Old 03-24-2013, 11:05 AM
david831's Avatar
Cuztomizing
Is this true? I been hearing this from my neighboor... its better sticking the whole car system with one brand (car stereo+speakers = one brand) only because its sounds better. Any one agrees?
Old 03-24-2013, 11:13 AM
Fudman's Avatar
Wrong!
Old 03-24-2013, 11:14 AM
DennisCooper!'s Avatar
DennisCooper! DennisCooper! is online now
Hi David,
You don't have to stick with one manufacturer brand at all if you don't want to. For instance I have an Alpine head unit, Arc Audio Amplifiers and DLS cabin speakers and a JL Audio subwoofer. Some of the 'best' manufacturers of each part of the audio setup, might only make that product - HAT for example only make speakers, DLS and Hertz for instance make excellent speakers and also Amplifiers.
I see you've started multiple threads, I'd suggest perhaps reading up some more on specific car audio forums to learn more as well as across the various BMW forums too. Speak to local reputable car audio installers/dealers as well, and then you can make more of an informed choice of whichever direction it is you wish to go.
If you were anywhere near West London, UK, you'd be more than welcome to have a listen to my setup!
Cheers, Dennis!
Old 03-24-2013, 11:48 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: 2000 DINAN 540, 1983 745
You could look into the BSW system.
2000 Dinan 540 Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Powerflex polyurethane bushings, Dinan stage 2 engine software, Stage 1 trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, Dinan TB, AFE cai, 18" style 5's, 235/40/18 275/35/18, Ultimate cup holders, rear cup holder delete/coin holder, Hella taillights, clear sides, Depo AE, M5 spoiler
1983 745 turbo, style 138 wheels
Old 03-26-2013, 11:36 AM
david831's Avatar
Cuztomizing
wich 5 1/4 woofers you guys recommend buying? do i have to buy any special ones for it?
should i replace all 6 tweaters?
Old 03-28-2013, 12:08 PM
abanjableu's Avatar
abanjableu abanjableu is offline
Mein Auto: 02 540/74 911/01 Z3(hers)
Bsw? They are not overly expensive and are plug and play. They all match that way and not as much mix and match.
