View Poll Results: Would you be interested in a Brake Caliper Upgrade?
Why yes Albo, I certainly would... 15 57.69%
No thanks Albo, I don't think I would.... 8 30.77%
Shaddup you maroon!! You don't know what your talking about!! 3 11.54%
Voters: 26. You may not vote on this poll
Old 03-18-2013, 10:51 PM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
Poll: E39 Performance Caliper Upgrade
This one item has bothered me for some time. I know there are a lot of people that are perfectly happy with the performance of the OEM brakes on their E39's, but I do believe there is performance to be gained over the OEM single piston setup.
I'm hoping I don't have to rehash the benefits of a multi-piston caliper, but in short:
* Lighter Weight
* Less Heat Retention
* Greater Fade Resistance
* Uniform clamping force
Of course, the limiting factor is always price. We often have to buy a kit that includes new (though larger) rotors, brake lines, brackets, etc. I would love to have the option to just upgrade the calipers to offer a reasonable upgrade in performance.
As an automotive "enthusiast", I know that it's often times more economical to purchase a pre-built kit and not always beneficial to "upgrade" components that "work", but I cannot abide.
To that end...I've began discussions with a vendor that is a supporter of this forum to begin an R&D project.
The goals are simple:
a) Discern what manufactured calipers to use (e.g. Willwood,etc.)
b) Manufacture the appropriate brackets to adapt said calipers.
This post is meant to be a discussion on the topic as well as a poll to see how many enthusiasts would be interested in this upgrade.
All comments are welcome, but please keep things on topic.
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 03-19-2013, 07:12 AM
Dragan Dragan is offline
Mein Auto: 2002 BMW 530i Sport 5 Spd
Are we talking like monoblock 4-piston calipers up front? If so, you forgot to mention that they drastically improve the aesthetics of the vehicle.
2002 530i Sport Package 5-speed
Style 42s for summer
Style 29s for winter
CDV delete
Skibag retrofit
G.A.S. DISA Valve Repair Kit
G.A.S. 1.2 Bar Expansion Tank Cap
Old 03-19-2013, 07:59 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Your car brakes fine with OEM setup. Unless you drag race the car, you don't need 2,000+ $ brakes.
ECS had a good promotion on big brakes kit a little while ago, if you still want to change the brakes.
But all you will accomplish is aesthetics only. And higher price of rotors & pads when you will have to replace them.
You will gain "0" performance for a DD.
Old 03-19-2013, 08:58 AM
demas demas is online now
Mein Auto: F10 550i M-Sport
apart from the excitement of this project and possible improved looks, the performance upgrade on the street would be negligible.
Additionally the 530 uses the largest brakes out of the I6's and is more than adequate for daily use.
but all this you know already.
Old 03-19-2013, 09:07 AM
Fir3n5m0ke Fir3n5m0ke is offline
Mein Auto: 2000 540i/6
I guess I'm one of the few but I would definitely appreciate some bigger brakes on this car. While the OEM brakes seem to work just fine, I would love to have some bigger brakes to make it feel more comfortable slowing/stopping at high speeds.
Take a newer 335i. The front calipers/pads seem almost twice the size of the ones on my car and the car is without a doubt a lighter car. The large calipers/pads come on sport model 335i I believe.
Old 03-19-2013, 09:10 AM
uncmozo uncmozo is offline
Mein Auto: 2002 530i 5 speed
Albo-
You haven't mentioned the problems you're having with your OEM setup. Are you looking for shorter braking distance at high speeds, less heat build-up, etc.? Forget the looks for a minute. Mechanically, what are you looking to improve preformance-wise?
Just curious.
Jerry
1995 525i 5 speed - sold at 225,000 miles
2002 530i 5 speed - 187,000 miles
Old 03-19-2013, 10:46 AM
With my backlog of deferred maintenance on my bimmer, I am in awe of those who have everything fixed up to date, and they then can contemplate performance upgrades!
I wish I was more like you!
Old 03-19-2013, 12:58 PM
Albo's Avatar
There is nothing inherently "wrong" with the OEM setup. It works fine when in good repair, but once you've experienced higher performance vehicles with higher performing brakes (yes...monoblock-type setups with 4 or 6 or 8 pistons) then you realize how limited these brakes really are. Any significant increase in power brings you closer to the threshold of that limit. I know I don't drive a 500hp beast, but there is absolutley nothing wrong with taking each area of our "Sport Sedans" to their zenith.
My goal has always been to maintain my cars to the utmost and when possible improve the function (and form) as I see fit.
There are brackets widely available for E36's and E46's that enable owners to adapt a wide array of mulit-piston calipers to suit there needs. I want the ability to do the same.
Something like this:
Old 03-19-2013, 01:25 PM
doru's Avatar
Then do it right. Check:
Big brake kit #1 (BMW OEM setup)
Big brake kit #2 (BMW OEM setup)
Old 03-19-2013, 02:25 PM
Albo's Avatar
I'd like to see if we can beat that price point... And upgrade the rear calipers, too.
Old 03-19-2013, 03:53 PM
DJ63's Avatar
DJ63 DJ63 is offline
Mein Auto: 2001 540/6 2014 328xdT
Because of an unfortunate string of events at my workplace resulting in a Federal trial and alot of spare time on my hands, I recently drove several thousand miles in my 540, at the end of which I realized I had driven the last segment with a frozen caliper L front. Yes, I pulled the trigger on the ECS BBK deal {what the hell else would a E39 guy do, huh? I was Powerless, I`m tellin ya!!!}
Anyways, aesthetics, :thumbup Performance difference for street, like others here say
Old 03-19-2013, 04:22 PM
DJ63's Avatar
BTW, if anyone out there gets the BMW BBK kit, be prepared; it comes mounted with the bracket for the 1 and 3 series that has to be removed. the 10mm Hex bolts were a bitch; 2 guys holding the caliper and 1 on the wrench with a cheater pipe, they were in there.
Old 03-19-2013, 05:06 PM
Albo's Avatar
Something akin to this on the front (though I would likely want a less expensive option):
Old 03-20-2013, 07:36 AM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
I would worry about the adapter for the calipers being strong enough. If you can beet the $1000 mark I think you would find plenty of interest.
1997 BMW 540i
Old 03-20-2013, 08:01 AM
DJ63's Avatar
The stock bracket is just a piece of cast iron, nothing special.
Old 03-20-2013, 08:07 AM
carlova78 carlova78 is offline
Mein Auto: e39 530i 5SP/e60 530i
M5 brake upgrade.
Old 03-20-2013, 09:23 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
+1
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, Euro Lens, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza Orion halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks with H&R Sport Springs, 19" M6 Reps, Full LEDs.
Old 03-20-2013, 10:10 AM
Albo's Avatar
Originally Posted by carlova78 View Post
M5 brake upgrade.
That does virtually nothing to address the "pluses" highlighted in my original post. The M5 system, while still effective , is just a bigger version of the OEM system.
If I'm going to updgrade the suspension, engine and interior, then I sure as **** want to get the best out of my brakes.
BTW...brakes that are "adequate" at 230hp are less so at 330hp (supercharger) and, if that LSX Swap ever happens, even less so at 400,500 or 600 hp (Maybe I'm day-dreaming there).
Like I said...Similar options exist for E36's and E46's. I just want the same option for the E39.
Old 03-20-2013, 10:25 AM
Albo's Avatar
When we get to that point we'll address it. I'm sure they won't be cobbled together with scrap metal or tin foil.
The company I'm trying to entice into the propisition is a known commodity on this forum. I've got samples of there work on my car and waiting to go on as well. they have my confidence.
Old 03-20-2013, 05:47 PM
Albo's Avatar
Bump.. 360 views, but only 15 votes. Give me a brake!
Old 03-20-2013, 07:08 PM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
If its under 1000 bux... i would be interested. But I would not be surprised if you actually lost interest in this project and went with ECS tuning kit. Its ridiculous for any aftermarket set up your trying to do to these cars without shelling out TONS of money. My radiator took a crap the other day (10 years of service, not bad) and i was thinking of going with aluminum set up. 600 bux + shipping? Not going to happen, while for my buddy's car, eagle talon, he payed 130 some bux for all aluminum radiator shipped to his door. I just went with Nissen radiator (120 bux) cause its not worth shelling out that kind of money...
Keep us posted!
Old 03-20-2013, 07:53 PM
occhis occhis is offline
Mein Auto: 1998 528iA
I am not debating the benefits of such an upgrade, but I question the relationship between hp and braking ability. It's a mass (weight) to speed ratio that determines the efficiency of the braking system. If one wants to stop a 4000 lb car going 100 mph, it doesn't matter how fast you arrived at 100 mph.
Either you are part of the solution, or you are part of the problem.
Old 03-20-2013, 08:41 PM
Albo's Avatar
The relationship is not directly with horsepower, but better brakes can always help get a driver out of trouble because of it. Of course...it doesn't hurt to learn how to drive, either.
Old 03-20-2013, 09:14 PM
I'll keep track of this thread, as I'm sure you will find a solution at a reasonable price point.
Old 03-20-2013, 09:15 PM
Just for the record, I'm wearing my "I Voted" lapel sticker.
bbk, caliper
