Old 03-20-2013, 12:45 AM
jennyjo7 jennyjo7 is offline
Mein Auto: 2001 530i
Camshaft Position Sensor - Intake
I have a 2001 530i a couple weeks ago my SES light came on, so i went and got it scanned, and had the code P0344, intake cam position sensor, however haven't had the money to get it fixed. The light went off and ran fine for a while, but then came back on, and has stalled 2 times while at low RPMs.
The light has gone off again, and has been off for a 4 or 5 days now, and hasn't stalled.
However, I'm scared to go on the freeway for fear that my car is going to die on me.
1. How long can i drive with it like this?
2. How much would it cost to get this fixed at the BMW dealership?
Thank you in advance!
Old 03-20-2013, 04:40 AM
diggyd357's Avatar
diggyd357 diggyd357 is offline
Mein Auto: 97 528I
It's a fairly straight forward diy and a good oem sensor can be found online for around $ 100. As far as taking it in to a dealer....I've heard as little as 3-$ 500 and as much as $ 1000. I guess it depends on where you take it and how much they think they can charge you without you storming out in a hail of obscenities. Unless money is no object for you (and since you're asking about prices I'm assuming it is) this may be a good time to pull the trigger on learning to work on your car. It's an e39, chances are you will need to make repairs again of some sort in the near future and changing out a cps is a good , easy, inexpensive way to build some confidence in doing your own repair. Fixing something yourself gives a great feeling of accomplishment and with the help from the people here at the fest anyone can do it. Good luck !
Old 03-20-2013, 05:17 AM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
See your other post and my response.
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 03-20-2013, 10:23 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
diggyd357, I suspect that jennyjo7 would prefer to keep her hands out from under the greasy hood.
jennyjo7, consider an independent BMW garage, instead of the dealer. Most often, they are superior, if not cheaper.
Try www.bimrs.org for a referral, or ask fellow BMW owners.
Old 11-25-2013, 09:56 PM
2002530 2002530 is offline
Mein Auto: 2002 530i
where does cam pos sensor plug into?
Hi. I have replaced the cam position sensor three times now, twice with aftermarket, and now with a BMW one. (on 2002 530i). But the "intermittent cam sensor bank 1" keeps coming back. Car runs, but gas mileage is terrible. Where does the cam sensor plug into? Anybody any suggestions what could be the problem?
Old 11-26-2013, 07:05 PM
If it helps, typing /cps f3 in the bestlinks nets this:
- How to replace your camshaft position sensor (CPS) in the E39 (1) (2) (M62) & E46 (1) & ('99 740iL)
Old 11-26-2013, 09:36 PM
continued Cam Pos Sensor code
Thanks Bluebee,
Did not have problems replacing the sensor. (have a lot of experience now...).
The "intermittent code" keeps comimg back. Mileage still 20 to 25% worse than normal.
What else could it be? Issues with crank case ventilation? Vent hose from cover showed yellow foam inside. What does the cam sensor plug into? I wanted to look further "upstream" for the cause of the "intermittent". I even added some conductive grease to the pins of the connector (very little with a toothpick. (I did not want it to melt and run through my connector). Other subject: where can I get the wire clips for the connectors? They seem to get away from me in my "not museum like" work area (a.k.a my drive way...)
Old 01-06-2014, 07:13 PM
speedchase speedchase is offline
Mein Auto: 2001 540i MT M62
I have code P0348: Camshaft Position Sensor 'A' Circuit High Bank 2. I am guessing this is the sensor on the Driver side (USA , LHD). Can you someone please confirm if the part is interchangeable between the left side and the right side; not sure if the part # is same and I don't want to end ordering the wrong part 3.
Recently moved to Dallas,TX and the car failed the vehicle inspection due to this error although I think this does not cause any emission issue.
2001 540i MT - Still a newbie until I change my VCG, VANOS & Coolant system...
Repairs so far - Steering fluid pump ($1k - Indy), CCV replacement ($1k hosed to another Indy) & Axle replacement ($850 to another indy).. 3 indys to date and now I am diving all in as a DIY'er
Old 01-07-2014, 10:29 PM
Hi Speedchase,
My code (P0369 Powertrain Camshaft Position Sensor "B" Circuit Intermittent (Bank 1) turned out to be the one on the front/passenger side (it sticks into the engine from the front, about in line with the coolant tank. A metal shielded cable runs to it.
The two sensors "the one behind the vanos solenoid" and the one I just described are not interchangeable. The one behind the Vanos, which is the one I think you need (no guarantees though), has a cable attached to it. There are some youtube videos to show you how to change it.
I had no problem with the allen head screw on the one behind the vanos solenoid. The other one though was a bear. After stripping the internal hex I tried everything (using an eazyout and grinding a screwdriver slot). Nothing worked until I tried an old trick as last resort and that worked. I had to tap the top of the bolt with a ball-peen hammer, and then I could almost take it out by hand. They put a locktite type paste on the bolt and by tapping it (mine had been in there for 12 years...) it let go and it came out. It is a 30 minute job. Don't lose the clips for the electral connectors.... and watch the youtube videos.
Good luck. Pls post here how you made out.
Best regards,
Old 01-08-2014, 11:21 AM
@2002530 - Thanks for the info!
Old 01-08-2014, 12:37 PM
joelselman joelselman is offline
Mein Auto: 05 Z4 3.0i smg, 01 530ia
While it may be the sensor itself, I believe I've read that a malfunction in the vanos unit (seals? etc) can trigger this fault code.
Old 01-08-2014, 06:17 PM
Is that not the case if there is an error for exhaust CPS malfunction vs. the inlet ones?
Old 01-23-2014, 09:46 AM
Replaced my bank 2 CPS with the sensor I bought from RMEuropean for $80.76 and it was a breeze replacing this one on the driver side (US version). The Service engine light went out after driving for about 10 miles and it was a comfort since the parts stores (Autozone, etc) don't clear codes in TX. The car passed the inspection as well.
The car runs smoother and I am hoping the mileage improve as well. I will report back on the mileage improvement, if any.
Old 11-23-2014, 12:39 PM
topbasura topbasura is offline
topbasura
Send a message via AIM to topbasura Send a message via Yahoo to topbasura
Mein Auto: 2001 BMW X5 3.0
good morning everyone,
I have a 2001 BMX X5 3.0, I am also trying to clear a P)369 code Camshaft position sensor B circuit intermittent Bank 1. From everything I have read is the one in the intake side which is located right next to the vanos oil solenoid . Changed out the camshaft sensor and the code went away but after a 4 days code came back. Does anyone have any idea what it may be? I did not use an original BMW part could this be the issue?
Old 11-23-2014, 03:17 PM
rac421 rac421 is offline
Mein Auto: 540i msport
After-market sensors are a poor bargain and often work only a few days before throwing codes again. Oddly enough your corner Autozone parts store has these and they are the actual BMW part with the oem "BMW" embossed on them. Only a $100. last month. I had to replace two generic ones before this fixed the problem (intake side). It takes about ten minutes to change this. No codes after a month of hard driving. If you are not up to the job, try to get a mechanically inclined friend to do it for you... or, buy the part and take it to an Indy to do the work. This will save you from getting ripped on the part and installation shouldn't be more than fifty bucks (still a rip for this simple job).
540i, M sports package, Dinan intake and tune, six speed.
530i, asap, bmw, camshaft, position, sensor
