#51
Either that, or one of them is mis-named in the engineering diagrams (I'd suspect the vacuum diagram since it is already known to be wrong in other areas).
Hmmm... a 'fuel' SJP. |
#52
I think the name should actually be suction jet pump. It was poorly translated from the German.
The term "jet pump" describes a device that uses a venturi to move fluids, like shallow well pumps. The BMW design engineers used the same type of device to solve two different problems. I think the term is appropriately applied to both the brake booster SJP and the fuel tank SJP.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
#53
Wow, this thread has really taken off. I have been trying to hunt down the cause of my PO171/174 codes. That is where the thread "Different Scanner , New Codes" originated.
The other day I decided that I would go ahead and cut the clamps to the SJP and inspect it. The pump itself appeared to be fine. However, the hose from the intake to the pump had somehow wore itselfdown to the inner linnings. I went to Napa and had a new hose cut to replace the worn one out. This did not work because of two reasons - 1. The OEM hose is form fitted to allow the brake booster hose and the vacuum line from air boot to line up correctly (On the 540). The new hose was not strong enough to handle the curving requiered. This made the hose pinch. 2. The same hose is flared out so it can connect to the jet pump correctly. I managed to get the hose on but damn near developed a case of carpil tunnel. I ended up buying the correct hose from EAC which should be here today or tomorrow . Another problem I encountered was the line to the brake booster. It was showing its age. When I tried to reconnect the jet pump back on, the hose just started splitting. So I ordered a new hose for the booster as well. I just hope I dont break the fitting to the booster while trying to remove the old hose. I will report back today or tomorrow to confirm that my codes have been resolved.
Steve530, over here today, found an excellent picture of the sucking jet pump elusive connection to the intake manifold in the back of the M54 engine:
- For all to benefit, WHERE are the ends of these hoses in our beloved E39s anyway? Quote:
#55
Here's more information just now from Steve530 on the location of the manifold vacuum to brake booster suction jet pump:
just to add to this post
i saw where the top had come off of the vacuum multiplier. I had this happen to me while changing out my ccv. in looking closely as to how it is put together...they glued the top where the check valves are... to the body...you can see the red ring is a small amount of glue without removing it from the car i carefully glued it back together in a similar way....be sure not to put too much on there so none gets on the check valves. just around the edge...then seal the top with a thin layer around the edges. it is stronger than it was before and sealed better around the top. I carefully scraped the old glue off until i liked the fit....it fits in there very snug almost like it would have sealed without being glued. keep in mind you should test fit it a couple of times in there before you use the glue....it can only go in 1 way...it cannot be turned clock or counter clockwise in the housing and the glue dries withing 5 minutes. it was a 2 part epoxy plastic adhesive.... when i priced this part is was over $100 and included the vacuum lines. The glue was $8 plastic glue from autozone.....i did smoke test for vacuum leaks....non found Last edited by glhx; 02-29-2012 at 05:48 AM. |
#57
The venturi description is correct. There's two (orange) check valves on the booster because the non-venturi side gets the booster pressure down fast to one level, then the venturi side takes the booster pressure down lower to another level. |
#58
For the record, today I decided to clean my ICV and in order to get to the clamp bolts for the boot over the ICV, I had to disconnect the Torx holding the sucking jet pump venturi valve to the M54 engine.
Here's a picture for your edification:
#59
Does anyone know where the sucking jet pump is supposed to mount on a pre-98 M52? Mine just kind of hangs there in the engine bay, supported by it's hoses. I don't think that's right ![]() Stuart |
#60
I was looking for a picture for another user's question when I ran into this nice photo by Michel showing the 2002 525i SJP in situ.
#61
For the crosslinked record, this useful information was posted today:
#62
For the record, the SJP 'might' be implicated in Poolman's situation today:
#63
| Tags |
| lean condition, misfire, sucking jet pump, vacuum hose, vacuum leaks |
