Old 03-18-2013, 07:34 AM
gebhardt gebhardt is offline
Mein Auto: BMW 645 2005
Front PDC sensor removal
Hi all,
My 2004 645ci coupe keeps giving me a PDC fault.
Using INPA I have traced the fault to the front right centre sensor (error code 9E3A)
Has anyone changed one and if so do you have to remove the front bumper?
Neil -G-
Old 03-18-2013, 07:47 AM
you might be able to get to the two center PDC's by going through the grill. But the bumper takes about 10 minutes to remove, here is a link to a previous thread. In it is some info for you along with info on how to remove the bumper should you find it necessary.
http://www.bimmerfest.com/forums/sho...d.php?t=586841
Old 03-18-2013, 09:03 AM
Thumbs up
Thanks for the speedy reply will order a new sensor today and give it a go at the weekend.
Only problem is not sure if I can live with the bong bong till then.
Once again many thanks
Neil-G-
Old 03-18-2013, 02:09 PM
HerbP HerbP is offline
You can not get to the 2 center sensors, without removing the bumper cover. Is your PDC giving you a fault at startup, or beeping constantly? I just got through replacing my front wiring harness this weekend, for the same senor problem. The harness ohm out good, but replacing it fixed the problem. If you buy a new sensor, it needs to be the correct color. Painting them will add extra layers of paint, causing problems with the system. The wiring harness was 64.00.
Old 03-19-2013, 02:27 AM
Thanks for the reply I have ordered one from eBay should get it on Thursday.
Will have a go at changing it at the weekend UK weather permitting.
Cheers
Neil-G-
Old 03-19-2013, 02:54 AM
645/333's Avatar
645/333 645/333 is offline
Michael
You can reduce the volume of the ping in your Idrive!!
Old 03-19-2013, 06:04 AM
V8esp V8esp is offline
Mein Auto: 645ci
Neil-G-
I have the same issue, so would be interested in an update when you're done - also where you get your sensor from
You can turn off the PDC via the idrive to get rid of the bong for now...
Old 03-19-2013, 09:00 AM
Hi V8esp tried turning off the pdc in I drive but still get the error bong when I start up.
I have ordered the sensor from eBay used real oem to get the required part number.
Will give you an update when I have fitted it but can't see it being before early next week.
Do you know which sensor has failed on your car?
I used INPA to trace my faulty sensor
I think the front looks easier than the rear to replace.
Cheers
Neil-G-
Old 03-19-2013, 09:09 AM
Mein Auto: 645ci
Hi,
I have plugged in INPA and get the same error as you - not sure where you reference the error code though but I think it's the corner sensor as I can't hear any clicking from that one when activated.
How much did the sensor set you back? and have you got the part no to had?
Cheers
Linc
Old 03-19-2013, 10:16 AM
Hi Linc
What colour is your car?
If you go into real oem and search for pdc the sensors are part no 2
They all end in a different number depending on the colour you require
Mine colour is sapphire black and I think off the top of my head it ended in 90
I got mine from eBay and got it for 20 including postage (new and in the box)
Let me know if you have a problem finding the part number you require.
Cheers
Neil-G-
Old 03-20-2013, 03:05 PM
Mein Auto: 645ci
Hi, it's titan silver, cant see any on ebay so may have to buy a plain one
and spray it!
Old 03-21-2013, 07:04 AM
Hi mate,
I have found one on ebay that will fit your car.
It is off a E60 but they are the same as the E63.
Sorry I dont know how to add a link so you will just have to follow the instructions below.
Go to ebay motor parts
Enter in the search bar BMW E60 pdc
If you scroll down to the ninth pdc that is the one you want.
You can either bid on it or pay the 34.99
I will be having a go at fixing mine next Thursday in work till then.
I will let you know how i get on.
Cheers
Neil -G-
Old 03-28-2013, 05:14 AM
Mein Auto: 645ci
Hi mate,
Cheers
Neil -G-
Hi Neil,
I ordered a plain black one in the end and sprayed it - 19, probably from the same guy as you. Anyway, just finished fitting this morning and it's all working fine - got my pdc working at last so I'm a happy man!!!
The one I replaced was a front offside corner - near the headlight washer...
It wasn't a bad job but probably not the best day to do it as its chuffin freezin - let me know how you get on and give me a shout if you need any help with bumper removal..
Linc
Old 03-28-2013, 11:56 AM
Hi Linc,
Made up to hear you got it working.
I have put mine on hold was going to do it today but it was freezing.
Might have a go at the weekend,
How long did it take you and was it easy to get the front bumper off.?
Did you take the bumper right off and ifso did you have to take out the fog lights
Cheers
Neil
Old 04-02-2013, 02:00 AM
Mein Auto: 645ci
Hi Neil,
The bumper was pretty easy to get off, took about 15 mins. You can get at all the bolts ok, just follow the instructions in the thread, otherwise you probably wouldn't know where to look. The trickiest screws are just inside the bumper. So, when you peel back the inner arch there are 2 screws just behind the headlight. When all the screws are out the bumper will just pull forward.
I didn't have to disconnect anything else as you can get to the sensors if you just rest the bumper on the floor.
Cheers
Linc
Old 12-26-2014, 03:11 PM
GoBux GoBux is offline
Mein Auto:
IF this helps anyone out there - Replacing PDC center front sensors on a 2011 335 or similar:
EASY and quick and by doing yourself will save you about $891 , YES $891 - my dealership was going to charge me $891.04 to replace a PDC sensor that was damaged -I found one on ebay for $35 and replaced it myself in about 20 minutes!
To replace either of the 2 front center sensors you do not need to take off the entire bumper...simply remove the (4) Torx head screws on the top of the bumper under the front of the hood (lifted of course)... then gently pull the bumper forward to access the clips on the grill and remove the grill - once removed all you need to do is pull up and back the rubber seal sitting in the grill space and access the PDC. There are 2 clips holding the PDC sensor in place just pull each out slightly and the PDC will come out the back - then just replace with the new sensor - and that is all - reverse process to reinstall bumper and you are done!
Old 02-07-2015, 01:08 PM
bojan bmw e60 bojan bmw e60 is offline
Mein Auto: BMW e60 530xd
Is it possible to acces the front right PDC sensor located under the headlight washer from the actual headlight bay by removing the headlight? It will be much easier to remove the headlight then the bumper.
Old 02-07-2015, 02:26 PM
roseng's Avatar
roseng roseng is offline
You have to remove the bumper to remove the headlight. There are several DIYs on bumper removal. It's surprisingly easy and fast.
Old 02-07-2015, 03:10 PM
sentrex sentrex is offline
Mein Auto: 645ci convertible 2004
Roseng,is right you have to remove the front bumper to get at the lights,it took me 30 minutes to remove the bumper and i've never done it before,real easy job
