Old 03-20-2013, 02:40 PM
E60black E60black is offline
Mein Auto: 545i
Bought a '99 528i....overheating, pulled codes
Got my hands on a cheap '99 528i, car was smoking white thicker than average smoke...overheated on the way home. Needle didnt completely hit the end of the red however it remained in the red. I'm thinking blown head gasket or cracked head...
Old 03-20-2013, 03:45 PM
Tkarrde Tkarrde is offline
Mein Auto: 2000 528 Build Date 10/99
These cars really dont like to overheat -- if it gets in the red you need to shut them off ASAP.
Have it pressure tested but coupled with the white smoke it does sound like a head failure.
Old 03-20-2013, 03:47 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Vacuum leak can cause a lean mixture.
At very least, do a compression measurement and/or cooling system pressure test.
Old 03-20-2013, 07:55 PM
Mein Auto: 545i
Ya it's hard to say how long it's been overheating since it was at an auction but I'll assume the worst for now. Hoping for a non-cracked head after my Indy tears it down tmrw.
Car is pretty solid otherwise, sad to see it overheat.
Any other components/parts I should replace while its apart? It's a 1999 528i with 160k, no leaks as of yet...
Old 03-20-2013, 08:19 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Entire cooling system.
http://www.bimmerboard.com/forums/posts/199986
Either you are part of the solution, or you are part of the problem.
Old 03-21-2013, 04:12 PM
IndiansFan's Avatar
IndiansFan IndiansFan is offline
Mein Auto: '99 528iA
Suspension - front and rear.
Either write something worth reading or do something worth writing.
Benjamin Franklin
2004 X3 2.5 TITANIUM SILVER/Grey - Sport/Premium Package
2001 530iA STEEL BLUE/Sand - Sport/Premium/Cold Package
1999 528iA JET BLACK/Black - Sport/Premium/Heated Seats
1982 Fiat 2000 Spider - BLUE METALLIC/Blue
1999 528iT CASHMERE BEIGE/Sand - Sport/Premium Package - 5 speed SOLD
1989 535i SALMON SILVER/Black SOLD
