E39 DSC works, but can not switch off - Bimmerfest - BMW Forums
Old 03-20-2013, 04:15 AM
Makomagnet Makomagnet is offline
Mein Auto: 2001 525
I have bmw e39 2001 525 and DSC light is not coming on when i press the DSC button, however when i switch the ignition on yellow triangle light comes on and goes off which how it should be. can any one help me.
Old 03-20-2013, 06:58 AM
QSilver7's Avatar
Is this a new development or has it been like this for a while? And if it's been a while...did it occur around the time some other work or other malfunction/change/upgrade/mod occurred?
If you have diagnostic software/hardware, you could always hook it up and communicate with the control modules to see if there's a fault code registered...anything other than that will be a guess at what it could be if there's no other signs or symptoms that might lead us in some direction.
Q {BMW CCA Member #191509}
(SOLD)
Old 03-20-2013, 07:23 AM
Minimal BMW Minimal BMW is offline
Mein Auto: bmw
i had the same problem with ASC, an it was the ABS module problem, one very very thin wire was damaged in abs module
sorry for English
Old 03-20-2013, 06:21 PM
Mein Auto: 2001 525
QSilver7 thanks for the reply. A couple of years ago I replaced the LCM and it was not coded. Could that be the issue? As I remember I've been having this issue for a couple of years.
I don't have the tools to interrogation the software you mention, and I'm sure no one else went in there.
Any suggestions that may help identify where the problem is ?
Old 03-21-2013, 12:19 AM
mjalloul11's Avatar
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Did you try another switch? could be the reason why it wont shut down . The DSC will always stay on and only the switch can turn it off, or if something is wrong with it and then the light on the dash will be on all the time.
Old 03-21-2013, 12:36 PM
Mein Auto: 2001 525
I replaced the switch from a junkyard. No change. The strange thing was they were different part numbers. When I look up on real OEM it shows the part number I picked at the junkyard, not the previous switch. At one time it did work with the old switch.
Old 03-21-2013, 07:01 PM
senser senser is offline
Mein Auto: 540i/6 E39
Your master cylinder could be low on brake fluid.
Old 03-22-2013, 03:16 AM
Mein Auto: 2001 525
I just purchased another switch off of EBay but will check my brake fluid this weekend.
Low on brake fluid could do that ?
It's worth a try
Old 03-22-2013, 11:26 AM
mjalloul11's Avatar
BMW forever
Wont a low brake fluied triger the light on the dash?
Sent from my GT-I9300 using Bimmer App
Working on my car is a pastime
Old 03-27-2013, 03:14 AM
Mein Auto: 2001 525
Installed new DSC switch hoping to toggle DSC system, switch made no change. It's not a bad switch.
What else is there ?
Old 03-27-2013, 10:37 PM
Yes, the light that's triggered is the DSC light. Nothing else. When the master cylinder gets low the DSC light will be solid on.
I did a full brake flush using the pressurized method and a few bottles of BMW brake fluid and the light went away for good.
Old 03-28-2013, 12:54 AM
mjalloul11's Avatar
BMW forever
There is a red light in the dash a circle with doted lines around, it lights up when the pads are worn or the brake fluied is low .
Old 03-29-2013, 06:42 PM
Mein Auto: 2001 525
Not brakes, not fluid level, not DSC switch. Is there a fuse or harness I can check the the switch is sending a "turn off" signal ?
Old 03-30-2013, 01:12 PM
QSilver7's Avatar
I think there may be multiple fuses due to there being underlying systems that work with DSC. Check the front fuse box (there should be a pull out fuse index card when you open the fuse flap in the glove box) and the rear fuse box (should be a fuse index on back of battery compartment door) and look for anything that has to do with ABS, ASC (automatic stability control), and/or DSC/DBC (dynamic stability control/dynamic braking control).
Again, there may multiple areas that a fuse related with traction control can be since ABS/ASC/DSC/DBC all work in conjunction with one another (not all e39s may have all of the systems aforementioned).
(e39 glove box fuses)
Check fuses #17/#30/#31
(SOLD)
Old 03-31-2013, 09:03 AM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
You think?! LCM needs to be coded for at least the mileage.
Get the codes read; too many options to guess. Extremely common. http://www.bimmerfest.com/wiki/index...S_Control_Unit
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 03-31-2013, 03:14 PM
Mein Auto: 2001 525
Qsilver7. Thank you for the information and experience.
The DSC switch now works. Fuse # 17 was missing and nothing was there. I replaced it and it now works as designed.
What is the amperage of the red fuses ?
Thank everyone who contributed
