need more help - Bimmerfest - BMW Forums
Old 03-17-2013, 08:58 PM
jordan101 jordan101 is offline
Mein Auto: 1998 740il
need more help
im having a lot of probs with this car . it runs great. heres whats wrong. I was sitting in my driveway idling and all of the sudden car dies. I put it in park shut it off tried starting it. It runs then dies only way it will stay running is if I give it gas then the traction control light comes on and stays on I cant turn it off. The check engine light came on. Any ideas of what this could be. I don't know what to do.
Old 03-20-2013, 08:19 PM
sealbeach740 sealbeach740 is online now
Mein Auto: 2000 740iS, 2003 540iS
Get your codes read first.
That would be a good place to start out figuring out what's going on with your 7.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 03-20-2013, 09:05 PM
No engine light on.
Old 03-20-2013, 10:27 PM
The check engine light left codes stored in memory, I believe.
Also, I'd suggest you double & triple check your battery. I had a low battery in my 540 (but it would still start OK), and it would die, restart & drive, but die again.
New battery & I was good to go. Not saying this is your problem, but with some code info we'd know a lot more.
Old 03-20-2013, 10:54 PM
I went to go get my codes checked and engibe light with off and code scanner couldnt pull anything up.
Old 03-21-2013, 04:27 AM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
Can you get a BMW specific code reader like a peake code reader?
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 03-21-2013, 11:29 AM
Im thinking muy battety is way too small. The guy I bought it from put a 650 cca battery in it and factory is 950. I was told 850 minimum. Would this cause a stall.
Old 03-21-2013, 03:09 PM
Ok so on my way home it stalled again and cel came on. I went straight to oreily and the code that came up was the mass air flow circuit.
Old 03-28-2013, 03:43 PM
Mcwalner Mcwalner is offline
Mein Auto: BMW 740 IL 2001
Where can i find an engine used for my BMW 740 IL 2001? Please help me find a credible place.
