E34 (1989 - 1995)
Old 03-07-2013, 08:06 PM
Dionte Dionte is offline
Drive her like an ///M
Mein Auto: 1992 BMW 535i (manual)
Bad catylatic converter? Or installation?
Needle moves slightly up and down during idle.
Check Engine light comes on during idle and occasionally comes on during drive at a steady speed.
Throttle delay.
Car starts to smell like gas during idle.(Inside and outside the car)
When you floor it you don't feel much acceleration.
Just overall feels like the car lost quite some horespower after the original catylatic converter got stolen.( Cant even spin the wheels anymore lol)
Could it be something simple to fix on the catylatic converter, or should i think about replacing it?
All suggestions are appreciated!
1992 535i 5 speed
Old 03-08-2013, 05:39 AM
The Ornery Old Man
Mein Auto: GTI
Have you pulled the codes using the stomp test yet? Sounds like you may have a bad O2 sensor.
How/Why does someone steal a catalytic convertor off a car? I realize there is some precious metal in the cat but the amount of work to remove it doesn't seem justified.
Maybe... the O2 sensor failed, ruined the convertor and it was removed because it was blocking the exhaust?
If anything the car should run better without it.
There is no fix for the convertor, it is a sealed unit, replacement is the only option.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 03-08-2013, 08:09 AM
Ok thanks, so replacing the O2 sensor wont do any good?
Old 03-08-2013, 12:44 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
cats are worth a lot of money, especially to someone that knows what they are doing once they have it.
i have bolded above what my thoughts exactly are
E30 above Sold
Last updated 2nd January 2014
Old 03-09-2013, 12:26 AM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
I wonder if it has an o2 sensor at all. Most metal thieves don't carry a o2 socket.
Oh we stole your cat. but keep you sensor...
Old 03-22-2013, 08:00 AM
Haha, but I'm sure that the one I got came with an o2 sensor.
1992 535i 5-Speed
Douglasville, Georgia
Old 03-25-2013, 08:08 AM
I've been doing some research about my rough idle. Stays around 500 rpm but slightly moves down to about 300 rpm then back up to 500 rpm. Check engine light also goes on and off (Mainly at a complete stop, then goes away during drive) & acceleration is kind of slow/hesitant. Someone said that they replaced their spark plugs and it did the job. Someone elses also said that it may be a vaccum leak. It could be the o2 sensor but the catalytic converter came in good condition with the sensor. Question, could seafoam and or fuel injection cleaner make a difference as well? Because i know that the car's engine hasn't been maintained in a while. Thanks in advance.
1992 535i 5-Speed
Old 03-25-2013, 11:35 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
As said above, you need to pull the codes; either via the stomp test or using a code reader. Otherwise, you are just stabbing in the dark.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-26-2013, 06:05 PM
Thanks but i can't do the stomp test. I would go to autozone or something, but they only diagnose cars years 1996 and up.
1992 535i 5-Speed
Old 03-26-2013, 07:29 PM
BMR_LVR's Avatar
Humble E34 lover
Don't take this wrong, but perhaps you are not doing the stomp test correctly. There have been many before you who couldn't do it at first.
If you will post a video of your attempts, we can see if you are doing it right or not. Several here posted their attempts and we were able to see the problem with their technique and were able to help them do it right.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-26-2013, 09:34 PM
The thing is, my OBC is not connected lol. The radio got stolen out of the car a while back and they ripped out the whole center and cut the cable to the OBC. I need to find the correct part online so i can replace it and be a able to do the stomp test.
1992 535i 5-Speed
Old 03-26-2013, 11:07 PM
M540FELLA's Avatar
Josh
Your obc missing shouldn't matter. That's just a computer that keeps up time, outside temp, etc. It has nothing to do with actually controlling the engine. The computer that controls the engine is what's called a DME and I can guarantee that they didn't steal it.
Watch this vid and go and try it please! It's the only way we can help you any farther.
Turn ignition to position 2 and press gas to the floor five times. It's a four digit code.For example the code from the video: One blink means 1, goes out for 1/2 sec., Two blinks means 2, goes out for 1/2 sec.,Two blinks means 2, goes out for 1/2 sec.,One blink means 1 which means your code is 1221.
Old 03-27-2013, 06:25 AM
Oh ok, thanks. I really thought that the codes came up on the OBC. I'll give it a try.
1992 535i 5-Speed
Old 03-27-2013, 02:19 PM
BMWFatherFigure's Avatar
BMWFatherFigure BMWFatherFigure is online now
Old School
You seem to have over fuel problems. Could be sensors telling the DME lies or bad injectors etc. O2 sensor and injector rig clean first, and check for vacuum leaks. Then go on form there. +1 on stomp test too.
Current:
E38 Parts Car
Previous:
Old 08-08-2013, 08:06 AM
Quick update, I've replaced the vaccum lines a few weeks ago but i already knew that the o2 sensor was failing. I'm getting the o2 sensor replaced this weekend. Could it be possible that my performance may not increase as much due to the o2 sensor fauling the catylatic converter?
1992 535i 5-Speed
Old 08-08-2013, 05:38 PM
south26 south26 is online now
Mein Auto: 535i 1989
Heck I just got 150 for a 525i cat and I was happy. The place even paid for shipping. Only took about 20 minutes with my angle grinder.
Andy
Old 08-10-2013, 08:25 PM
Robinson Crusoe Robinson Crusoe is offline
Mein Auto: 1994 530i 195k miles
Meth is a hell of a drug
Old 08-26-2013, 09:13 AM
After the o2 sensor replacement, she idles perfectly now and is way more responsive than ever!
1992 535i 5-Speed
