Old 03-22-2013, 11:33 AM
deans745 deans745 is offline
Mein Auto: 2004 BMW 745Li
got a tire changed locally and got this message 5 mins down the road
http://i26.photobucket.com/albums/c1...g?t=1363973564
Old 03-22-2013, 11:38 AM
samadkins29's Avatar
samadkins29 samadkins29 is offline
Mein Auto: '03 745Li
Try reseting the TPMS or TPM system in the Idrive. But I would head back to the shop tha just did the service.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 11:40 AM
Tpm
I tried that- does nothing!
Old 03-22-2013, 11:43 AM
Do you have a DTC light on as well? (on the dash) If it just happened now, they had to have knocked something off.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 11:45 AM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
Hopefully you are back at the shop showing them the problem.
Sent from my SAMSUNG-SGH-I317 using Bimmer App
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 03-22-2013, 12:00 PM
yes, the DTC light is on , the emergency brake light, the parking brake light, the works... the shop was a general tire and of course they claim no responsibility. does anyone know of anything that could have been knocked loose that would cause this?
Old 03-22-2013, 12:03 PM
Wheel speed sensor, but that all relates to the TPM. It sounds like the ABS module is bad (which will light all those up). Not sure what to tell you. If the brake sensor was knocked out or damaged I think it would give you the brake warning only. Lets start with which wheel was worked on and why?
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 12:04 PM
rear driver tires was replaced... it was worn badly.
Old 03-22-2013, 12:10 PM
If im not mistaken teh brake pad sensors are back right (passenger) and front left (driver). Does your car use TPM or TPMS? I have TPMS so i dont know what teh other style looks like in the menu. While researching my blown ABS module I found many threads relating to bad wheel sensors. (RDC? dont quote me on that though). I know the 2004 came with both types of systems.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 12:16 PM
my car uses TPM....knucklehead could of knocked it loose from the rim??
Old 03-22-2013, 12:20 PM
I can almost 100% say thats it. Its not on the rim side though. I think it attached to the wheel well(not sure sorry). TPMS are the ones inside the tire (like mine).
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 12:22 PM
then mine is TPMS because its on the inside of the rim...you see the little box when they are changing tires.... how do i fix this problem?
Old 03-22-2013, 12:27 PM
Well now I am confused. The TPMS is inside the actual tire (not visible). The box maybe the TPM or it might be the magnets used to balance the tires. But following up on that is a start.
-EDIT_ sorry, miss read your post. Your correct. Although it would be hard to knock the TPMS loose. The until is attached to the tire stem (to inflate the tires)
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 12:30 PM
Db750's Avatar
David
I rode 22s with no tpms sensor for over a year. If the sensors are messed up or not in place all you get is a flat tire warning. The other system is called FTM I believe
You need to get back to that damn shop and show them the problem. The longer you drive around like that the easier it will be for them to make an excuse.
Also, I am not sure about your laws, but I know here in kentucky a tire shop is required by law to make sure the tpms sensors are working before releasing a car.
If one of those gets knocked out, you wont get an ABS light. You will get a TPMS error light or flat tire warning.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 01:19 PM
the shop told me they did nothing wrong...just changed the tire is all.... so pissed...ready to burn the car
Old 03-22-2013, 01:23 PM
and another thing....when i start the car all the lights are off- i drive about 1/8 of a mile and all hell breaks lose.
Old 03-22-2013, 01:39 PM
I hate to say this. But that really doesnt sound like it could be cause by anything the shop did. The left rear tire doesnt house anything to my knowledge. And the TPMS being possibly broken wont cause the car to spaz out like that. I almost want to say disconnect teh battery cables and reconnect them. I am at the max of my knowledge and ideas at this point. Kinda pissed that the shop is not atleast trying to help you.....
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
Old 03-22-2013, 01:40 PM
disconnect both cables? for how long? will that mess anything up???
Old 03-22-2013, 01:48 PM
Disconnect the negative for 15 minutes. Just breaking the power loop and you wont shock yourself. No it wont mess anything up (or cause any further damage). Your in dash clock and date will reset. I dont know if it will help or do anything for you. But its worth a shot.
And the battery is located in the trunk, right side, under the car jack. If all this fails to fix it you will need to take it to a shop and have them clear the codes and then re-assess it after.
2011 535i
2003 745li (Sold)
HID Guide
LED Guide
ABS/DTC Guide
