Old 03-22-2013, 02:07 PM
riff riff is offline
Mein Auto: 745i, 330Xi
Hi Piers
The trace file you posted helped. It put me on the path of checking each one of the ASK.C0* files. Come to find out only the ASK.C04 profile has a tuner_vor_0905 for INST_ID_TUNER.
I have two ASK units on hand (plus the 2002 original). Both produce an ASK FSW_PSW.TRC file that is categorized in NCSExpert as ASK.C05 profile (i.e., not a C04 file with the "vor" option). One ASK unit is from an early 06 760i and the other is from a 2008 750i.
So....
Can I just change the value in the 2008 TRC to tuner_vor_0905 (which kicks out an error in NCS Dummy ASK.C05 profile) and hope that works? Or do I have to find an ASK that runs a ASK.C04 profile (and how does one determine what ASK part # to look for in that case)? Is there a way of 'forcing" NCSExpert to produce a ASK.C04 profile that will work?
Thanks for you and anyone else who helps me out on this.
Riff
Old 03-22-2013, 02:24 PM
Originally Posted by riff View Post
Hi Piers
So....
Riff
Update on the profiles of ASK.C04 and ASKC05.
When I loaded my ASK.C05 file into the NCS Dummy reader if returned the error "Unresolved function keyword "CODIERUNG_ERFOLGT" (which I think loosely translates to "coding is"). Make sure the chassis and module match those...(can't read the rest)". Interestingly enough this variable has a value of "codierung_erfolgt". I get a similar error when I try to enter " tuner_vor_0905" in the ASK.C05 file.
So using the stock NCS Dummy ASK.C04 profile with the required tuner_vor_0905 variable returns the first error mentioned above. Using the ASK.C05 profile and just changing "ab" to "vor" gives a similar error. Haven't figured out how that helps me yet. I look to you great minds to guide me in my quest.....
Old 03-26-2013, 05:06 PM
Anyone have any thought on this? I still cannot get it to work with the ASK.C04 file (the ASK in place generates a C05 file) without NCSExpert throwing an error (C04 has the "vor" option). Is it possible that I need to change the vehicle order to reflect the facelift ASK?
Given all the success on doing facelifts as shown on this forum I feel I am just missing some simple step.
Thanks for any ideas and guidance.
Old 03-26-2013, 05:19 PM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
To be honest i'm not really certain here.
I just coded it with that trace and it accepted it and worked.
My ASK is from mid 2006, maybe the software on the newer ASK no longer has the option as it became redundant.
Maybe it is possible to flash the ASK with an older version of the software that accepts the command if yours is newer?
Old 03-26-2013, 09:44 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
ok I tried to follow your post but they are all over the place .
if you like PM me your # & I will try to help you out ...
Old 03-27-2013, 05:58 AM
BSOD BSOD is offline
Mein Auto: 2006 BMW 650i Sport
Riff
Are you using the FISTER profile in ncsexpert? this should allow you to override the .C0x file to match your ASK unit instead of whatever it defaults to based upon the build date code in your VO. (Other profiles might allow you to do this, but I'm not familiar with them so can't comment)
Are you using ncsdummy to make your changes to the trace file which makes it a lot more user friendly and prevents manual editing errors in the trace file. It will only allow you to select valid options available against each entry in the trace file.
If you have a 2008 ASK then you should be using the .C05 file.
Old 03-27-2013, 03:12 PM
Thanks to everyone for responding
Paper I will PM you tonight with my number. I am east coast USA.
I am using Revtor's NCS Expert Profile. I tried downloading FISTER but had virus problems with the site that offered it. Please LMK of a good site from which to download. I don't understand what you mean by overwriting. I thought each module had its own trace files that had to be modified based on their content and the desired mod. IOW, I don't understand how the profiles work.
I am also using NCSDummy.
Today I started from scratch. I reinstalled my original ASK (2002 745i) and read the TRC file (ASK.C02) and did the same for the 2006 and 2008 ASK (ASK.C05 for both).
I again tried to modify the TRC files for the 2006 and the 2008 using the "vor" option as found in ASK.C04. I tried uploading these files through NCSExpert as MAN files to each respective ASK. Unfortunately I got the same error as noted above.
I tried to use the ASK.C04 configuration with the 2002's TRC file. This gave me an error on an unrelated issue (VOLUME_MAX....) and additionally would not let me select any options (there were no radio buttons to check off).
I'd attach the TRC files but it looks like that can't be done. I did not note anything special about them.
Again - thank you all for your help.
Old 03-30-2013, 02:07 AM
chowdarygm chowdarygm is offline
Mein Auto: BMW 318i E46, 735i E65
Paper.. i am in the same situation.... can you help me please....somehow i guess i bought a facelift ask without knowing it is. other users suggested that it is a FL ASK what i got , from the attached screenshot.
please help
Old 03-30-2013, 12:25 PM
PAPER's Avatar
CRISP & CLEAN
please help
Post a pic of the Ask unit you purchased
Sent from my GT-N7000 using Bimmer App
Old 04-01-2013, 10:23 AM
it looks exactly like pre-facelift version (attached)
but when i am trying NCSexpert and WinKFP, both are reading the ask.c05 file automatically which i guess is for facelift.... also the aasembly number is (9150992) which is the latest i guess
i have used WinKFP to write my VIN number and ZBUpdate. it was successful and now my ASK is showing my own VIN only but still sound for radio is not working (tried attaching my own old ASK and radio is working fine but front speakers are not working which i why i bought another one)
what else do i need to do ?
Old 04-02-2013, 01:00 PM
PAPER's Avatar
CRISP & CLEAN
Sorry I took so long to reply .
the Ask in your pic definately looks
Like a Non-FaceLift Ask unit . The
Only thing I can think of is the front
Of it was swapped & that's why it
Reads as a FaceLift unit . There are
A couple things you can do , but 1st
I would try to test the Ask unit in a
FaceLift car . Do you have any friends
Or can you get access to a FaceLift car ?
Old 04-02-2013, 01:02 PM
unfortunately not....mine is the only 7er i can see in my company parking atleast....
Old 04-02-2013, 01:17 PM
PAPER's Avatar
CRISP & CLEAN
Man that really sucks . Maybe make a
Topic asking if there is anyone in your
Area willing to let you try the unit in
There car
Old 04-02-2013, 01:28 PM
There car
sure....
but what is the process to code a Facelift version to pre-fl ? writing the VIN alone is not sufficient ? you have done good number of fittings right? what extra do i need to do ?
Old 04-02-2013, 01:34 PM
PAPER's Avatar
CRISP & CLEAN
sure....
There is more to it than just coding . More
Info about your car is needed . Do you have
PDC sensors , what other upgrades have
you done or plan on doing ?
Old 04-02-2013, 01:36 PM
it is E65 735i 2002 model... i have front and back PDC sensors (both working with new ASK)
no other upgrades other than the tuner antenna i replaced for radio...all are normal factory options....
Old 04-05-2013, 12:52 PM
irish745 irish745 is offline
Mein Auto: e65 745i
just fitted a facelift ask 25/06 today and having the exact same issue need help
Old 04-06-2013, 12:37 PM
Mein Auto: e65 745i
All working now.I went and got the tuner module 06/06 from the car I got the ask from ,.plugged in and radio workd straight away ,I then was able to change the parameters i of the ask trc file c.05 in ncs dummy and write it back etc.but I know this doesn't solve the tuner issue of ab09/05 only being in the ask c.05 file but installing the newer tuner solved the loss of radio which was my only prob when fitting the facelift ask which had the uptodate trc file and I now can code anything I like in the ask file so job done
Old 10-16-2013, 08:45 PM
Eute Eute is offline
Mein Auto: BMW 745i, X5
Facelift MMI & Facelift Ask Unit
I am researching how to retrofit an Aux input for my early 2002 745i. Some of the online videos show how to install in an E65 equipped with Facelift MMI & Facelift Ask Unit. I assume this refers to the screen and the radio unit. How do I know whether I have this? Further, the unit must apparently be recoded to operate the Aux input. I believe I can do the installation of the Aux kit but don't where to turn for the coding.
Old 10-16-2013, 11:03 PM
PAPER's Avatar
CRISP & CLEAN
The search feature is your friend !!!
but to help you out I will say that the FaceLift MMI & Ask unit
are in the years from 2006 to 2008 . So unless you changed
yours & upgraded those units , then NO you do not have FaceLift units ...
Old 02-17-2014, 10:25 AM
Weld745i Weld745i is offline
Mein Auto: 04 745i, 10 328i, 04 545i
Hey what's up guys, got a 2004 745i I am wanting to do a Mmi coding and also add the aux in the vo, I think I got the +naux down I just need some step by step help with coding the Mmi so that the aux shows up then I think I can do the +naux in the vo and then order the cord from bmw I watched "PAPER" video on pulling the ask and hooking up the 3 wires in the correct spots, I hope I am going in the right direction with this and of course I'm learning a lot from reading what you guys are posting.....anyways some help will be much appreciated Click image for larger version
Old 03-02-2015, 02:48 PM
tony745li tony745li is offline
Account Under Review
Mein Auto: 2003 bmw 745li
Could some one please help me , i have a 2003 bmw 745li , i really want to have the aux option , i hot a mmi from a 2007 and the ask unit from a 2007 , could someone lead me in a right direction on how to code step by step so i can make the aux work , i also hot the oem aux cable , i hooked everything up , my ask unit will not acknowledge the CD AM FM will not work and I can't get the AUX option to show on the MMI, i can play musing thru the cd changer and i can control the volume through my asking if I can change the songs through my ask Unit you this but I still can't get the CD to work and the axillary to show up on my MMI could use step by step how to code so I can get the aux to play
Old 03-02-2015, 05:11 PM
Get a facelift ANT. All three work together with no coding. Did it in my 2002 and it works fine. ANT goes in the rear driver's side pillar. Don't forget to disconnect the battery.
Old 03-02-2015, 05:24 PM
Whats a ant?
Old 03-02-2015, 05:25 PM
Can u get me a link where i can get the right ant?
