Old 03-15-2013, 08:12 AM
D.B.V.'s Avatar
D.B.V. D.B.V. is offline
Slower Traffic Move Right
Mein Auto: 2009 750i (F01)
Originally Posted by TXSTYLE View Post
Haha! Love it.
Old 03-15-2013, 08:58 AM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
Anywho.... Sweet Chariot my man!
~ Big Marcus
You got me on that one, TX. Laughed out loud in line at Lowes!
Sent from my SAMSUNG-SGH-I317 using Bimmer App
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 03-15-2013, 01:24 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
I aim to please...
BigMarcus ~ EVO 4G LTE
Old 03-20-2013, 02:20 PM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
If anyone was curious in regards to my comments on the LEDs...
After parking it next to my Chrysler, and turning both headlights on in the garage (I back up both cars, so both sit grille to the garage door) my BMW is WAYY too low. I'm going to the dealer on monday to see if they can adjust them upwards.
2016 750i xDrive M-Sport (Current)
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 03-20-2013, 02:26 PM
BaranE BaranE is offline
Mein Auto: '10 740Li
Lightbulb
Mine were too low as well. I had the dealer adjust it. They don't even need a computer to do it. Done manually via screw driver holes on top of headlights.
Old 03-20-2013, 02:27 PM
Popoemt's Avatar
Popoemt Popoemt is offline
Mein Auto: 2015 750i
Is it possible the auto leveling has them at a lower setting (maybe a steeper driveway?) so when you turn the car off they haven't leveled back to a "normal" setting?
2015 750i
2013 740 Li (Lease End)
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 03-20-2013, 04:02 PM
gustovier gustovier is offline
Mein Auto: 325ci
I PM'd you but I figure I'll just share it to give people an idea. 58% residual, 1.3MF, 3k down, 987/mo after taxes. Its pretty reasonable considering a loaded 550 MSport will run you about what 7-800/mo?
This must have been for 10k miles / year for 3 years, right?
Old 03-21-2013, 12:36 AM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
The vertical adjustment screw for the drivers headlight is under a small plastic cap in the fender to the right of the light (when standing in front), the adjustment for the passengers is again to the right of the light inside the access panel for the lamp housing. The other adjustment screw (to the left) moves the lights left/right. Note that if you are at the extremes in adjustment of up/down, turning the screw further makes the light move left/right.
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-21-2013, 05:05 AM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
~ Big Marcus
2011 750i
Old 03-21-2013, 10:40 AM
ChrisF01's Avatar
Gib mir Feurschutz!
Are these the two screws you're referring to? I dont see one on the right of the light...
There isnt anything under that plastic screw thingy on the right, I opened it to see if that was it.
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 03-21-2013, 03:17 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is online now
Mein Auto: BMW 328GT/740LI/750LI
Chris that is one Sexii Color combo . Enjoy!
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 03-21-2013, 03:27 PM
Mein Auto: 325ci
The lowest I've been able to get is $1050 with cold weather, executive, and m sport for 15k/3 years (with use base tax about $2700 paid upfront)
Old 03-21-2013, 05:59 PM
ChrisF01's Avatar
Gib mir Feurschutz!
Mine is 10k/yr 36mo term, I put 3k down. That was with lighting as well. But you have quite a bit more mileage. Sounds like a good deal.
Good luck!
Chris
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 03-21-2013, 08:36 PM
RocknDoc
OK... so the vertical adjustment screw is below the flat cap (that you have to remove) in the fender... next to the one with the "cross". The other screw adjustment is inside the protective case for the headlight accessible through the lids that also allow access to the bulbs.
Old 03-21-2013, 08:50 PM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
Def wouldn't recommend doing it yourself based on your capability level displayed in that post. These should have been aimed at the factory with a light box. Almost makes me think your bumper was repainted at the vdc and headlights removed. Sucks but it happens. Hopefully your dealer has a lightbox and can properly aim the lights like the factory.
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 03-22-2013, 12:31 AM
ChrisF01's Avatar
Gib mir Feurschutz!
I actually have adjusted old fashioned halogens in the past, same type of system. This is the first car in which I would adjust them that has vertical and horizontal auto leveling built into the car. I wanted to make sure I'm not screwing anything up.
The more I drive the car at night I think it needed time to either adjust, break in, or something I unknowingly did quasi-fixed/improved them? I didn't touch the screws yet and I've noticed a difference. First time driving them they seemed very low, equivalent to putting a HID kit in a Halogen Light housing. Now they feel the same as my HIDs, still perhaps a tad low. But no where near what they were... very odd.
As far as possible damage to the bumper, unless they completely replaced it there are no swirl marks or signs of buffing. If they did that good of a job, heck fine by me
Its a bit hard to tell from the picture, but the bimmer is closer to the door, nearly too close. And the center of the LEDs definitely has more coverage than what appears.
I was going to edit out his license plate, but he cut me off, then flipped me the bird...
Not the best picture, but it seems the lights have improved from when I saw them first. Still not a huge difference from the HIDs. Not sure if I would get them, unless they were noticeably improved.
Chris
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 03-22-2013, 01:25 AM
RocknDoc
... Still not a huge difference from the HIDs. Not sure if I would get them, unless they were noticeably improved.
Chris
I think the visual aesthetics of the lights are more appealing than the actual difference in LED performance. I haven't noticed a considerable difference in the LED's vs HID'S... That being said.... The German's (personally being of that ancestry) rarely do anything without applying logic and improvement. The biggest concern I've heard about LED lights is that they get hot... very hot! Not the LED's themselves but the resistors required for them to work. That's also why they have individual fan units on each headlight! Audi had a problem a few years back with their LED headlights melting and actually catching cars on fire!
Here's some info from the new 7 series technical manual that describes the function of these LED headlights in great detail, including which part of the light does what... may surprise you!
ID:	367576 Click image for larger version
ID:	367567 Click image for larger version
ID:	367569 Click image for larger version
ID:	367570 Click image for larger version
ID:	367572 Click image for larger version
ID:	367573 Click image for larger version
Full technical manual:
http://prodcds.bmwuniversity.com/cou...troduction.pdf
Old 03-22-2013, 01:50 AM
ChrisF01's Avatar
Gib mir Feurschutz!
Sweet tech manual!
Thanks!
Chris
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 03-22-2013, 03:44 PM
Popoemt's Avatar
Those tech specs make it look like the price tag for the 7 is on par with just the amount of engineering that went into the headlight mechanics, testing, all of it. Not being an engineer it is hard for me to fathom the amount of man hours and testing that went into knowing how to angle the housing and where to place each electronic piece to get the lighting in just the right spot... Very cool to see, thanks for sharing! V/r, Tim
2015 750i
2007 G35 (trade-in)
