BMW E65 2002 735i Error codes, suggestions needed - Bimmerfest - BMW Forums
Old 03-07-2013, 01:56 PM
chowdarygm chowdarygm is offline
Mein Auto: BMW 318i E46, 735i E65
Hi All,
I have done a diagnosis with INPA and cleared some fault codes. but the below ones still remain. can anyone help if i can DIY these issues or its advised to go to a BMW dealer only?
done a search and found what these errors mean but couldnt find any DIY's. so your help is much appreciated
9649 Resistance,firing circuit,thorax airbag,front left,too low
9A6A Resistance,firing circuit,thorax airbag,rear left,too low
9C76 Auxiliary-water pump (my local car service replaced a pipe going to water pump coz of coolant leak and told the issues are resolved but still get error)
6059 Fault, wheel sensor undefined
604E Fault, RDC system
and lastly my bugging battery has been checked by car service guys and told that its in perfect condition but randomly i get 'recharge battery' warning whenver i run the CD player when car is off for 5 minutes (can be due to me not going for a loooong drive since loong time) ?
sorry if i have missed any of the above ones solved somewhere
Thank you
Old 03-07-2013, 04:23 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
It could be your battery . Maybe try
Taking your battery out & charging it
Up . Put it back in & see if you still get
The Errors
Sent from my GT-N7000 using Bimmer App
Old 03-07-2013, 04:35 PM
The Errors
ok....many suggested this....so you feel its worth giving the battery a try ...then lets do it...mission battery charging....
Old 03-07-2013, 05:30 PM
PAPER's Avatar
CRISP & CLEAN
Make sure you disconnect it from the car completely .
Good luck hope that works for you .
Old 03-07-2013, 05:34 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
Question on Battery charging: Why should you ever have to "charge" an ACTIVE battery? Wouldnt that mean something's wrong with either the battery itself or charging system in car?
Fun Doesnt Come Cheap!
Old 03-07-2013, 06:06 PM
PAPER's Avatar
CRISP & CLEAN
yes you are correct , but if the battery holds a charge it might
help with solving the problem with his errors or at least giving
an idea at what else to look at ( alternator , battery , IVM , PM )
Old 03-10-2013, 10:50 AM
The Errors
as some of my other BMW friends suggested, instead of removing battery and charging it, i took it on a loong 2 hour drive which as per them should recharge the battery to full
checked the codes and some new codes cam up
272C Additive mixture adaptation, bank 1 - control limit reached
272D Additive mixture adaptation, bank 2 - control limit reached
could this be that there is a vacuum leak somewhere? does it cost much ?
for the battery check, PAPER, can you check the below voltage screenshots and suggest any issue with the battery or you still recommend to charge it once separately? as the error codes still remain the same
ID:	365689   Click image for larger version
Old 03-12-2013, 04:00 AM
Anyone?
Sent from my LT18i using Bimmer App
Old 03-12-2013, 06:02 AM
pedro2u pedro2u is offline
Mein Auto: 745i
and you might want to listen to the radio/cd with the ignition off. Just eject the key and hit the radio "ON" button. That way all the other car electronics are off and only the radio is on. I've never seen that "recharge" message since I started doing it that way
Old 03-22-2013, 06:58 AM
changed the battery to a better one and still the codes exist. so i guess the battery problem is ruled out.
gave my BMW to a dealer due to the check engine lights coming up for air sensors after repairing it at Bosch also. BMW fixed it for 230 euros but the car is still sitting at dealer to check what the Airbag lights are coming up for?
but the brainless bugger forgot to check the airbags since Tuesday and today when i called to know when i can pick up the car, he told he forgot the airbags and need time until Monday to check it.
as battery is not the problem, can you tell me what could have been the problem and how much more you think he would charge ?
please advise urgently as i am thinking to bring the car back today itself as i didn't like the attitude and carelessness of the dealer
Old 03-22-2013, 01:13 PM
got call from dealer and he mentioned that wiring in the pillars has to be changed for airbag lights and will cost 750 euros......
can this done with DIY ? please somebody reply
Old 03-23-2013, 07:50 AM
anyone?
Old 04-09-2013, 11:51 AM
to be sure on the battery problem, bought another perfect condition original BMW battery and registered it properly with DIS. cleared the codes and the airbag light has come back again
please help ..... now i have started regretting the buy with one problem a day, not able to resolve them without going to dealer who only services to earn as high as possible they can on a car
Old 04-09-2013, 02:33 PM
Firecatdriverf7 Firecatdriverf7 is offline
Mein Auto: 745li ,Rx8 & 7
Is not his recharge battery for his FOB while its in the IGN and not charging the fob?
Old 04-09-2013, 02:36 PM
As per air bag harness yes it's a DIY , nothing complex about replacing a harness , but if you know where it's cracked or broken even easier to fix
Old 04-09-2013, 02:51 PM
i am not able to find harness anywhere on internet. do you know the part number or how i can search for it?
i will be in US for 3 weeks of vacation in next 20 days, so if i can find one in there maybe i can buy and bring here and fix my car
problem is i dont know where exactly the problem is
Old 04-09-2013, 02:56 PM
The part # should be on your work order when you were at the dealer for the quote, sorry but it would be only a BMW thing ,or a used one , or a repair job. But on the A post it should be easy to repair
Old 03-01-2014, 06:36 PM
Educlass Educlass is offline
Mein Auto: BMW
Any result I'm having a code 9649 airbag issue can't find a resolution. Any updates on a fix?
