E34 (1989 - 1995)
Old 03-23-2013, 08:03 AM
Cornbinder89 Cornbinder89 is offline
Mein Auto: Marmon
New member with questions
Hi all,
I am considering a '90 535i with auto. Supposedly the car in question has a blown diff. A quick look on the net leads me to believe that used diff shouldn't be too much.
So now for the questions.
How likely is a diff to fail on these models? My experiance is most diff's are one of the last things to fail unless run out of oil or abused.
Any other things I should look at before purchase?
What are the weak point and strong points of this model?
It would be way to nice if it was the "bisket joint" behind the trans, but I haven't got to where I can see whats happening with the car yet.
Old 03-23-2013, 08:21 AM
DanM5's Avatar
DanM5 DanM5 is offline
My other ride is ur wife
Mein Auto: 535is-m
Can you get it up in the air to have a good look at it..?? If the diff failed and it hasn't been driven, check the rear tyres, they'll show signs of abuse if its been abused... Great car otherwise!
Get in, sit down, hang on, shut up!!
Old 03-23-2013, 08:41 AM
Mein Auto: Marmon
What kind of fuel mileage could I expect driveing it mild? I'm just looking for basic transportation and the price of this car is cheap enough that even with a used diff, would be a good buy.
Old 03-23-2013, 08:53 AM
DanM5's Avatar
Mein Auto: 535is-m
i couldnt tell you mate, its not something i ever worry about... like all cars though it depends how you drive it...! One of the other forum members mite be better able to fill you in about that... do a thread search!! Buy it if the diff isnt a concern, you wont regret it!! post pics if you can...
Old 03-23-2013, 02:09 PM
manuelwindows manuelwindows is offline
Mein Auto: 1994 530i, 1977 320i
averaging around 16 mpg. if you can get this car for $1500 or so in running shape, even with that differential, that's about right, it could last you quite a while if you do the regular maintenance and drive it "soft"
if there is any way for you to look for a masked transmission problem that will cause the tranny to fail before you buy it, that would be ideal because if that is being hidden and goes out on you after you buy it, it'll cost you the price of the car in parts alone to get it fixed
Old 03-23-2013, 02:57 PM
Mein Auto: Marmon
Thanks for the replys. I was able to start it and run it for a little while, The diff is defenatly blown (drive shaft spins, but no output and no speedo). recent waterpump, but low coolant light on and smell of coolant out the exhaust. SO likely headgasket+ diff is more then I want to do, even for $850.
Got to look at the title, this owner only had for a year and a half, while the previous title owner had the same last name. Looks like a car handed down to son, and son ran it into the ground.
I'll keep looking.
Old 03-23-2013, 03:11 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I'll keep looking.
You are wise
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
