Old 03-23-2013, 06:56 PM
Rayg1022 Rayg1022 is offline
Mein Auto: 1997 BMW 528i
After market window regulator 528i
Need some help ASAP I just bought the after market window regulator for my front left passenger window and have everything installed and it stops mid way on the way up. any ideas?
Old 03-23-2013, 07:00 PM
AH673000 AH673000 is online now
Did it come with a new motor or did you transplant your old motor ?
Old 03-23-2013, 07:06 PM
Using old motor... nothing was wrong with the motor
Old 03-23-2013, 07:07 PM
Is there DIY that shows the layout of the front driver side window? I have 3 star looking screws up top and 2 10mm for the bottom?
Old 03-23-2013, 07:30 PM
cn90 cn90 is offline
The curvature of the guide rail is not correct ---> binding half way through.
This is the REAR regulator DIY I did a while back, but I showed where the problem could be, see post #16:
http://www.bimmerfest.com/forums/sho...d.php?t=556902
Old 03-24-2013, 07:56 PM
jigga1 jigga1 is offline
Mein Auto: 528i
I had a problem with my window getting stuck half way. I lubed the track and it solved my problem. Hope that helps.
Sent from my SPH-L710 using Bimmer App
Old 03-24-2013, 09:56 PM
Why not type /driver side window regulator in the best links?
You will never get a thread with more pictures than that!
- One user's effort to diagnose, rebuild, and replace a BMW E39 front driver side door window regulator (1) and how to remove a BMW E39 front passenger side door window regulator (1) (2) & the unintuitive trick to effortlessly loosen and tighten the astronomical cable tension without damaging the front door window regulator (1) & how to rebuild and restring your current E39 front door window regulator (1) & scores of pictures showing how NOT to remove & repair your front door window regulators (1) & how to replace just the rollers (1) (2)
Note: YOUR job, now, is to ADD VALUE by snapping a photo of YOUR SITUATION (so that others benefit from your effort).
