E34 (1989 - 1995)
Old 03-22-2013, 10:01 PM
markfothebeast markfothebeast is offline
Mein Auto: 1995 BMW 540i
95 540i: Where to purchase all CCV Hoses?
Removing intake, replacing all gaskets, replacing CCV. Need to find somewhere online that sells ALL the hoses to the CCV. When I bought my 95 540i the CCV has been completely blocked off and has no hoses.
Old 03-22-2013, 10:05 PM
Khemraj Khemraj is offline
Mein Auto: 2000 328i
Rock auto
Old 03-22-2013, 10:11 PM
Okay. So I'm replacing valve cover gaskets. Thought I'd also do intake gaskets as well. And upgrade to newer 4-valve fuel injectors. Main purpose is to fix my oily stinky idle due to the CCV. Here's what I've ordered:
Valve cover gaskets
CCV w/Gasket (PVC)
Intake Gasket Set
Are there any other potential gaskets I need to replace during this process?
Also, as mentioned above, I need the hoses for the CCV system. Thank you!
Old 03-23-2013, 12:15 PM
Can anyone link me the hoses please? I don't see them on Rock Auto. I can't find a diagram for where the hoses connect to, what the hoses look like, or how many hoses there are either.
Old 03-23-2013, 10:38 PM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, E30, E24
The only hose coming off the ccv plate goes to the fuel pressure regulator. There's also a metal tube that connects to the plate that goes to the crankcase vent.
There are two other orifices on the ccv plate but they're both plugged. Here's a link to the Realoem diagram: http://www.realoem.com/bmw/showparts...98&hg=11&fg=40 You can see the plugs and the O-ring (4) for the orifice where the crankcase vent tube goes.
I just did this job about a month ago -- my valley pan finally started leaking badly enough that I had to fix it. I changed the CCV plate, profile gasket, throttle body gasket, intake manifold gaskets, injectors and injector seals while I had the intake manifold off.
If you want to change out injectors, there's a guy on the boards who will clean and reflow yours or swap yours out with rebuilt units for a very reasonable price. Search for MEPEH. I've been running on his injectors (the stock red tops) for a couple thousand miles now and the car runs great.
Old 03-30-2013, 10:51 AM
Thanks! Im going to be working on this today. I had already purchased an injector set but a newer 4 nozzle style. My CCV must be connected although i didnt think so before. It has 2 plugs on it.
Sent from my SGH-S959G using Bimmer App
